Building a Car Port
/ Building a Car Port
What size beam did you use for the 24 foot unsupported span?
Along the 24' there is a post at 12 feet. The load bearing beam in that 12' is made of two 2 x 8 x 12' sandwiched together.
On the gable ends and at the 12' center there are 2 x 8's on each side of the 6" post. These are the non load bearing and they span 20 feet.
Sent from my iPhone 2.0 using TractorByNet
We put up the trusses yesterday but then Bonnie moved in, uninvited I might add. :D
There were 13 altogether and they weren't too awful bad but sure was glad to find the bottom of the pile in that hot afternoon sun. The check for the house roof replacement came in the mail yesterday, just in time so that we can purchase shingles to match the house roof. (Severe hailstorm a few weeks ago decimated the house roof which now has to be replaced.)
Glad to have this much work behind us now. Joked with the wife and said we were tired and just going to staple a tarp to the trusses and "call it good." She didn't smile. LOL!
/ Building a Car Port #63
What are you going to use for decking? I personally thing OSB is superior to plywood, but either work. Don't forget to use H clips between the trusses on your decking, and stagger your joints.
Haven't purchased that material yet. What thickness OSB do you recommend? We will have architectural shingles on it to match the new house roof.
/ Building a Car Port #65
7/16's is used on tens of millions of homes all over the country. It's good for spacing up to 24 inches. Sadly, the cost is on the high side right now. It fluctuates from under $7 a sheet to twice that. I just saw it for $11 the other day.
Good deal, my trusses are 24" OC. I'll be curious to see what our price is here in WNC.
On the roof edge on the gable end overhang should the roof deck extend or be flush with the rafter?
/ Building a Car Port #69
The gable end roof does not have to extend past the wall. In most homes that's done to add appeal to the look of the house, and also to keep a little water off of the walls. Some houses have gable vents, and if you do that, it's important, but since you don't have a gable vent, it's not needed.
If you decide to do that, there is a lot of work to do it right. In your case, I would decide if that's the look you want, and if so, we can go forward with what you need to do to make it happen. If not, then don't worry about it.
/ Building a Car Port #70
I like gable overhangs, just a personnal preference.
The gable end roof does not have to extend past the wall. In most homes that's done to add appeal to the look of the house, and also to keep a little water off of the walls. Some houses have gable vents, and if you do that, it's important, but since you don't have a gable vent, it's not needed. If you decide to do that, there is a lot of work to do it right. In your case, I would decide if that's the look you want, and if so, we can go forward with what you need to do to make it happen. If not, then don't worry about it.
Actually I was planning on the overhang and read about the cantilever design in Justin's house build thread.
What I was really asking was whether the deck will extend past the overhang or be flush with the 2 x 4. Looks like the roof deck of my house extends about an inch beyond with aluminum flashing protecting the wood. I could post a sketch tomorrow.
/ Building a Car Port #73
The decking should be flush with the edges of your trusses. It is very common to install a 1x2 piece of trim at the top of your gable end, then after you put your paper on the decking, you cover it with flashing. I personally like T flashing. It extends the flashing out a bit more and gives you a better drip edge then regular flashing. Both work good.
Was poking around this afternoon checking closer on the house before getting the new roof work started. Then 'poking' became a sad note rather than a figure of speech.
Found some rotten wood apparently from improperly installed fascia?? Hoo-boy, got to get to the bottom of this before starting the re-roof.
Sorry to derail my own thread... LOL!
Finally started putting down some roof deck. 7/16" OSB on trusses 24" OC. ImageUploadedByTractorByNet1469322385.296547.jpg
/ Building a Car Port #76
Decking is always fun. You get that instant gratification of making a big change in how it looks quickly!!!
Are you going to install a fascia board? You don't have to, but it does add some strength to the rafter tails and the edge of the OSB. It also makes adding gutters real easy in the future, which is really nice if you have to walk through the water coming off of the roof to get to your car.
The number one reason building fail is movement. They all move, but the more they move, the more that goes wrong with them. Roof start to leak, cracks appear, and then things start to rot. Diagonal bracing is very important in locking everything together. Ideally it should be as low as possible, but with covered areas, its always about two feet down from the top of the posts.
/ Building a Car Port #77
I always diagonal brace everything. I built a carport and a patio cover for the engineer that I use when I need a stamp on things once upon a time. He engineered pier and beam along with spans for additions on remodels for me. One of the few times the actual customer supplied me with detailed drawings. He had no bracing specified on the posts so I asked him how he would like them. He stated none they are not needed. So I asked him to explain. If the cover is freestanding you need the supports on the corners to prevent it from falling over due to winds. If the cover is attached to a building and you have the proper roof on then you do not need them as the tie in to the structure and the roof prevents any movement. He stated if the structure fails then you failed in your tie in to existing structure.
I did not do any on his and they are still standing with no issues. I did them on everything attached before his, and honestly everything after. He would also occasionally look at my drawings for remodels and advise me to go with smaller LVLs or glue lams when I was opening spaces up to save money. I just had him stamp the overkill anyways. More is not always better, but overkill brings peace of mind :)
I have diagonals to install for stability. Need the trusses covered first, they've been exposed much longer than I'd prefer.
/ Building a Car Port #79
... If the cover is attached to a building and you have the proper roof on then you do not need them as the tie in to the structure and the roof prevents any movement. He stated if the structure fails then you failed in your tie in to existing structure.
With all things lumber, this is only true up to a certain distance. That distance is up to the engineer to decide, or the builder if he's comfortable with sizing lumber and it's a small distance. But there is a point when you go so far out that the wood will bend regardless of how well it's attached to the building. This of course assumes that the building is secure. You might be surprised how many newer, open floor plan homes rack something horrible!!!!
Yep, fascia board is in the plan, as well as gutters. We had the house re-roofed and guttered after a bad hail storm in May. Saved enough gutters to install on this carport. My desire is that the carport look like it is a part of the house and not just an afterthought.
It really has been very rewarding to see it go up, albeit a bit slower than we originally planned. So many different things can occur unexpectedly, lengthening the total duration of the build. You are correct, adding the roof deck makes a big difference in how it looks more quickly than anything else. It has also reinvigorated me to get it done sooner. Partly because the OSB doesn't need to get wet and partly because I can see the light at the end of the tunnel.
KOMATSU PC 200 EXCAVATOR (A65643)
KOMATSU PC 200...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
Landhonor Hydraulic Logging Winch (A66285)
Landhonor...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Hobart Beta- Mig 200 Welder (A65579)
Hobart Beta- Mig...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
