Self built Mulcher .
/ Self built Mulcher . #21
Will you be mounting the motor on rubber blocks ?? I personally would just so if will vibrate some with the mulcher shaking so much
/ Self built Mulcher . #22
Hi.I think I will subscribe to your topic.
Started building the cabin floor and the fitting of the Grammer air ride seat .
Tony , I got your phone message yesterday when I went to town as we have no mobile service at home . I could not return your call as the phone does not log a number if it goes straight to message bank and you didn't leave a number .
/ Self built Mulcher . #26
Looks to be coming along nicely. I like the way you're keeping the weight low for stability. What is the width over the tracks and length? Do you have a ballpark on what it will weigh?
Thank you , the track width is 1800mm , the tracks are just under 3000mm . I think it will weigh around 7 tonne with the head .
All but about 1.5 tonne will be below 1200mm in height to it should be pretty stable .
Radiator is going in today , it is new , old stock out of a Cat loader and is very heavy which is what I want . I want as much weight as I can get hanging out back to counter the weight of the head .
Me too. Love seeing creative engineering!!!!!
It just got a little more "creative" , I am on the hunt for a 2 ton excavator arm for the front of it . It will have a small tree shear on the end so I can snip trees off and feed them straight into a front mounted woodchipper on the machine . I will go through the paddock first with the chipper and then again with the mulcher to clean up the stumps and rubbish . Mulchers in general are too slow at processing whole trees . A chipper with 175hp driving it will chip them in seconds .
I will also be able to rake debris with the arm from tight places and direct it into the mulcher . The arm will also be able to run a small flail mower for mowing embankments etc .
/ Self built Mulcher . #30
Another amazing thread on TBN
/ Self built Mulcher . #32
And it just gets better and better.:thumbsup:
Today I bought a new backhoe off New Holland for a 55hp Boomer .
I couldn't get a small excavator at the right price so this will suffice . I will remove the stabilizer legs and use that function and the control valve sticks to drive the tracks . Servo/Pilot system hydraulics would have been good that the excavator would have provided , but this will do at a 20k saving .
/ Self built Mulcher . #34
May I ask. Why did you buy one new?? Around here you could get a good 3pt one that would be good to chop up and use for 3k. It would save alot more money. Or couldn't you find any?? Only reason why I don't buy one is cause a back hoe costs 6k and I don't have a tractor for one
/ Self built Mulcher . #35
Gees Reg, always the way , buy something then find it cheaper elsewhere. Yesterday on the job i'm working I came across a backhoe similar to the one you just brought. The farmer says "take it away" if i want it. :laughing:
To answer the last two posts . If I wanted to end up with a secondhand worn out piece of junk after I go to all this trouble , I would have used second hand worn out parts on it .
/ Self built Mulcher . #37
Outstanding project Eagleview! I hope this works exceptionally well for you. Oh to have a nice shop and some real tools...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
2022 EZ-GO ELITE...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
1000 GALLON FLAT BOTTOM POLY TANK (A64278)
1000 GALLON FLAT...
Ford Metal Tailgate Sign (A64557)
Ford Metal...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
