Self built Mulcher .
/ Self built Mulcher . #21
Will you be mounting the motor on rubber blocks ?? I personally would just so if will vibrate some with the mulcher shaking so much
/ Self built Mulcher . #22
Hi.I think I will subscribe to your topic.
Started building the cabin floor and the fitting of the Grammer air ride seat .
Tony , I got your phone message yesterday when I went to town as we have no mobile service at home . I could not return your call as the phone does not log a number if it goes straight to message bank and you didn't leave a number .
/ Self built Mulcher . #26
Looks to be coming along nicely. I like the way you're keeping the weight low for stability. What is the width over the tracks and length? Do you have a ballpark on what it will weigh?
Thank you , the track width is 1800mm , the tracks are just under 3000mm . I think it will weigh around 7 tonne with the head .
All but about 1.5 tonne will be below 1200mm in height to it should be pretty stable .
Radiator is going in today , it is new , old stock out of a Cat loader and is very heavy which is what I want . I want as much weight as I can get hanging out back to counter the weight of the head .
Me too. Love seeing creative engineering!!!!!
It just got a little more "creative" , I am on the hunt for a 2 ton excavator arm for the front of it . It will have a small tree shear on the end so I can snip trees off and feed them straight into a front mounted woodchipper on the machine . I will go through the paddock first with the chipper and then again with the mulcher to clean up the stumps and rubbish . Mulchers in general are too slow at processing whole trees . A chipper with 175hp driving it will chip them in seconds .
I will also be able to rake debris with the arm from tight places and direct it into the mulcher . The arm will also be able to run a small flail mower for mowing embankments etc .
/ Self built Mulcher . #30
Another amazing thread on TBN
/ Self built Mulcher . #32
And it just gets better and better.:thumbsup:
Today I bought a new backhoe off New Holland for a 55hp Boomer .
I couldn't get a small excavator at the right price so this will suffice . I will remove the stabilizer legs and use that function and the control valve sticks to drive the tracks . Servo/Pilot system hydraulics would have been good that the excavator would have provided , but this will do at a 20k saving .
/ Self built Mulcher . #34
May I ask. Why did you buy one new?? Around here you could get a good 3pt one that would be good to chop up and use for 3k. It would save alot more money. Or couldn't you find any?? Only reason why I don't buy one is cause a back hoe costs 6k and I don't have a tractor for one
/ Self built Mulcher . #35
Gees Reg, always the way , buy something then find it cheaper elsewhere. Yesterday on the job i'm working I came across a backhoe similar to the one you just brought. The farmer says "take it away" if i want it. :laughing:
To answer the last two posts . If I wanted to end up with a secondhand worn out piece of junk after I go to all this trouble , I would have used second hand worn out parts on it .
/ Self built Mulcher . #37
Outstanding project Eagleview! I hope this works exceptionally well for you. Oh to have a nice shop and some real tools...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2022 EZ-GO ELITE...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2020 FREIGHTLINER M2 4X2 S/A 26FT CDL REQUIRED CURTAINSIDE BOX TRUCK (A67148)
2020 FREIGHTLINER...
2018 International DuraStar 4300 Vactor RamJet Sewer Jetter Vacuum Truck (A64556)
2018 International...
2010 Club Car Electric Cart. (A64557)
2010 Club Car...
