ford 2000
/ ford 2000 #1
dave1952
geneva ohio
1966 ford 2000
hi I am dave and I just joined this sight I have a 1966 ford 2000 and am rebuilding lift cover on the piston the shop manual says put on leather ring and o ring howerver the rebuilt kit has a plastic ring aleather ring and o ring when I tore down piston it has the plastic ringand not the leathe ring the book calls for what ring should I use thanks
/ ford 2000 #2
Most likely the plastic backup ring is a replacement for the OEM leather ring. Install it per the instructions.
/ ford 2000
:anyone:hello Dave 1952 here got a little problem had to buy a new voltage stabilizer for 1966 ford 2000 old one has 3 terminals b and I on same double terminal the third terminal is marked with an E the new one has just 2 double terminals one set marked B the other marked I where do I plug the wire marked E lost:(
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
John Deere 350 Sickle Bar Mower (A66408)
John Deere 350...
S/A Towable Solar Speed Radar Trailer (A64194)
S/A Towable Solar...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
Cedar Boards (A65640)
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
