ford 2000
/ ford 2000 #1
dave1952
geneva ohio
1966 ford 2000
hi I am dave and I just joined this sight I have a 1966 ford 2000 and am rebuilding lift cover on the piston the shop manual says put on leather ring and o ring howerver the rebuilt kit has a plastic ring aleather ring and o ring when I tore down piston it has the plastic ringand not the leathe ring the book calls for what ring should I use thanks
/ ford 2000 #2
Most likely the plastic backup ring is a replacement for the OEM leather ring. Install it per the instructions.
/ ford 2000
:anyone:hello Dave 1952 here got a little problem had to buy a new voltage stabilizer for 1966 ford 2000 old one has 3 terminals b and I on same double terminal the third terminal is marked with an E the new one has just 2 double terminals one set marked B the other marked I where do I plug the wire marked E lost:(
(12) Round Grass Hay Bales (A66408)
(12) Round Grass...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
DooLittle XTM-8418 Trailer (A66285)
DooLittle XTM-8418...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2014 Kenworth T400 Hazardous Material Tanker Truck (A64194)
2014 Kenworth T400...
