Sputtering BX
/ Sputtering BX #11
I'd check the fuel cap first to make sure it's venting properly or the vent hose to make sure it's not plugged. Much cheaper to look at the basic stuff first.
/ Sputtering BX #13
Yes there is a chance for Alge too.
My tractor lives outside, so Im more susceptible, but I did have some alge growth in my filter bowl last year. Since then Ive been using a product called BioBor Jf that is a biocide. No problems with alge since Biobor Jf Fuel Additives - Products
/ Sputtering BX #14
My BX had an intermittent problem and it turned out to be a pin hole in the rubber fuel line... somehow a twig got in there and the thorn punctured the line.
/ Sputtering BX #15
Maybe you should also check your operator presence safety switch. My B26 just started cutting out and after checking the switch, I found that the plastic seat underbody was all cracked up. Too much bouncing around. I remembered putting some JBWeld on it a year or so back to fix some cracks around the safety switch, now in addition to that failing again, the area where the seat is bolted to the seat frame is cracking. I guess it is about time for a new seat on my 2009 model TLB.
/ Sputtering BX
Thanks for all the suggestions. I have a friend who's a very good mechanic, and he suggested I let him remove the fuel tank and clean it out at substantially less cost than the dealer would charge (he also has a BX), so that's the route I've decided to take. Will post the results.
/ Sputtering BX #17
Removing those fuel tanks is a big job with a bunch of sheet metal to get out of the way, etc. We had one done down in Louisiana and the dealer took several hours to do it. If he does remove it, be sure to check the pressure relief valve in the tank while you have it off. Many owners of the BX series (many models, ours was a BX2200) have a condition where the tank leaks if it is filled more than about 2/3. I've seen posts saying that was due to a stuck or defective relief valve. Of course some serious cleaning of the tank is in order (steam clean if you can.) Then getting it REALLY dry is another issue. Good luck.
/ Sputtering BX
UPDATE: The tank was removed, drained, and cleaned. Inside was a small amount of sediment, a little twig, and two bugs. I use a siphon to fuel the tractor and I'm thinking the bugs crawled into the siphon between uses. The twig, I dunno. There was absolutely no water, resulting in a clean-looking sending unit. At any rate, the job is done at a cost of $270. A few pics:
/ Sputtering BX #19
I'd bet you are right about the source of the 2 bugs. What a job ! So does everything work OK now I assume ?
2016 CHEVROLET TAHOE (A59823)
2016 CHEVROLET...
International S1900 (A61307)
International...
2017 FREIGHTLINER CASCADIA SLEEPER (A59906)
2017 FREIGHTLINER...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
