CK 30 Gas Lever Not Working
   / CK 30 Gas Lever Not Working #1
lakngulf
Lake Martin Alabama
Kioti CK30
Was using my CK30 around the house, get back on the tractor one time, pushed the Gas Lever and nothing. Obviously is disconnected from the feed wire. I was able to use the foot pedal. Did some observation and found where the lever wire and foot pedal wire meet. Pushed foot pedal to see which one was lever. Follow it back up, it is a green covered wire heading into the dash.
But now to fix it. I see the possibility of removed a part of the dash, with four ??screws?? at the yellow circles. Some were filled with dirt dauber gunk, and I cannot see into them to determine what is needed to remove. Anyone have some experience or suggestions with this? Thanks in advance
   / CK 30 Gas Lever Not Working #2
I haven't had to take my dash apart, so can't help you there. But curious so I will be following this thread.
I've never heard of that lever malfunctioning.
   / CK 30 Gas Lever Not Working #7
Those four bolts do indeed take the front panel off the dash. I have done that, though I was working on the other side for electricity. The throttle cable is the green one, same on my tractor. You may need to pull the rest of the dash, but those bolt are hidden away, don't remember where. The front panel is a good start there.
The gas lever is called the throttle, confused me when I saw the title as I thought you meant the fuel cut-off valve on the sediment bowl.
Thanks. I guess is would be tough for a diesel tractor to have a "gas lever". Sorry about the multiple posts above. TBN was giving me fits yesterday.
Took a little bit of maneuvering but four 10mm bolts got the middle section out, and eight more released the major portion of the dash so I could see the throttle connection. Green wire was broken, and looks like repair is out of the question.
What is best method to obtain a new throttle wire?
   / CK 30 Gas Lever Not Working #10
Local dealer or Michigan Iron has a pretty good web site that you can order from.
Rancho
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
UNUSED PABREAK SPIN3-84" SNOW PUSHER (A57193)
UNUSED PABREAK...
