Running Bamboo Hate it
   / Running Bamboo Hate it #1
Sprinklerman
severna park
New Holland 1925 Kubota bx 24
Spent 4 hours dealing with this weed , Bamboo . I was cutting 2 to 3 inch around bamboo 20 ft plus tall about 1/3 acre . You cant push it over into the rest of the growth . I tries a chainsaw , the blade kept jumping off , tries a sawzall it was way too slow . I finally tried a circular saw , it worked great . So I started dropping the bamboo into an open area , all facing the same way . Then i fired up the tractor , with a 5 ft brush cutter and started shreading the pile . I left the stalks about 4 ft high so they wouldnt go thru a tire . Once the stalks were ground up I used the loader and knocked down the bottoms , and ground them up . Now thats its under control , got to keep it cut so it doesnt take over again
   / Running Bamboo Hate it #3
If you don't get along with your neighbor plant some bamboo along the property line.
   / Running Bamboo Hate it #4
Try Ortho Brush-B-Gon, mix it stronger than recommended, and add a "sticker". You can use "Hi Yield Spreader Sticker", or Bonide "Turbo", or Dawn liquid dish detergent (1 tsp/gal.).
If you use dish detergent, be sure to add it after the water, and the Brush-B-Gon, or you will have a sudsy/bubbly mess.
Spray it on the fresh cut little bamboo stumps.
   / Running Bamboo Hate it #5
One of my neighbors had in catty corner in the back where I used to live. I hated that stuff and I hated them, dayum renters. It was a never ending battle trying to keep that crap at bay. It should be illegal to plant that stuff anywhere. It's just plain stupid to plant it anywhere but in a pot or a completely contained bed maybe. Even then you'd better keep your eye on it.
   / Running Bamboo Hate it #6
Better get a backhoe and dig it up completely then burn it. Any part of a rhizome with a joint will put up a new sprout. Ask me how I know.
   / Running Bamboo Hate it #7
When I did it I just backed the bushog into it over and over; finally at scalping height. Did not run over rooted stalks til scalped. Never left the tractor.
I tried that , but I was in tight quarters and the bamboo was falling on me .
This is the second section I cut down . I read that bamboo doesnt like acidic soil so I got sulfur from john deere landscapes and put that down , then I had a large tree company bring me in 100 cubic yards of tree chips and covered the whole area I did before 6 to 8 inches thick , the chips breaking down make the soil acidic AND I can now run a finish mower over the area and cut it when its short . So far that area has been managed very easily . Now with the rest of the bamboo cut , I am hoping that since there is no green leaves it will not get any sunlight and will slow the growth . I would like to use some herbicide , but the house is on a hand dug well
   / Running Bamboo Hate it #9
Just get a couple of panda bears... they'll eat the bamboo. Sure, they're from China but the quality is quite good.
I did call the Maryland zoo and asked if they wanted it , They said sure bring us all you can . NOT
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
JOHN DEERE 348 SQUARE BALER (A58214)
JOHN DEERE 348...
Kubota B2301 (A53317)
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
