Traction Deere 3038e: 2wd/4wd Level Not Working After Incident
   / Deere 3038e: 2wd/4wd Level Not Working After Incident #1
gatorbait3014
Amherst County, Virginia
First tractor: JD3038e
Hopefully someone on the forum has seen this before and can offer a suggestion...
Got a 2015 Deere 3038e with a D160 loader, with about 45 hours on it so far. I had several acres of land logged-off over this past winter, and I am moving the cuttings and brush into piles for burning.
I was dragging brush in reverse from the edge of a creek with the loader bucket, and got a branch/limb snagged under the left-side of the tractor. It pulled-off the low-pressure hydraulic return hose from the filter assembly, causing loss of control and movement. Hose (#9) in the image was knocked off of the filter assembly (#3).
I loosened the spring clamp on the (1-1/2") hose, and reattached it to bottom of the filter assembly. Then refilled the almost five (5) gallons of hydraulic fluid I had lost onto the ground. All good so far. Regained control of the bucket and transmission. :) So far, so good. I was able to drive back up the mountain to the house, and give the tractor a thorough inspection.
Then, I noticed the two-wheel drive/four-wheel drive lever was all the way down, in the 2wd position. When I pulled it back up, there was none of the normal friction or resistance, and when I let go, the lever dropped back down onto the deck. :eek:
The 2wd/4wd lever (#3) goes through the floorboard, connecting to an arm (#7) that connects to a shaft into the front-left side of the transmission (transfer case?)
Everything appears physically attached, and the shaft rotates when the lever is moved up and down. But, something is not connected. :confused:
I use the tractor almost exclusively in 4x4 mode, due to being on the side of a mountain. I have not noticed not being in 4-wheel drive. But also have not figured out an easy way to check short of finding a mud hole.
Anyone have any ideas on this?
Thank you in advance...
   / Deere 3038e: 2wd/4wd Level Not Working After Incident #2
Lift the front with the bucket and try to rotate front tires by hand to check front drive train?
Finally got a chance to lift the front wheels with the bucket.
They turned freely, and the front drive-shaft rotated.
If I pulled-up on the 2wd/4wd lever while turning the wheels, they engaged and stopped turning.
So, from that, I am assuming that the tractor is in 2wd until this issue is fixed.
   / Deere 3038e: 2wd/4wd Level Not Working After Incident #5
Knocked some sort of retaining mechanism loose with the branch?
If nothing else I'd stop by a dealers lot and crawl under one like it. Take pics under yours and theirs to compare later.
   / Deere 3038e: 2wd/4wd Level Not Working After Incident #6
I agree, something got knocked loose, or knocked off.
   / Deere 3038e: 2wd/4wd Level Not Working After Incident #7
Did you get this fixed? what was the problem?
Re: Deere 3038e: 2wd/4wd Lever Not Working After Incident [WHAT ACTUALLY BROKE]
The 2x4/4x4 shift lever though some linkage controls a sliding collar which engages and disengages the 4x4 on the tractor.
In the attached images (borrowed from Deere's parts website), the "Shaft" #22 (PN# LVU19323) moves the "Shifter" #21 (PN# LVU18520), which intern moves the "Shift Collar" #19 to engage/disengage the 4-wheel drive on the tractor.
In my incident, the "Shifter" #21 broke, and was not moving the Shift Collar. Attached are two images.
The first one is the parts diagram of the shifter.
The second is the blow-up view, that I have marked in RED what broke.
   / Deere 3038e: 2wd/4wd Level Not Working After Incident #9
Did you or the repair shop have to split the tractor in half to make the repair? My seal is leaking and I cannot get the 4x4 shift housing out of the tight spot below the tractor because the opening is not large enough. 6F1FB76A-DF44-4567-A0A0-EC973A5AA74F.jpeg
View attachment 510523View attachment 510524
   / Deere 3038e: 2wd/4wd Level Not Working After Incident #10
Did you or the repair shop have to split the tractor in half to make the repair? My seal is leaking and I cannot get the 4x4 shift housing out of the tight spot below the tractor because the opening is not large enough. View attachment 631280
Did you ever get a resolution to this problem? I have developed a similar leak in a 2012 3032e and it appears a rear split is the only way to remove the MFWD housing.
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2017 Ford F-550 DurALift Bucket Truck (A60460)
2017 Ford F-550...
WATER TRAILER (A58214)
Freightliner Fuel Truck (A56438)
Freightliner Fuel...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
