Door Painting
/ Door Painting
As a person who does remodels for a living, painting doors and trim is something I'm always doing. I have two different airless spray guns. One that I mostly use for enamel. The other is the big one that I put five gallon buckets of paint under it and spray entire houses. The only time I have ever sprayed trim on a house is when it's new construction and there are no floors installed. Then I can spray without taping anything. That's about the only time I consider it better then using a brush. All other times, it's faster and easier to just paint a door with a brush.
I have 20+ doors to paint, so they will have to be done in stages in the garage...I think spraying is going to be more efficient in this case.
/ Door Painting #22
I just saw in the last few weeks someone spraying doors on a house show. They lined them all up like they were on hinges (vertical) or big cardboard pages in a children's book with little spacers at the bottom. They'd spray one side, flip the door, spray the other, flip to the next door. Made it look REAL quick and easy.
Painting Doors With A Paint Sprayer. Spraying Interior Doors. - YouTube
Just google "spray painting interior doors"
/ Door Painting
Now I get it. I feel for you, that's going to be painful no matter how you do it
Thanks for the sympathy. I think spraying them a few at a time will allow me to prevent heavy build up and allow for quicker dry times....I hope anyway. Probably spray them with satin, doubt the semi on the trim will matter or cause any visual issues..Don't really like shiny house paint...Any opinions there?
/ Door Painting #25
Depends on the color.
White semi gloss, is not all that shinny, especially on a door that has a textured surface. But, darker colors can be too shinny for me.
Semi will last longer, because it is more cleanable.
Satin covers better. And, as I said, can be used for better coverage initially.
I would make some tests panels, and decide, before going too far.
Sherwin Williams ProClassic, is what I use for interior trim, if I have a choice.
/ Door Painting #26
Don't forget you can mix semi gloss, and satin together, to make other levels of gloss, if neither is acceptable.
/ Door Painting #27
One tip I found, it may be hard to find a place to set the doors to dry. I always like spraying with the doors laying down to avoid runs, I set them on a cart I have. I use a large step ladder laying on its side to set the doors on to dry. A couple long 2X4s could work also
/ Door Painting #28
Here's the best method I've found for painting doors...
Cut four strips of 3/4" ply or scraps of pine to about 1.5" by 24 to 32" or so.
Drill a hole through the middle of the strips of wood.
Put the door on a saw horse.
Attach two strips with a screw to the top edge of the door and two to the bottom edge.
Set the door on the floor
When the door is laying flat the strips will be pointing up 12" above the door and 12" below.
You've created a "door table"
Now you can spray the door on the flat, flip it over with a helper and spray the other side immediately. And then you can stand it up on the same strips so it can dry. Standing them up keeps the dust off and saves space.
With this method I can do two coats on a whole house worth of interior doors in one easy day. And I can spray all six sides without waiting for them to dry. Just need to brush under the strips when you take them off. But no one sees the top or bottom edge of a door.
/ Door Painting #29
Very clever Mike. Almost makes me wish I had a bunch of doors that needed painting so I could try it out.
Almost.
/ Door Painting #30
I wish I had thought of that. That sounds very clever.
/ Door Painting
Good idea Mike----I'll definitely be doing that.
/ Door Painting #33
Hope it helps someone �� Nothing worse then watching paint dry so you can paint the other sides.
Of course, for new construction, my favorite method is to just paint the door in place on the hinges.
I have a bunch of old hinges that I swap onto the doors for painting. Spray it in place and swap the new hinges back on the next day.
/ Door Painting #34
your full of good ideas... keep 'em coming. :thumbsup:
/ Door Painting #35
Sounds like a lot of work and wood. You could just use 2 on one end and one on the other - 3 legs will not be tippy.
But I have lots of time and not money, plus old and could use less work. Just lay them down, paint one side of several doors, let dry till next day turn over and repeat.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
Farm King 300-bushel Gravity Wagon (A66408)
Farm King...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
more info coming soon! (A61569)
more info coming...
Race Trailer OFFSITE Eden NC (A62613)
Race Trailer...
