Input for a multi process welder.
/ Input for a multi process welder. #21
You can Tig weld aluminum with a DC only welder. You'll need a bottle of helium. It does run hot. About half the amps as with AC. This weld was done on DCEN, with 100% helium.
Good to know .... something to try .... thanks!
/ Input for a multi process welder. #22
Warning for newbies: don't try this unless you have 30 years welding experience.:D
/ Input for a multi process welder. #23
I did it, and I've only been welding a few weeks now.;)
Even did it with an Everlast stick welder, and a Tig rig.
/ Input for a multi process welder. #24
/ Input for a multi process welder. #25
I never had much luck Tig welding aluminum on DCEP. :eek::shocked:
/ Input for a multi process welder. #26
Shield Arc if there was a plan to weld two feathers together from a Turkey to an Eagle you'd find a way!
/ Input for a multi process welder. #28
You give me waaaaaaaay too much credit! I'm just a beginner.;)
He's just a beginner liar....and just in case newbies are following this thread, ShieldArc is a master welder with decades of experience. Don't try things that he fools around with unless you are really sure you know what you're doing. He knows when his experiments fail, you (newbie) might not recognize the difference between a fully penetrated good weld and glue gun weld.
(No disrespect ShieldArc, just wanted to make sure noobs don't go running out to the welding shop in search of Argon so they can do welding repairs on their mother's car...)
/ Input for a multi process welder. #29
Nope. Save that for your mother-in-law's car.
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
1629 (A57192)
1629 (A57192)
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
Kubota LX2620 (A53317)
Water Tank (A61570)
Water Tank (A61570)
