Door Painting
/ Door Painting #1
timswi
Super Member
Beaver County Pa
Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris RZR 900 Trail
Let's preface this by me saying that I loathe house painting..That being said, what is the best method to paint interior Masonite doors?
I don't want to roll/brush. I do have a Binks HVLP air gun for painting cars (I do like that) but I don't want to trash the gun.
Is an airless better, or just dilute the latex and blow it through the Binks?
Any opinions are welcome--Thanks.
/ Door Painting #2
An airless will do a very good job , but I'm not to sure latex is a very durable finish for doors.
/ Door Painting #3
We refreshed our family room a few years ago and the biggest pain was painting the doors and trim. I always like oil based paint for this work, but now everybody wants to sell the latex low VOC junk. The worst part is the paint didn't want to stay wet long enough. There was virtually no time to work it. Going along the trim was bad enough. Trying to get the whole one side of the door without getting into a dry edge was very difficult.
/ Door Painting
Agreed with all of that..Ergo my spraying option.
As an addition, I'm willing to pay for an airless ($400 or so) but I don't want to waste my money.
/ Door Painting #5
I am not sure what kind of airless you are talking about, but my $400 sprayer works fine if you use a minimum of a gallon or a 5 gallon bucket. For small jobs it would be a pain. I got a couple HVLP sprayers for maybe $20 a piece and they paint very good, nice and smooth. They are big enough to hold maybe 1/2-1 pint in the reservoir which is way plenty for a door or two.
/ Door Painting
Therein lies the question...Is it better to dilute the latext and fire it though a $500 Binx and will that work ? I see that you say yes...Dilution ratio, if you have one?
/ Door Painting #7
I have one like this. it will do a great job. Use a viscosity stick to adjust the thinness of the latex paint.
http://www.walmart.com/ip/Campbell-...fault&beacon_version=1.0.1&findingMethod=p13n
viscosity stick - Google Search
If you don't have or can't find a viscosity stick, just use your own judgement. Start with about 1/2 a cup of paint, put a little water in it. stir it up with a stick, withdraw the stick, look at how the paint comes off of the stick. add more water if needed. Do a test spray on scrap, if the paint looks good, paint the door. if it spits and gobs, adjust gun nozzle or thin the paint some more... Just use common sense.
/ Door Painting #8
Buy or rent an airless or use a waterborne lacquer like target em6500 or sherwins aqua-kem.
/ Door Painting #9
An airless is ideal for house paint.
But, you can spray it with a conventional air powered spray gun, for trim work, if you really want to. I do it all the time.
Thin it only enough to get it to spray well. Don't use anymore air pressure than you have to, to get the paint to go on nice.
An HVLP gravity feed gun with a large fluid nozzle, (1.4, or bigger, works best).
If you are spraying white semigloss, it is often transparent. Using satin for the first coat(s), gets you covered faster. Let it dry. Then, follow up with the semigloss.
Chim: There are additives for slowing latex paint drying time down. This one works well: Flood Floetrol 1-qt. Clear Latex Paint Additive-FLD6-4 - The Home Depot
/ Door Painting #11
I tried finding a viscosity measuring devise for a while and couldn't, so I just thinned it down to where it seemed to thin, then it painted quite well. Can go two coats if needed.
If I left it thicker I had all kinds of trouble plugging up and spitting.
Now i see from a previous post I was looking for a viscosity cup, but I wouldn't pay that much anyway.
/ Door Painting #12
All a Zahn viscosity cup is, is a cup with a hole in it.
You still need to know what size hole, and how long the time to empty is, to use one.
That all changes with each product, and different conditions.
But, you can make a cup with a hole in it, and do your own timed test, when you get it thinned to where you want it. So, you can use that viscosity in the future.
You want it just thin enough to spray well.
You can find that with trial and error.
/ Door Painting
Thanks all...looks like using my old siphon gun with lightly diluted latex will probably be the answer...
/ Door Painting #14
Do you have primer gun? That's what I would use.
/ Door Painting
Yeah, that's the siphon gun (verboten by the tree police) and I'd rather use that than my Binks for latex.
/ Door Painting #16
A quality roller goes a looong way if you have everything set up to do at one time.
/ Door Painting #17
If you are painting one door only, why waste time setting up and cleaning out a sprayer of any kind? I'd pull the door, lay it vertical, brush the edges, roll the top. If you don't like the rolled finish, use the brush to make your laps how you'd like, wrap the roller and wet brush in plastic wrap or a disposable shopping bag, wait for that side to dry, then flip it over and do the other side. Two or three thin coats will be a snap, no cutting, taping or drips to worry about, and no temptation to lay it up thick and have a soft cure on it.
/ Door Painting #18
I use one of my good guns, when I need to spray latex.
No big deal, it cleans right up.
/ Door Painting #19
I use my 40 year old Binks #7 and clean up with lacquer thinner. Gun still like new, always clean it so you can not tell what color paint was in it.
/ Door Painting #20
As a person who does remodels for a living, painting doors and trim is something I'm always doing. I have two different airless spray guns. One that I mostly use for enamel. The other is the big one that I put five gallon buckets of paint under it and spray entire houses. The only time I have ever sprayed trim on a house is when it's new construction and there are no floors installed. Then I can spray without taping anything. That's about the only time I consider it better then using a brush. All other times, it's faster and easier to just paint a door with a brush.
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
Stout Buckets XHD84-6 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
Case 1845C Skidsteer Loader (A66285)
Case 1845C...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
