JD 1020 power steering
/ JD 1020 power steering
Hello,
I think I resolved the lifting problem - the leaking PS caused the problem. After I closed the oil pipe with a screw, the hyd pressure problem resolved, the 3 point is lifting as before.
And - the steering is working match easyer - manually, but easyer, probably the oil pressure pressed the damaged PS pieces and this caused the hard working. Sometimes I will open the pipe and let to flow to oil in the PS column - for the lubrication. I will search somewhere a second hand PS column, than I will replace it.
Now I will order 30 litre (7-8 gallons) of JD Hy-Gard oil, than I change the oil from hyd system and also the filter too.
After I refill the system with a good quality JD Hy-gard oil - sholud be spectacular changes of the function of the hyd system?
/ JD 1020 power steering #42
I dont understand something which may be important for the working of the hydraulicView attachment 459877View attachment 459878.
Its about the cover which can be seen on the picture. Piece nr. 3 from the scheme is gasket, on it there is a rectangular hole. When I removed, this hole and under the hole the calliber was also filled with red silicone paste.
When I fixed it back, I did not refill with silicone, I left it empty. The cover gasket now is leaking a little bit, but I will repair it again.
I dont understand the way of the high pressure hyd oil how it is flowing under the power steeling column boreholes.
1. The oil comes from the high pressure oil pump, enters in the PS cylinder, than the used oil flows out across a calliber from the cylinder....
2. Under the cilynder base there are two callibers in the alloy, one off the callibers flows down to the transfer case, the second calliber outlet flows into the cavity under the cylinder.
3. Has to come out but the cover gasket does not let it to flow out....the cover close it.
And than from where does collect the oil in the cavity. In the cavity there is no plug-hole than how does it work??? Beside of this the cavity was full of oil mud and water.
May in the gasket be high pressure? Or only low pressure oil flow. Can also this cause problems?
There should be oil behind this cover. It is low pressure from the steering column. It lubes the parts inside. There should be an overflow hole that maintains the oil level behind this cover and allows the extra to drain back into the transmission for reuse.
/ JD 1020 power steering #43
Thanks for update. It sounds as if you're making progress.
The transmission pump - AR96662 - where can you find an the tractor, backside, on the transfer case? And what is its function - does press oil for the transfer lubrication, or is it feeding with oil the high pressure pump in the front, or what?!
/ JD 1020 power steering #46
Trans pump is located at the frt of trans. case in clutch housing. Trans pump lubes transmission,supplies operating oil pressure for hyd ind pto,hyd hi-lo or hyd reverser then excess oil is sent to ft hyd pump
/ JD 1020 power steering #47
Here is a picture of the clutch housing. Transmission oil pump bolts in back side of the clutch housing (bottom picture) Transmission case bolts to this side. Engine bolts to front of clutch housing
Hi...
I have JD Hy-Gard Oil.... When I will clean the check sump screen - are there any little pieces which can cause problems? Or are difficult to put back to their position?
I think I will unscreew the sump screen, clean it and than put it back, and its ready?!
/ JD 1020 power steering #49
Cleaning sump screen is relatively easy & straight forward after oil is drained except in rare occasions when screen is very,very dirty.
What is the exact function of that sump screen - is it filtering, draining, or thas it colect the oil mud...? Or, does it have another function?
What I can see on the scheme is a part of the filter tube?
Hello,
I have got only a question:is the power stering unit from the JD 1120 fitting to the JD1020 model?
Thanks...
/ JD 1020 power steering #52
Yes the power steering valves should interchange
Hello, Tx Jim.
Somebody offered a manual stering which is fitting to the my JD. If I put on is it going to work as easy as the oil power stering unit... So, will be it going to work easily or not?! Does it worth to change to an manual one - until I will fix the power stering unit or should I replace it only with an other PS....
P.S. Do you know after I changed the hydraulic oil with the new JD Hy-Gard oil, the 3-point lifting system is working match more punctually and easilly....:cool2:
Thanks.
/ JD 1020 power steering #54
Rather than change to manual steering box I'd just cap pressure line to power steering housing and thence have manual steering without changing housing. Manual steering will require more effort to operate than PS.
Now I use without the Oil pressure..so I fouled the Oil pipe and use only manual..but it is working only match hardly... I thing ut is preferabbly tó wait ...an other person maybe will bring an used piece from the West...Germany or other European country... Everything is working so complex...
/ JD 1020 power steering #56
A properly operating manual steering gear will steer much easier than a nonfunctioning power steering gear. Also using a power steering gear without power will soon fail the small needle thrust bearings on the shaft. They weren't designed for the high thrust load for manual steering for very long. Also, with no oil pressure to the power steering system, the oil will soon drain out and there will be no lubrication.
/ JD 1020 power steering #57
jd110 thanks for "heads up" BUT I didn't intend for historyan1975 to operate PS valve in manual mode indefinitely.
Thanks for your advice, JD110...
I know that the PS system is not working perfectly without oil pression and lubrication... For this reason I did not close completly the high pressure oil flow - I just stuck an the aluminum rivet on the oil pipe. In this case alwasy flows a little oil throught the pipe and lubrificates the system.
But - as also TxJim mentiones - I do not intend to operate in this way for a long period. Only until its going to be fixed the problem or I will change with other.
Hello, Tx Jim..
I am expecting an used PS unit from Germany, for my JD 1020. I hope after fitting it - is going to work properly... And also the lifting will be working.
Without oil pressure the steering is working easily only if the tractor pulles something hard - in this case the tow is working as a counterweigt..
Hi...
I found an used PS unit, but there are some problems related to it....
First - it is too long, its longer than the original one, aproximatelly with 8 inch... Secondly - the bottom part is missing....
What should I do? I think I try to fix it at its place... and if it works I let is as it is...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
iDrive TDS-2010H...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
