2032r to replace 1025r
/ 2032r to replace 1025r #1
KYThunder
Rush, KY
JD 5055E Cab/JD 2038R
I have a 1025r and use it alot, mostly grass cutting, but i have found i use it alot more than my 5055e cab. Considering trading the 1025 in on a 2032r becsuse as of now it has no emissions. My only concern is the grass cutting, i mow about 3.5 acres, all flat with little trim. Just wanting a little bigger small tractor while its in the no emission stage as an upgrade but dont want to get too big to mow. Anybody with experience on this id like to hear your experience on the 2032 as a mower, thanks in advance.
/ 2032r to replace 1025r #2
I traded in my lemony 1025 for a 2025. Got tired of the rough, fast idle and many warranty calls. Had NONE on the 4010, and the 2025 is just a bigger engine 4010 with a few extra goodies the 4010 should have had. The 2025 is a MUCH better tractor.
Ralph
/ 2032r to replace 1025r #3
I did what you are considering doing except I did it before the model change. I went from a 2305 to a 2720. It is used for 70% mowing, and the other 30% of the time is garden tilling and snow blowing. I am so glad I did! It needs a little more room but the smoother ride is well worth it.
bigtiller, do you use the lift to set the mow height or did you make a mechanical stop. This is the other concern I have because I dont want a stopper on the lift slide arm setting the height, id think if you raised and lowered it 10 times you would measure 10 different heights even with the stopper. A mechanical stop of some sort would be a must...maybe im wrong.
/ 2032r to replace 1025r #5
My deck is not controlled by the 3ph. It has its own hydraulic cylinder and a third set of mid mount remotes and a bypass switch so the joystick can raise and lower it. This system also has its own height adjustment. It's all factory stuff, dealer installed and works very well.
/ 2032r to replace 1025r #6
Anyone figure out how to get rid of that stupid mow in reverse switch they put on the new ones? That stopped me from buying one right there.
/ 2032r to replace 1025r #7
Don't let that stop you, it is an easy system to override.
/ 2032r to replace 1025r #8
If scalping is not a problem the 72" deck combined with the higher speed in the 2032r should reduce your mowing time. I would not be concerned about the slightly larger size machine because the tires are large enough to spread out the increased weight.
I suspect the slightly larger size will be more useable for your lawn work. I have considered getting one myself but really need to get a much larger field tractor next.
I went to the dealer Sunday and drove the 2032R and the 2025R. Not much different in the 2 other than the 2025 retains the deck height lock knob. Only thing stopping me from pulling the trigger on the 2032 is using the 3pt hitch stopper to obtain the cut height, maybe Im overthinking this but I can't see that being as accurate as some type of mechanical stop. Anybody out there mowing with the 2032R and the 3pt hitch lift give me some reassurance?
/ 2032r to replace 1025r #10
Can't help you on the accuracy of the 3 point, but the JD position control on the 3 point seems to be pretty good. The deck height knob isn't a perfect solution either. It isn't a continuous adjustment - it's a series of notches. The notches are quite far apart, especially if your lawn isn't a golf green. On my 2320, I can only really use two of the settings (plus the lock up - 5 to 6 inches for the really rough stuff.) Overall I'm very happy with the machine as a mower, but I would rather have a continuous adjustment.
/ 2032r to replace 1025r #11
The 3ph control on the 2025R and probably on the 2032 are pretty much exactly the same as on the 1025R. You get really good control of lift position.
The 2025 and probably the 2032 also have multiple positioning holes on the lift arm. I have to move the lift arm position when going to the bush hog, to get a decent lift height on it.
On thing on the 1025R that is better is the startup of the PTO. It's very gentle on the 1025R but is more jolting on the 2025R. The very severe jolting start on the 4010 is likely what caused failure of the donut joint in the driveshaft on it.
Ralph
/ 2032r to replace 1025r #12
Chiming in just to follow this thread. Considering a similar upsize.
ovrszd... I think you should go trade then you can answer all my questions,then I will decide whether or not to trade...I would really appreciate it. :laughing: I am very close to pulling the trigger, told him to hold it and I would let him know in a day or two, he has quoted me $1,000 less than anybody, 2032R, fel, 62" mmm for $22,500. As an fyi, anybody considering a 2032 as well, whats available now have no emissions, when these are gone the new ones will have emissions (assuming a dpf).
/ 2032r to replace 1025r #14
Is there still a hydraulic lift option for the mower deck on the 2032R?
I had a 2720 with a hydraulic lift for the mower deck. It had a height adjustment knob for the mower deck on the left fender.
Yes that is available and I believe its about $1,000 option.
/ 2032r to replace 1025r #16
I don't want to hijack this thread, but I am considering a similar move. Could someone please explain to me what "emission" means in this context? How could a tractor not have any emissions? Is this some new environmental legislation coming through the pipeline?
SI2305
/ 2032r to replace 1025r #18
Think the 2032 is a tier 4 "emission control" tractor. My 2025 is not, because it is just below 25 hp. Only thing on it that appears to be different from what was on my 4010 is the 1,300 rpm idle speed vs. 1,000 for the 4010. (Haven't attempted yet to change the 2025's idle speed. On the 1025, it was near impossible, and it was a ridiculously high 1,650 rpm, and ROUGH.)
Ralph
/ 2032r to replace 1025r #19
HEY, I'm waiting on you!!!! :D
The 2032's on the lot now may say tier 4 but so will the 1025, doesn't mean it has emissions equipment, just means it meets tier 4 requirements. Yes it is suppose to be 25 hp and less but for some reason the 2032 he has does not have a dpf, I varified this myself on his lot. He also contacted me today and said because I waited, another $200 rebate came in....its making it real hard not to just go ahead and trade!
FIFTH WHEEL ATTACHMENT PLATE (A60736)
FIFTH WHEEL...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
KUBOTA L47 BACKHOE (A62129)
KUBOTA L47 BACKHOE...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
