05 duramax batteries getting drained
/ 05 duramax batteries getting drained #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
So I go to start my truck lately (currently it's just a farm truck) and every other day batteries are so dead that it won't roll over. We can't figure out what has been causing it. The batteries are only a few years old. Alternator less then 8 months.
Truck has a front snow plow, salter and back up lights that ain't hooked up yet. Salter is unplugged because the plug broke on the truck end and plow hasn't been hooked up in over a month because the tranny cooler is bad. So nothing aftermarket is running. The driver door does sag but you can lift it and it shuts just fine. We can't figure out what's going on. Dome light has a timer but it didn't go off last night when I didn't shut a door hard enough but even though the door wasn't shut the dome light should have gone off. Went and reshut the door and it went off.
The truck has around 427,000mi but nothing has acted up like this before. You guys got any idea.
Now I have to go start the truck every morning and run it for a while to keep batteries charged. Not a big deal but I shouldnt have to do it
/ 05 duramax batteries getting drained #2
I would take the batteries out and have them checked as some stores or garages can do that, or just take it down. They may be able to put a load test on it while in the truck.
For me, it sounds like you have a bad battery, or two. One may be bad and drain the better one.
If you have the batteries charged and the cables disconnected and then when you hook up a battery if you get a few sparks, that should tell you if there is a draw downstream.
/ 05 duramax batteries getting drained #3
If the batteries check out look for loose ground wires. I chased a drain for months on my 04 Suburban. Are any of the gauges reading differently?
I found my drain the switches on the driver door. The switch kept making contact inside activating the computer and would drain the battery in less than 10hrs.
I hope it is the batteries but my 03 Trailblazer also had electrical problems that took a long time to track down.
/ 05 duramax batteries getting drained #4
I believe the GEM module or whatever it's called has been a issue. Look into that.
Chris
I'll see. Probably won't take them out or to a shop. These Chevrolet batteries have those ends that ain't the easiest to get into and Thier positions are under cross supports. And the truck ain't leaving the farm unless it's a emergency
/ 05 duramax batteries getting drained #6
OEM battery charging isolator hooked up ok and diodes not shorted or 'open' there? Could be that only one batt is being charged, and we are told that connecting batteries in parallel without an isolator can shorten their lives considerably, esp if one is aging out of sync with the other.
I'm South of Sand Lake and this Winter (last two) had me scrambling to keep batteries topped up with the temp fluctuations. Snow equipment batteries get the worst shake during the Winters we use them the least. (light snow 2 yrs in a row)
Last week my (road) truck wouldn't start (temp in teens). Starter terminals were badly corroded and freshened-up when I replaced it. My car would only 'click' Thurs morning (~4^ F) but was ok by mid afternoon and temp up into the 20s. :confused: A dome light/timer can draw plenty o'night in the coldest weather.
Even HFT's $10 DVM has a 10A 'transit' (w/test lead socket) for measuring DC amps. (know/learn how to use it) Use such to measure current leakage with everything turned off and connected in series to each battery in turn at the + post. Don't ignore ground connections (engine/chassis/body) when analyzing starting issues. Good luck!
Only thing that I am thinking now that I am thinking hard about it is there is a ground cable from the hood to the truck that is cut. I'll replace it tonight,and see what happens
/ 05 duramax batteries getting drained #8
I would also test the alternator. Could have a live field.
Chris
/ 05 duramax batteries getting drained #9
separate the batteries and test them. charge them. put a meter on them and if there is a draw you will see it. then start pulling fuses until the draw disappears. that will narrow down the circuit that you will need to inspect
/ 05 duramax batteries getting drained #10
i have an 01 duramax, and a few year back i had same problem. they were some auto zome or walfart or something. batteries checked out good. on one of the diesel sites for duramaxs said just replace batteries, both at same time. did that with good batteries that you can get from a truck repair shop that handled interstate batteries and fixed the problem.. just couldn't believe it was a couple of year old batteries. fought for a couple of weeks. new GOOD batteries have lasted almost 6 years now. if you pm me i will give you the duramax sites. they have been a great help. i even replaced alternator and that wasn't it.
/ 05 duramax batteries getting drained #11
Gm is notorious for their wake up computers.
Anything that may draw current will wake up the computer running the system for 15 minutes or so till it shuts down then it will do it again all night.
I had an 03 gas and an 06 diesel that just the radar detector caused them to wake up all night killing the battery slowly.
Anything connected had to be wired to ignition only or straight to battery.
If it's just a farm truck and you can't find the problem a battery disconnect can be an easier fix. Just use it when you use the truck, otherwise it's completely disconnected from the system while not running.
/ 05 duramax batteries getting drained #13
I had a similar problem with my 04 Silverado.
I put a test light between the battery and cable end and light stayed lit. (cable disconnected)
I started removing fuses until the light went out.
The problem was the passenger seat. I cycled the seat controls a few times and all was good.
Have ran it some into town and haven't noticed any battery problems again. Will check today. It hasn't been ran all weekend so.
But it stopped right after I posted the thread. Who knows it's a old truck
/ 05 duramax batteries getting drained #15
Sounds like a loose ground wire.
Well no more problems. I don't know if it was that I had pb blaster in the plugs for the snow plow or not but that is the only thing that changed besides the plow greeting hooked up and staying on currently as I have no reason to unhook it.
I also replaced the one wire that was broke but that was just a ground wire for the hood to front clip.
At least it's not draining soo in not too worried
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
Club Car (A59231)
Club Car (A59231)
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
