Problem starting 5045d John Deere tractor
/ Problem starting 5045d John Deere tractor #1
kpack
Bryan texas
5045d
Hello I posted this on another thread the other day but want to start my on. I tried to start a lady's tractor the other day
here in Bryan tx it's a 5045 d. It was about 45 degrees and was really hard to start. I've driven it in the summer starts and runs great. Yesterday I started trying to figure out how to preheat but got nothing so I started searching the net and it lead me here.
I've tried pushing the key in on run no joy from search looks like that's a option the intake preheat. I don't see how they would send a diesel out without something on it for cold starts.
Looks like from what I've read everybody likes the coolant heater better than the block heater or intake preheat.
How does the coolant heater work once you plug into 120 electric ? Does it circulate the coolant while its heating it ? I want to install the best thing for the lady.
I'm going back to her place to look for the block heater or coolant heater or intake preheat now that I know what I'm looking for.
Ok I have since decided there's no preheating on the tractor so I went to jd here in Bryan and looked at the intake preheat setup it was 122 without tax. No colder then it gets here that's what I will get for her.
Right now one of her horses has a eye problem and her border Collie dog had his hip dislocated while working cattle so I'm going to wait for her to get over some that other stuff.
/ Problem starting 5045d John Deere tractor #2
Is 40's the usual cold there? If so, the in line air pre-heat should be sufficient and the quickest method, no need to plan and plug in hours ahead of time. Although block heaters and coolant heaters take much longer, heating the block and oil is much friendlier on the motor. But with good oil, I doubt it makes difference over life of motor. In the meantime, until you decide on which, some people here would suggest using her blow dryer to heat the intake air.
I went with the block heater and preheater. Use both when it's below 35-40 ( depending on how much pre-planning time I had), but just the preheater if it's above.
It can get in the high teens but not for long and not this yr.
/ Problem starting 5045d John Deere tractor #4
Check to see if someone has disconnected the thermistor at the thermostat housing or loosened the connection at the pump. They control the cold start advance on the pump. These often fail and cause the fuse to blow that powers the shut off solenoid, causing a no start situation, so the simple solution is to disconnect them.
/ Problem starting 5045d John Deere tractor #5
I have read your comments added to the other thread and peoples responses. My tractor also has the 3cyl engine. I have installed the coolant heater, leaving it plugged in for 1 hour and an outside temp of 30 it will warm the engine up about half way. Looking at JDparts the heater is the same, but the installation location is different.
I use the JD fuel additives, there is a winter ty26787 and summer ty26784. I included a link at the bottom. Since using the additive, NO smoke at startup and literally just a flick of the key to start. Both are cheap in cost and suggest trying them. I have no experience with other brands. Leaving the range as well as the gear in neutral it starts up easier. Have you checked the fuel filter to insure there is no water in the fuel. For me with the fuel tank full and filling the filter with fuel before putting on, I have never had to bleed it to start it.
Your other post indicated it starts hard even when warm outside, if I recall correctly. If I recall correctly, there could be a fuel delivery problem. I believe this tractor as mine has no fuel/transfer pump. So a hole in the fuel line, filter needing replaced, tank not venting correctly try leaving fuel cap off and looking at JDparts there is a straining at the fuel tank part # SJ10012.
You might look at greenfarmparts.com for parts and sometimes they have sales.
I second Tractorboy88 suggestion. I have included a picture thermostat
I would start with the simple things before attempting to change the timing.
Here is a link to operators manual, if you needed to see it.
John Deere Ag - New Equipment: Technical Publications - Equipment Search
https://jdparts.deere.com/partsmkt/document/english/pmac/5496_fb_SummerWinterDieselConditioner.htm
/ Problem starting 5045d John Deere tractor #6
I live near navasota with my 5055. It'll start quick and easy at 30-32. If you turn the key on, and then push it in, you should hear the buzzers quiet down a little as there is a draw on the battery. I don't know what it's heating, but it does smoke a little less than not using it. Check the condition of the battery.
Brett
It does not have the preheat when you push the key in , the key will push in on run but does nothing because it's not there , I went to jd and they pulled up the a picture of the preheat kit so I know what it looks like and it's not there. I will check the other stuff on the pump your talking about. It may be the weekend before I get there.
When I say it starts easy in warm weather I mean 85 and above . I only drove it last summer a couple of times before now.
Jd5210 posted a picture of the advance sensor . Is that what your referring to ? If the fuse blew where would that fuse be ? I saw the fuse block for the tractor but do not remember a advance sensor fuse.
I will check the shut off solenoid fuse . Thank you fellows for helping me out.
/ Problem starting 5045d John Deere tractor #12
If the fuel shut-off solenoid fuse was bad it would not start at all. What is being suggested is to check if the temperature switch part # is RE503242 is plugged in, this is part of the cold start advance. I have attached a write up on how the cold start advance works.
To comply with the exhaust emissions regulation, the timing of injection pump should be around 6 to 9 degrees before TDC. These timing values do not allow proper start-up operations when engine is cold. To ease engine start-up, a cold advance system gives to the injection pump a temporary over-timing.
When coolant temperature is below 50 C (122 F), the solenoid valve is activated and opens the cold advance circuit.
  • Timing_Advance.pdf
Thanks jd I may get to go look at it tomorrow afternoon after work.
Is there a place here on the forum that tells how I post pictures ? Every site seems to be different.
When I hit reply to thread I'm not seeing manage attachments
This is a picture I took the other day not knowing we needed to see this part. I'll get better pictures when I go back.
/ Problem starting 5045d John Deere tractor #16
Kpack , I believe that's the sensor connector right behind the injection pump in that picture, but the picture doesn't show the thermostat housing very well.
I'll get a better picture this afternoon.
/ Problem starting 5045d John Deere tractor #18
I think fuse is in fuse block but if this fuse is blown engine will not start
/ Problem starting 5045d John Deere tractor #19
The thermostat sensor is on the same circuit the fuel shut-off solenoid is on.
Take a look at the pictures I posted in thread#5 and you will see where the thermostat is located, along with what it looks like.
In the timing advance pdf thread #12 in the picture of fuel injection pump the connector labeled B is where the thermostat plugs in.
Hope this pulls it all together. Again if the fuse is blown it will NOT start as the fuel shut-off solenoid is closed.
.i went to turn screw on the bottom of fuel filter to drain any water . I barely cracked it with it running a soon as it started dripping it died. It's low on the fuel gauge but she says it has fuel. I've bleed the fuel filer and pump for air as manual says and have plenty of fuel coming out. Now I can't find in the manual about cracking injector lines at the block like I do my tractor. :eek: no fun right now I'm going after a can of diesel.
It says something in the manual about the pump prime button on top of the fuel filter the black round button there. image.jpegimage.jpegneeds to be left down but I don't see how I could lock down.
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
Hensley 16in. Bucket with Teeth Excavator Attachment (A64194)
Hensley 16in...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
Aluminum Alligator (A65583)
Aluminum Alligator...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A64557)
2019 Mercedes-Benz...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
