welders welders welders
/ welders welders welders #21
Hit the thermal overload constantly with a Hobart Tigmate (econotig) transformer based welder. Haven't hit it since getting the replacement, but at 310A for 20% duty cycle my gloves run out of duty cycle long before the machine does. :laughing:
Seriously, 20% is nothing. There's a reason all the bigger machines are amperage rated to where they're 60% duty cycle. You still have 4 minutes out of 10 for arc off, but with a 20% you can only run 2 minutes out of the 10 minute window. 12 minutes useful arc time in an hour is not a lot. Even for a student it's downright painfully slow.
+1
Well stated.
/ welders welders welders #22
20% duty cycle means you can weld for 2-minutes in a 10-minute time frame. :thumbdown:
Well that IS what it means, but i think TBN members want to know "is a 20% duty-cycle sufficient?"
Until I read or hear of credible reports saying 20% is NOT enough, I'm still the expert. Not because I "know", but due to LACK of credible info that 20% is insufficient (for 97% of TBN welder-purchasers).
Thomas why don't you ask those questions and become the "duty-cycle expert"? Members come to this forum for sensible advice - if you have it, post it. I'm a persistent mofo but easily de-thronable by someone who actually "knows". I was thinking of Mark at Everlast but even Mark won't flat out say what % a TBN purchaser should look for. Clearly TBN Members want to know.
If you can afford more than 20% then by all means hand it over to the salesman, he may have mouths to feed! At least your money's feeding local kids and you come home with the jewelry. Thats how I buy in some of my other hobbies. And I DID overspend some on my MultiMatic200..... :D
My MultiMatic200 is sort of a "20% machine" but in the midrange it's like 40-60%. Thats how it will be for most TBN members. Buy a 20% machine and you will never have a problem.
/ welders welders welders #23
Oh, and my Hobart handler 125 is a dog and will turn itself off if you run it too hard/long. I found that out trying to seam weld the perimeter of a intrusion resistant vent on the side of a cargo container. It was a rude awakening going back to a 120v machine from my Miller Invision 354MP that'll run 100% at anything under 25V.
Duty cycle is as relevant here as PTO horsepower, or hydraulic system flow and pressure. Anyone who thinks otherwise just doesn't know what they're talking about. If you need 2900psi to lift the loader at it's rated capacity, but you only feed it 1500, you're going to have problems. If your tiller needs 5hp per foot, but you only give it 2, you're going to have problems. If your work needs full rated power to get the weld hot enough, you're going to be thumbing your exit for a long time if your welder can't keep up.
Now if you want to get esoteric and talk about MIG guns or TIG torches, those are rated at 100% duty cycle and I'm a fan of not using a 300A gun if you don't have to. The last shop I was at they had 300A guns on 300A power supplies, but were only running about 150A (pulsed - where they had 100% duty cycle ;) ). We could've had 200A guns and saved 50% of the weldor's fatigue without ever thermally stressing the guns, but someone in purchasing had their head up their butt and everyone on the floor suffered.
/ welders welders welders #25
OK you two guys are what the 3% in 97 is for! The other 97 can't outweld a Hobart 125, they don't have that many projects. Hey I'm quite the stud in my memory too. Except I've forgotten how long ago that was. :D
Hey wait a minute if you guys are doing that duty-cycle we wanna see the projects! Thats what the forum wants.
/ welders welders welders #26
The problem with a machine that's nameplate rating is derived from a 20% duty cycle is that they have very low output at a useful run-time interval. When you have a machine that starts out at 20% at 180A, when you get down to 150 you might be up to 35%, drop down to 125A and now you're up around 45%, and by the time you reach 60% you're sitting at a whopping turd of a 90A output.
Do you know what 90A on a MIG will safely weld? It's the bottom limit for 16 gauge! 1/16".
So if you only do really light stuff and it's 1/8" wall, you still need 150A.
/ welders welders welders #27
Completely agree - good analogies. I switch to a 17 tig torch for little stuff instead of a 26.
I have a 120v mig on the shelf that rarely ever gets used anymore. Turns out switching back to it I completely forget about trigger time and it gets hot and starts welding crappy.
Fortunately the mig gun on my millermatic 210 is small and light enough to not really notice it - but a 300 amp gun is kind of heavy and would be annoying to wrestle if not needed.
/ welders welders welders #28
I've said it before, and I'll say it again! When it comes to Mig welding there is no substitute for power.
Here you guys be the judge.
/ welders welders welders #29
I've had a 300A gun on my steel rig since I got it, and upgrading to a lighter one has been on my mind ever since. The thing holding me back is that I have so many of the darn consumables for it, that I don't want to make them all worthless. :)
I run a #20 water cooled for the TIG with a gas lens and I don't find the size is a problem at all 80% of the time. The last few days I was between 150-250A depending what I was doing, so having that range is nice. My water cooled torch is far more flexible than the air cooled 150A was. I didn't even put up with air cooled when I was still learning. Those things are unwieldy.
/ welders welders welders #30
I had this same discussion with my crews when I was in the marine construction business about 10 years ago. Everyone wanted a 250 amp Bobcat (or bigger) on their work boat. I started paying attention to what they were doing and noticed that 90% of the time they were only running about 120 amps using 1/8" 7018. Every now and then they would use 3/32 or 5/32 but that was it. Machines never went over 160 amps or so and that was rare. I dropped back to a smaller Bluestar machine that weighed quite a bit less, cost less, and burned less fuel and it did everything they ever needed. I still have a little portable multiquip welder that is only 135 amps but runs 1/8" 7018 just fine and weighs 100 pounds while burning little fuel. I think having a big amp machine is more "cool" than necessary for most people who likely do not have the need or even the welding rod to go over 200 amps but tell you that you need a 200 amp machine with a high duty cycle for some reason.
I have a PA-300 but I almost always just use my ESAB 161 because it runs what I use (3/32, 1/8,and 5/32) just fine. It's nice having a big machine but the only rod I have that requires more than 200 amps is cutting rod so in reality I have no use for welding anything over 200 amps.
/ welders welders welders #31
You can always turn it down, but you can't turn it up any farther than it'll go.
Seems like the money part is where folks get hung up. Good welders aren't cheap. Even the cheap welders aren't all that cheap when you start getting into ones that will weld serious thickness'. If you're building yard art, you can probably get by with something that doesn't have much arc-on time available. If you're welding trailers or buckets or anything with some seams to it, you're going to find out how we're not lying when saying you need to be able to keep putting out the juice more than 2 minutes at a go.
I got my handler 125 as something to do little stuff up at the property without having to haul my big welder up there. I figured it'd be slow, but I didn't expect it to be as slow as it was. Will that turn out to be a good purchase long-term? That's yet to be seen. For now I can run it off my 5000W genset, so that's a plus.
/ welders welders welders #32
SMAW is a different animal. I've wondered if I would've been better off getting a little inverter stick power supply instead of the handler. Both are gasless in my application and I can run either process although I'm not a fan of the smoke from stick. FC seems to be a little less smoky which makes sense since it's also a bit less heat too.
/ welders welders welders #33
I love my little inverter. About the size of a lunch box.
/ welders welders welders #35
Many years ago I bought a used Millermatic 250, just looked in the book for the duty cycle and it is 40% @250 amps, 60% @200 amps, and the 100% line runs off the chart at about 150 amps. In my home projects, I've yet to run it hard enough for the fan to kick on, much less come close to the overtemp light. But I guess if I ever need to stitch a piece of railroad track to a truck frame, I won't be able to do it in a single go.
As for my Tigwave 250, I'm guessing that it has a higher duty cycle than the electric meter, which would probably spin itself out of the box if it ever ran wide open.
/ welders welders welders #36
Jim how many inches is 2 minutes welding with your Hobart 125?
/ welders welders welders #37
From my understanding most of the machines will not necessarily shutdown at duty cycle limits. As a result you may very well be able to weld beyond said limit. The problem is the long term effects that exceeding the limit may have on the machines internal components and failure rate.
Whatever works for you in your application is what is right for you to buy and own. Don't try to tell others that only you are right. Explain the issues and the pros and cons but avoid dogmatic statements that everyone needs to operate the way you do.
There are folks on here that never weld more than an inch at a time and less than a minute total in 10 minutes. There are others that weld much more. I know that my welding needs and habits have changed significantly as my skill set has changed and my needs have changed.
The discussion of welding until the unit shuts down (well exceeding the DC in almost all cases) reminds me of the discussions on what oils to put in chainsaws both mix and bar oils. It is your equipment. Treat it as you want to treat it. I respect my equipment and I value its worth to me and will not knowingly abuse it or take it beyond its limits as I don't care to spend money and time to repair the damages. Other folks look at things differently.
If you are a person that accepts the added wear and tear that exceeding the DC puts on the machine before it shuts itself down (if it even does that, not all machines will) that is fine. That is one way of operating. If others think differently that is fine. The one mode is just as wrong for one group as the other mode is for the other group. I know which group I fall into. For the price difference I will almost always buy the machine that limits me the least (assuming I can afford that option).
/ welders welders welders #38
Maybe 4? Took forever and a whole lot of swearing and shut down time to get these done. 8x8" 1/16" plates.
So much so, that I did them on two different days. Would've been a half hour project otherwise.
Even on the container, the handler was colder than I wanted it. When you turn up wire speed on my big welder, it turns up the heat. When you turn up the wire speed on the handler it just makes the arc suck more. :lol:
/ welders welders welders #39
Jim if you decide to buy an inverter SMAW machine. I have my brother-n-law's Everlast PowerArc 200ST. This welder is very impressive with 6010. I'm starting to believe it will stack 6010 better than my Lincoln V350-Pro. And right there with any of my Lincoln SA-200s.
Mark with Everlast takes very good care of us here!:thumbsup:
POWERARC 200ST - Stick Welders | Everlast Generators
/ welders welders welders #40
but hokayyyyy..... Furu methinks you take forum opinions a little too seriously. You only have to follow my orders if nothing better comes up. :laughing: But nothing will. This will spiral off-topic before anything definitive comes up. It always does because duty-cycle is like chainsaw size, pickup size. Any size you can imagine on the internet - size is king!
Jim 4 minutes would be bothersome. Maybe it was due to extension cord? Insufficient generator? If you don't supply it with sufficient power, the volts go down and the amperage goes up and I suppose that can cause problems.
These welds, all you can see in this pic, 167 inches were done continuously in 25 minutes on a 20% machine, (on generator) continuous welding not shutting down once. It's a LOT more, and higher heat than those 8x8" 1/16" thick plates. BTW 1/16" thick has a known amperage requirement that is significantly below the Hobart 125's capabilities. You might consider othee deficiencies, that 125 is a good machine. I had a Hobart 115 (or 120?) for a few years in the '90s (pre-internet).
456421d1454970266-welders-welders-welders-167-inches-welding-jpg
I was wiped out though.:shocked: It would take a foreman cracking a whip to get me to do that again.
....no foremans here i'm pretty much unemployable at this point :D
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
