Good morning!!!!
   / Good morning!!!! #41,852
Nah. What you're wanting to do isn't too complicated if you take it a piece at a time. But first a question:
Will you be activating the turn signals, brake lights, and headlights when the wagon is horse drawn?
The headlights only when being horse drawn, not when towed. Brake lights will be flashers only with horse, no turn signal with horse.
Brake lights, turn signal, and electric brakes used when towed, just like any other trailer
I would like to put switches on head lights, and flashers. Brakes are used to slow horse down, kind make it work harder and tire faster so cooperates better, not to stop the trailer. Harness and horse do that unless you live where it is hilly. I don't. Not worried about drain on battery for it won't ever get used but a few hours at a time. Parades, hay rides, and fun around the area. No trail blazing or long distance camping. So I will charge the battery as I need it.
Brakes are exactly what you said, axels and hubs are trailer type, P235-65/15 tires. Sewing machine doesn't hum with no pressure, but spins faster as you apply more pressure, why I thought it would make a good brake pedal.
Was going to run wires from battery to termination blocks with a kill switch between, from the blocks to switches to corresponding items. Then wire the trailer plug like any other trailer tying in the lines in between the rear light assembly's and termination blocks (scotch loks, gotta love em). With the battery kill switch in the off position, and the truck hooked up, will I get any feedback to the blocks? And will that hurt anything? And where do I tie in the brake line?
   / Good morning!!!! #41,853
We should let Mexico keep the name. After all we did take almost half of their country.
Using that argument, it should be Gulf of England.
At least we had the good manners to pay the French.
   / Good morning!!!! #41,854
The snow does not get heavier!
I am so sick and tired of hearing all the doofus news reporters saying that. It settles, it get's denser, but if you've got a 2 foot x 1 foot x 1 foot stack of snow it weighs the same as it packs. It may start out at 14 lbs in 2 cubic feet, pack down to 1'x1'x1' but it will still weigh 14 lbs.
The big problem comes if you get melting on top with refreezing. You can get a significant ice layer built up. I can remember ice skating on the hillsides in Vermont on snow over a foot deep, but with a real thick crust of ice and lots of dense snow underneath.
And that is a real pain to shovel.
Tell that to your snow blower or tractor, or back. While a given number of snowflakes may not got heavier, the bite your snow blower gets does, as it settles and packs. While improperly stated, I'm sure that's what they mean by getting heavier.
   / Good morning!!!! #41,855
Neighbor just brought over a warm homemade 🍎 pie to thank me for pushing out their drive.
   / Good morning!!!! #41,856
Terminology help needed.
What do you call the switch on a pressure washer that is connected right before the hose connection and turns the pressure washer on when the trigger is pulled and shuts the pressure washer off when the trigger is released.
That automatic switch is sticking bad, the machine cuts off and will not come back on until I unscrew the switch and pull the plunger out. I want to get a new one but I can't seem to find it using the phrase "automatic pressure on/off switch". I think I'm using the wrong words and the manual is no help.
   / Good morning!!!! #41,857
Comparing a shovel full dry to a shovel full of wet, wet it is much heavier. Yea, not same density blah blah blah..but who gives a ...
   / Good morning!!!! #41,858
Don;
Replacement guns are cheap at Northern Tool and other places. Your gun is probably stuck with minerals in the water?
   / Good morning!!!! #41,859
Glad to see the engineers.
   / Good morning!!!! #41,860
I think it's called a "doo-hickey."
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
JLG 1255 Telehandler (A51039)
JLG 1255...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
