Milwaukee power tools
/ Milwaukee power tools #61
I've been a devout Milwaukee fan over the years. I used to have a 12V NiCad driver/drill that I used the snot out of. I finally broke it when it slid off a metal roof and landed just right, breaking in two at the handle. I replaced it with a Milwaukee 18 volt lithium model that turned out to be utter junk. The transmission went out in it and I'm stuck on the slow speed. I then splurged and bought one of the 18V Milwaukee fuel models. It's great but has a few knocks. The first knock is the quality of the chuck sucks and won't hold a small drill bit tight enough once the chuck starts to wear. In addition, the chuck doesn't have pronounced enough knurling to let you get a really good grip to tighten it. The second is that it has no on board storage for 1 or 2 bits. I like when they have a place to keep a spare reversible flat/Phillips bit somewhere. Otherwise I love it. I'm getting ready to get a cordless angle grinder.
/ Milwaukee power tools #62
My favorite went to an also ran over the last 35 years...
/ Milwaukee power tools #63
I use to buy Milwaukee tools and loved MOST of them, BUT when they went to making their tools in china, I pretty much gave up on them!
SR
/ Milwaukee power tools #64
SR
I'm not confident that there's a cordless tool that isn't made in China. Is there? Milwaukee went to the dark side for a while but it seems like they've started to improve again in the past few years. Are Makita made in Japan? Makita always made some good tools. Porter Cable has turned into cheap junk.
/ Milwaukee power tools #65
I noticed that the latest iteration of the M18 finally has the features of my beloved M28 only with smaller battery and the same price of $399.00.
/ Milwaukee power tools #66
BUT, it's "Milwaukee", they always made some of the BEST industrial tools, and now they are pretty much down to home owner grade!
It just grates on me! lol
SR
/ Milwaukee power tools #67
My Milwaukee Magnums were my favorites... extra brushes for quick field repair and easy to replace cords... made in USA
/ Milwaukee power tools #68
Geez ANOTHER one day only sale
Milwaukee 18V right angle impact driver 2661-21CT
The M18 kit charger and one compact battery is less than the everyday price of the bare tool and for the exactly the same price as an M12 bare tool right angle driver.
Right angle impacts are unique tools and not everyone needs one.
The gearbox head is movable and has two positions on the 18v models
Milwaukee has 3 different models. They offer some torque advantages over using a right angle cordless drill or a cordless ratchet in certain situations
/ Milwaukee power tools #69
MY Magnums are great too, well, all except the "Hole Hawg"... I think it took me about 10 minutes to blow the gear box in it! I took it back and got a REAL angle drill! (Elu)
Too bad the Magnums aren't the drill they USE to be!
SR
/ Milwaukee power tools #70
MY Magnums are great too, well, all except the "Hole Hawg"... I think it took me about 10 minutes to blow the gear box in it! I took it back and got a REAL angle drill! (Elu) Too bad the Magnums aren't the drill they USE to be! SR
They must have really cheapened down the hole hawg. My grandpa has one. That thing is built like a tank. If it binds it will break your arm off or twist you around in circles. If you have it braced against a stud it will knock it out of the way and then break your arm off. I have a new Dewalt version of the hole hawg. It has bind up control which works great.
/ Milwaukee power tools #72
The problem with many of the Mil Hole Hawgs is, IF the bit get's caught and jerks, that half turn of "slop" in the spindle shock loads the trans gears and they shatter... That's exactly what happened to mine...
Steady torque, they can take that...
SR
/ Milwaukee power tools #73
The problem with many of the Mil Hole Hawgs is, IF the bit get's caught and jerks, that half turn of "slop" in the spindle shock loads the trans gears and they shatter... That's exactly what happened to mine... Steady torque, they can take that... SR
How do they get any slack to jerk? The toque already being applied to the bit should have already taken up the slack. I have never used a drill, drill press, milling machine, and multiple metal lathes that didn't have some slop in the spindle. I hope you are exaggerating about the amount of slop. I bet if you jack up your tractor and manually turn the wheels it will have some slop too.
/ Milwaukee power tools #74
At that same old time Ace the closed up I went to their clearance sale and bought a brand new in box Hole Hawg for $80... guessing it's been on the shelf 20+ years because the box has yellowed.
Never tried it so no idea if it even works.
/ Milwaukee power tools #75
My girlfriend didn't buy one for me. I had to buy it myself. But what a saw... I haven't used my corded circular saw since I bought my cordless one.
Same here. I thought it would be a 1 or 2 cut wonder, but it's not. You can actually do some work with it.
/ Milwaukee power tools #76
Dang, double post!!
/ Milwaukee power tools #77
When boring big holes for plumbing or electrical, the bit/hole saw can jerk... And, NO I'm NOT exaggerating about the amount of "slop", go check one out for yourself. Last one I checked still had it...
I BET you that IF I jack up every tractor I own, I won't be able to turn the rear wheel half way around to take up the "slop".... If it did, that would mean something is VERY wrong!
Rather than doubt me, go check one out for your self...
ultrarunner can go out and check his, and report back here...
SR
/ Milwaukee power tools #78
Yes... it might be on the weekend... my job box is at my brother's place.
/ Milwaukee power tools #79
When boring big holes for plumbing or electrical, the bit/hole saw can jerk... And, NO I'm NOT exaggerating about the amount of "slop", go check one out for yourself. Last one I checked still had it... I BET you that IF I jack up every tractor I own, I won't be able to turn the rear wheel half way around to take up the "slop".... If it did, that would mean something is VERY wrong! Rather than doubt me, go check one out for your self... ultrarunner can go out and check his, and report back here... SR
The bit can jerk, but the slop in the gears should already be used up. 1/2 turn of slop is pretty pathetic. If you jack up your tractor it won't have a 1/2 turn of slop, but it will have some. If you were pulling a box blade and it suddenly snagged a stump, did the gears jerk? No, because the gears were already tight. The only way to jerk the gears would be to be rolling backwards and pop the clutch. I don't have a new hole hawg to check. I can go check the old hole hawg, the or a fairly new Milwaukee magnum drill, and my Dewalt copy of the hole hawg and non of those have anything close to 1/2 turn of slop.
/ Milwaukee power tools #80
You like to argue, but just go check the hole hawg and get back to us...
SR
2016 CHEVROLET TAHOE (A59823)
2016 CHEVROLET...
CFG Industry ECAG QA Auger w/ Bits (A60463)
CFG Industry ECAG...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2018 Bobcat T770 (A60462)
2018 Bobcat T770...
2014 18ft. Top Hat T/A Trash Trailer (A60352)
2014 18ft. Top Hat...
