I-beam size 30' span
/ I-beam size 30' span #41
I had to take a 3rd, 4th look at the pic to see what you are talking about. Wouldn't the truss lose a lot of it's span strength hung like that??
I've been here 15 yrs, the house almost three times that. Had to look up at the ceiling(a) in several steel buildings (Parker store, tooling house, recycler) with flat roofs to see steel versions hung from the top chord with nothing fancy on their ends either. (much like my wood trusses) This a one-story house w/trussed roof so no extra loads (2nd story walls) mid-span anywhere.
Nothing heavier than a piano or small gun safe above, but no unevenness when placing furniture against a wall, so no floor-sagging at truss ends ever noticed. Can't imagine how anchorage embellishments would affect o'all strength, deflection, etc but I wondered the same thing when I moved in. btw, fella who built & lived here first 20 yrs weighed ~375lbs and no cracked plaster to patch even today. I can show it, just can't explain it better. (usually the other way around :rolleyes:)
Mentioned a basement I-beam we wrapped in oak for looks. 'Liquid Nails' on 2x6 blocks to 'fill' web to flush & oak-veneered plywood glued/clamped to them. Cover & trim cap spot-glued to bottom of beam has never sagged or came loose. (15 yrs, now) Makes me think nailing atop steel beam not necessary to handle a compression load.
I came near to removing two posts in my previous home, but didn't want steel beam below joist centers. (Joists were NOT o'lapped at center of house as should be, butted atop triple 2 x 8 beam.) 10" x 4" x 22' steel beam was to have 12" x 1/4" plate welded to bottom as lintel. Well, shoring up both floors to trim joists & tuck the beam between the ends was more than I wanted to tackle by myself, so it never happened. btw, local inspector wished me luck shimming joists on the lintel to preserve flatness of sub-floor above but said the plan was ok to local codes. (or his taste, whichever)
I do like the OP's original idea since he'd have plenty of headroom in the garage. Tucking a girder between joists vs below would seem overkill and tho' I wasn't aware of them when I planned that beam job, having hangers as shown above could make things easy. Steel is cheap lately, and wood other than std 2-by could run into serious bucks to go 30' at 16" OC. I'd bet that when the numbers are crunched our guy's original plan wins out. (sometimes 'thinking outside of the box' teaches you to go back inside it when the work begins and the bills roll in. :))
Wow... thanks for all the replys and excellent information. Very helpful.
Several things to point out, that are going to steer my decision in which materials I use.
Hight of ceiling is higher than I would like, but due to current grade, slope of driveway into garage space, and hight of current 2nd floor, both are set, and I can only fill in the space between. Which leaves plenty of room for a beam to hang below the floor joist, waaaaaay below, and won't hurt anything.
I have timber to cut, and access to a sawmill, so I might use rough cut lumber if possible, so keeping floor joist down to 12' by running the beam as in my drawing will allow me to do so. I will be on a tight budget, so using rough cut or recycled materials will be part of the plan.
I do not plan to use this space for automotive type work, for two reasons. One, being attached to the house, I do not want to be welding or grinding, catch the garage on fire, and the whole house burns. So not likely to use the beam for pulling motors or other hoist work. There's a shop in the barn for that. And on that same note, 9x9' garage doors will be fine.
My next step will be finding a cheap used heavy beam. Guess I need to go thru those beam tables and figure out the right size. Unless someone can just tell me...
/ I-beam size 30' span #43
Post 6, Paragraph 3
/ I-beam size 30' span #44
Good stuff concerning the "upside down" trusses. Now that it is discussed I do recall seeing metal trusses hung upside down like that in large commercial buildings. Thinking thru it, I see the point. And in the case of Old Grind's house they have proven themselves for a long time!!!
/ I-beam size 30' span #45
Yep, metal trusses are hung from the top chord all the time.
Also, think about metal buildings built with I-beams. LOTS of them use a tapered I-beam, where the center of the span is a lot deeper section than than where it connects to the walls or posts. Same for the vertical columns. Might be small where it attaches to the floor and much larger at the top.
/ I-beam size 30' span #46
Yep, my shop is all metal. I-beam frame. Center beam is clearspan 42'. Vertical wall beam is smaller at the floor. But roof beam is larger where it fastens to vertical beam and smaller out in the center of the building where they bolt together.
/ I-beam size 30' span #47
Since I have a wife that has trouble driving through narrow doors I would consider installing one wide door instead of two narrow ones. Especially if you are going to park a pickup in the garage. This wouldn't necessarily be just for my wife as I am at the present time getting older too. I'm derailing a bit but just wanted to add my thoughts.
Make sure you make the space around the vehicles wide enough to open the vehicle doors completely. Park two full size vehicles side by side and open the doors. Then start to get in and out of the vehicles. Walk around them with the doors open. Once you see how nice it is to have the extra room then decide how wide you want your garage to be. Often a little extra width is very cheep to incorporate in the overall picture.
Of course it's easy for me to spend someone else's money. Enjoy your addition.
/ I-beam size 30' span #49
Thats just the opposite of how most of them I see are. But given the pitch of the roof, about the only way that center connection at the ridge can fail is if it pushes the wall out. Most of the ones that I have seen are flat or near flat roofs. And the beams always seem to have a deeper section in the middle of the span, where it is needed for the deflection.
But steel aside, look at any type of wood truss. The "deepest" section is the middle. The end supports where it sits atop the wall, not so much. Only have to be strong enough to overcome the shear.
/ I-beam size 30' span #50
Post 6, Paragraph 3
Thanks... I glossed over that, and got lost in the whirlwind of posts following. I will start my search, both used and local suppliers.
Lots of good info... thanks again for all the feed back... I'm glad we could give Richard something new to ponder... *grin*
/ I-beam size 30' span #52
BTW diesel, I grew up on the other side of the river from you. New Martinsville is part of my old stompin grounds, used to take dates to the drive in theater.
Buckeyefarmer: guess you haven't been back in town in a while, the drive-in got leveled and an apartment complex is there now... I remember going to the drive-in as a kid, saw 'On Golden Pond' and 'Raiders of the Lost Ark'. The bowling ally got torn down this past fall, building another motel there. The Viking Glass building is where i work, the company i work for owns it, thats our shop and office. Times they are a changin'.
/ I-beam size 30' span #54
Lots of good info in the replies from everyone. Here is a glulam i just installed in my building.
/ I-beam size 30' span #55
I don't usually go thru that way anymore, but do recall the drive inn being gone. I used to take WV rt 7 from morgantown to New Martinsville, now I take the interstates and come down the ohio side of the river. Remember when the bridge had a toll, that's been gone a few years..lol
There's a guy from New Martinsville that hunts on my dad's farm. Think he works at the Natrium plant, old PPG plant.
/ I-beam size 30' span #56
Nice job on all the joist hangers. I've found that it's easier for me to install the joists first, then come back and install the hangers after they are in place.
/ I-beam size 30' span #57
Are those hangers the top mount kind or face mount only.
On the top mount kind, I like hanging all of them first with ONE nail in the top. That way you dont squeeze them too tight. Drop the joist in and add the rest of the nails.
For the flush mount kind, I agree with eddie, easier to go back through and add later
/ I-beam size 30' span #58
So you guys toenail the joists in place or what??
/ I-beam size 30' span #59
Depends on the hangar I am using and the design of the build.
Something like a deck perimeter or anywhere I can get to the back side of the leger, easily and be able to hold the joist right where I want it, I screw or nail in through from the backside to hold in place. Then add hangars later.
I try not to toe nail anything that is going to inter fear with the hanger. Cause toe nails go through the hanger later. But I really do like the top-mount kind. Assures all the joists are level and the same height, and easier to install the joists and hangars with that style IMO
/ I-beam size 30' span #60
Yep, I can see that. In Bryan's case he can't access the backside. He can't nail a 2x4 along the ledger to sit them on. If he's not going to toenail, how would he fasten them in place before installing the hangars??
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
1988 Mack R688ST (A62679)
1988 Mack R688ST...
