Front SSQA & 3pt pallet fork attachment???
/ Front SSQA & 3pt pallet fork attachment??? #1
lennyzx11
Bennington Vermont
Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
I've been searching but haven't found one yet.
A SSQA front mounted set of forks that also has the three point attachment points all in one attachment.
This would allow one implement that could be used on both ends fairly quickly. Especially with quick hitch adapters.
I know I could get a SSQA ADAPTOR to 3 point or a vice versa one but how about both mounting configurations on one item to save from dropping the adaptor when switching ends.
Thanks.
/ Front SSQA & 3pt pallet fork attachment??? #2
I haven't seen any. SSQA fork frames tend to be a lot heavier than 3pt. Most 3pt forks have a minimal back stop & fixed forks rated for 1.5k or 2k lbs. They don't need the back guard as they don't lift high. I'd wager they are under half the weight of SSQA forks.
I've thought about making a 3pt to SSQA adapter so I could mount my bucket or forks on the back mostly as a carryall. But I already have a quick hitch & that would put things a fair ways back killing load capacity if I needed much.
I've already build a SSQA to 3pt adapter. Welded a quick hitch to a SSQA plate. The lift hooks on that is the pivot for my converted truck snow plow. Also handy for moving & loading implements.
/ Front SSQA & 3pt pallet fork attachment??? #3
There have been a few threads where guys have built one.
http://www.tractorbynet.com/forums/customization/286916-combination-ssqa-pallet-fork-qh.html
http://www.tractorbynet.com/forums/attachments/266276-converting-fel-forks-3ph-lots.html
I have a Speeco UltraFork that fits front or rear. you could build a fork frame the same way.
Thanks xfaxman!
I searched two or three different ways with tapatalk and Google and failed to get those threads.
I was originally thinking on building a carryall on one of those tractor supply frames but then thought of having the pallet forks and just carry the carryall when needed. Then I wanted to use forks on the front end. Next thing you know, down the rabbit hole I went!
I really really have to quit web surfing late a t night.
Fallon, I too would like to use my bucket on the rear. Have you seen examples of this store bought or homemade?
/ Front SSQA & 3pt pallet fork attachment??? #6
I think I have, but can't recall where. There are a pile of SSQA male parts around, $200ish if I remember. It wouldn't take much to weld some 3pt pins on some of em I bet. Just need to leave clearance to move the SSQA arms. Would push things back a bit & lower lift capacity a bit. But I expect this is more about a utility carryall than max capacity.
I found one so far. EAs has one listed ATI 3 point to quick attach adaptor at 1100 bucks including shipping. ImageUploadedByTapatalk1454444110.676709.jpg
Anyone sees any more please post.
Lenny
/ Front SSQA & 3pt pallet fork attachment??? #8
Ya, $1k is kind of insane. My SSQA to 3pt cost me $100 in used parts, would have been under $300 with new parts. The male SSQA interface is more complex with the pins & levers, but I can't see it running more than $500 to make one. Back when I looked prices were stupid high in that $1k range if memory serves. One of those things with low demand jacking the price up I guess.
/ Front SSQA & 3pt pallet fork attachment??? #9
Here is what I did.
Leejohn, that's exactly what I had in mind. Can you show a close up of that rear setup? It looks like a pin on to SSQA plate modified for three point?
I figured I could use the pallet forks to carry a carryall box/ballast etc that way when the bucket or grapple is on front and the bucket when the forks are being used.
/ Front SSQA & 3pt pallet fork attachment??? #12
!st off they don't make a SSQA for my B7800, so I came up with this. I must say I like it better then the one that came with my L4240. If I can find the time I'm going make some hyd cyls for the pins to hook and unhook it.
The frame I made for the 3 pt started out as a hiller and planter, then I made another set of brackets for the bucket. I also can use the forks on the back without the frame set up.
/ Front SSQA & 3pt pallet fork attachment??? #13
http://www.tractorbynet.com/forums/customization/321704-linear-actuator-power-ssqa.html
My power SSQA build... You could easily get by with the cheap $60 actuator on a B. I expect & it would lighter than hydraulics cutting into your lift capacity less. Its a little slow, but in using mine I've found actuation speed is less important than I originally thought in real world use. Easy to anticipate 10-15 seconds out or more before you are going to dump an implement. And you just throw the switch & drive off without waiting for the pins when picking up an implement.
Not sure if you are talking about front or rear, not that it changes the conversation much.
/ Front SSQA & 3pt pallet fork attachment??? #14
I have some actuators and I just don't have the room to use one. The hyd cyls I'm making are small and well not take much from my lifting power. I was watching your thread when you were posting it, it's a good ideal and would work on my L4240.
/ Front SSQA & 3pt pallet fork attachment??? #16
Lol, if you want that route, talk to Xfman (of something like that) about his compact telehandeler. Sane thing only more normal drivetrains. Only slightly more than double the cost of our L3200s though.
/ Front SSQA & 3pt pallet fork attachment??? #17
I built this from scrap metal and never used it yet. Just thought I needed it I guess. Hope it helps.
Steve
Steve
Steve, where do I need to come pick that up since you don't use it! <laughing>
That's exactly what I was thinking of.
Lenny
213098 (A64276)
213098 (A64276)
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
County Line 4' 3-Pt Rotary Mower (A66408)
County Line 4'...
C&S FARMS AUCTION - IN LOVING MEMORY OF JACKSON STRICKLAND. (A64277)
C&S FARMS AUCTION...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
