I got a Tractor!
/ I got a Tractor!
Here is what the piece I removed looked like on the back side!-
Then, I had my CNC plasma cutter make me a piece of 1/4" plate that was a bit bigger than the hole I had just made. By welding some bolts to that piece and using nuts and washers, I was able to draw it up tight to the inside of the loader arm for welding-
Then the bolts get cut off, welds are finished on that piece, and I weld another piece CNC cut to fit inside the welded area-
That ties it in nicely. I then ground down any high spots and clamped on then welded the first over sleeve-
Then once that is welded where where the second over-plate will cover-the second one gets clamped and welded on-
The inside of the arm gets similar treatment-
Then the process is repeated for the other side of the loader boom.
/ I got a Tractor!
Then there are some top and bottom plates that sandwich the whole thing, but those photos aren't loaded in the computer right now. At this point the loader arm repairs are actually done, so the project is now pretty much up to date.
Until next time, see you all later and have a Happy New Year!
/ I got a Tractor! #63
Your pictures will not load.
/ I got a Tractor!
strange.
At first, they were all there normally with thumbnails.
Then I left and came back and the thumbnails were gone, but when I clicked on the attachment text, the photos came up.
Now it says they are invalid. Pretty frustrating as I spent a lot of time loading them and writing all that.
/ I got a Tractor!
Well, I re-did the attachments. We will see if they stay put...
/ I got a Tractor! #67
Great read
A labor of love, or you just crazy.
This weekend I did a job I dreaded doing as much as income taxes.
My Mustang Cobra needed to have an inaccessible bung for the O2 Sensor weld repaired
God was on my side as I got the header flanges off without breaking any studs, etc. I was even able to get the broken pipe section removed without dropping the entire exhaust system.
I had visions of having to remove the engine and drive train, dropping K frame etc. I said a thank you prayer afterwards as I got offso easy.
/ I got a Tractor!
Great read
I'm pretty sure I'm just crazy!
/ I got a Tractor! #69
Nice work you have been very busy
Sent from my iPad using TractorByNet
/ I got a Tractor! #70
2012 VOLVO ROAD TRACTOR (A64280)
2012 VOLVO ROAD...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Kivel Quick Hitch Skid Steer Attachment (A61572)
Kivel Quick Hitch...
CASE IH MXM175 MAXXUM TRACTOR (A64280)
CASE IH MXM175...
2009 Ford E-350 Cargo Van (A61573)
2009 Ford E-350...
HARDEE DITCH BANK MOWER PARTS (A63291)
HARDEE DITCH BANK...
