Lift Cover Adjusting Tools
   / Lift Cover Adjusting Tools #1
otdrzman
Pilot, VA
Massey Ferguson 150
Hey. I am new to the forum and have been browsing it for the last few weeks or so. Lots of good info on here. I recently purchased a Massey Ferguson 150. While servicing the hydraulics I found grease on the hydraulic filter. After a little research I found out how it had made its way in the hydraulic fluid as Im sure many of you already are aware of. I removed the lift cover and cleaned out all of the grease that had accumulated since 1969. While there I replaced the worn external draft control components as well as the internal draft control rod. I have made the first initial adjustments. I am now at the point of needing the MF 970 tool/gauge, MFN 163 tool to make the draft and position control adjustments. I understand they are impossible to find and some folks use bolts and such as alternatives. My question is, have any of you made the tools yourself. My neighbor has a small milling machine and I am thinking of trying to fabricate the 970 tool and I haven't decided what Im am going to do for the 163 tool. If you can offer any tips or pictures I would greatly appreciate it.
Thanks
   / Lift Cover Adjusting Tools #2
Thanks
I'm a toolmaker. I've made all the necessary tools needed for the the tractor repairs I have done. The I and T manual have had sketches for everything I have needed.
SIMassey. Check you PM's
Kubota U55-4 (A57148)
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
Bobcat T590 (A60462)
Yanmar YT359 (A53317)
