Loader Chain hooks on loader
/ Chain hooks on loader #21
And you may have noticed that Ken uses weld on hooks on his bolt on pads. And does a really fine job of welding I might add.:thumbsup:
Thanks James, I wish I could take all the credit though but these are all done on a robot now, I simply couldn't keep up with the demand.
/ Chain hooks on loader #22
Here's what I did I'm very happy with it. Feel free to use the idea Ken.
/ Chain hooks on loader #23
I have Ken's 5/16" Bolt On Grab Hooks on the bucket and cross-drawbar of my Kubota B3300SU. They have not moved even 1/10,000's in four years.
Buy new drills, per Ken's instructions, and installation is simple.
/ Chain hooks on loader #24
Us Welder guys don't understand why anyone would bolt them on when they can be welded on so much easier and not have to worry about bolts coming loose or breaking depending on your bolting ability or lack thereof. :)
I can weld ok, it's just easier and quicker to drill a couple holes and crank down the bolts than it is for me to drag my welder over, clean the paint off the area to be welded, weld it, clean it again and then have to repaint all the burned off area.
yup, he sure does.... a much prettier and better job than I could do.
Another reason for me to bolt it on. :)
/ Chain hooks on loader #25
Ken's are great! The video is excellent and the include written instructions are great as well and I use to write procedures to repair nuclear submarines.
/ Chain hooks on loader #26
/ Chain hooks on loader #27
TISCO, as well as Northern Tool and othes sell weld-on chain hooks. The use of these rather than grinding and/or cutting grab hooks designed for linking with chain produces in a much more professional result.
Buy the weld-on hooks and take your bucket to a professional welder.
SDT
/ Chain hooks on loader #28
SDT
We sell the proper weld-on hooks too: Ken's Bolt on Grab Hooks <<Weld-On>>
/ Chain hooks on loader #29
Those look like decent weld-on hooks (Grade 70) for an acceptable price. The flat plates are a valuable addition as well. I'll likely be using your products in the future.
Since this topic comes up often on this forum and others, I'll provide your link unless there is an objection.
/ Chain hooks on loader #30
Not at all sir, thanks!
/ Chain hooks on loader #31
I have three on my loader, and one on each of my bh buckets. I also put one on my brother's loader for him.
Real good stuff...real good guy to deal with.
I was looking at my quick attach bucket on the la525 and the plate that is welded across the top is not even with the front of bucket. It appears that the bolt on hook will not sit flush at front of bucket. It would have to be moved back a bit. Then the under side looks like it would be drilled right through the weld seam?? Anyone else tackle this issue on this loader?
/ Chain hooks on loader #33
This has not been an issue for MANY customers.
Thanks kennyd. I got my order in for a couple grab hooks and a drill bit.
/ Chain hooks on loader #36
<snip>
The lip itself is not strong enough, so do not hook chains to it (not to mention that the size/shape of the lip is not right for any chain hooks I have ever seen).
The "lip" on the bucket of my M4700 FEL fits the hook of a chain just fine.
attachment.php
And you can tell by the crenulated surface others have proven it is NOT strong enough for heavy loads :)
/ Chain hooks on loader #37
451372d1450825693-chain-hooks-loader-img_20151203_112002182_hdr-jpg
Crenulated...I just learned a new word!
Anyway, that is why I welded a pipe under the lip. Unfortunately, that would make hooking the grab hooks as in the photo not possible.
/ Chain hooks on loader #39
I have the same loader as you. The bolt ons from Kenny worked perfectly. ImageUploadedByTapatalk1452371521.294810.jpg
I also added a Clevis inside the bucket center for a 1/2 inch shackle but am planning on adding another one on the rear outside of the bucket sandwiching the bucket body.
Here's a tip. When you try to get the nut and washers inside the SSQA mount, stack them all up on an Allen wrench with a couple of fingers holding it up through the bolt hole. Then push the bolt down through the washers and start it in the nut which you are holding up with your fingertips. Switch to a wrench to hold it and tighten down.
Thanks for the pics and tip. I was thinking it was going to be fun trying to get the washers and nut on.
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2018 FREIGHTLINER...
36' GOOSENECK LIVESTOCK TRAILER (A63291)
36' GOOSENECK...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
208320 (A58375)
208320 (A58375)
2015 Chevrolet Traverse SUV (A61574)
2015 Chevrolet...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
