Trouble with Home LED lights
/ Trouble with Home LED lights #41
I had a jelly jar porch lite that a LED just would not work (would not come on). Put in a old incandescent and it worked fine. I don't have the patience for things that don't work, just wears me out. I've a Dimmable LED on a dimmer switch in the basement that is about to go away as sometime it just goes off on its own, Probably go back to a dimmable CFL. I'm tryin' not to get sucked down the LED rabbit hole to far too hard on my pocket book chasin' fads. bjr
/ Trouble with Home LED lights #42
I bought LED X-Mas lights a few years back thinking this was for life. They all went dim and died! This is why I still just have a few cheap T-8 strip lights in my three year old shop and will put in LED lighting when it proves itself and comes down in price.
I have never had an LED light that wouldn't work. The 2 that I recently replaced still worked on all the LEDs in each light, they just got dim after 5 years of about 18 hours per day of use. These were over our computer work station which I turn on between 5-6 each morning and wife turns off about 1 pm each night. I calculated 31000 hours on these bulbs. None of the other LEDs in the house have started to dim yet.
By the way, the old LEDs had a second or two of hesitation before coming on but the new ones are instant on. I guess they have fixed that little problem with the old ones. I hope I get the same service on the new ones as I did on the old ones.
/ Trouble with Home LED lights #44
The only problem I've encountered with LED's, is new one -65w flood- that blinked every so often after being on an hour or so. Very annoying. When I replaced it it seemed very warm/hot. That didn't seem normal to me, but I've not had to mess with any before either.
/ Trouble with Home LED lights #45
So far not a bad one...
My brother just bought Cases of them and not a bad one in 200... can't say that with incandescent.
Excellent advice try a sample first to see of the light produced is suitable...
/ Trouble with Home LED lights #46
The 750w LED's that I've installed are 3000k or down around the warm scale. Way too harsh for some areas. The 650w I've ordered are a little better at 2700k. So I hope this does the trick.
I hear ya. I just put a 5000k LED bulb in my kitchen light. It's BRIGHT!, but is also rather harsh. I'll probably switch to something warmer and put this one in the garage or something.
Hopefully, they can tone down the harshness of white LEDs. We have clear Christmas lights strung around the perimeter of our living room for accent lighting. Thought I'd replace them with LED lights to save on electricity, but again too bright and harsh for the room...sticking with the incandescents.
I would like to replace the CFL outdoor spots we have with LEDs...the CFL ones take a good 10 min. to reach full brightness in cold weather (about the only time I use them...to illuminate the driveway when plowing snow). Right now they're way too pricey.
/ Trouble with Home LED lights #47
The 2700k LED's work just fine for me now. As far as the outdoor floods, I've gone with the Halogen floods. I also only use mine for short periods when blowing snow in the winter. Other then that they rarely get used. No need for energy saving lights out there. The indoor floods get used a lot, that's why I went with the LED's.
/ Trouble with Home LED lights #48
I made the mistake of getting a couple of cool white LED Christmas lights and they are just too harsh on the eyes. I've been slowly replacing them with warm white ones. They have just enough yellow in them.
/ Trouble with Home LED lights #49
My Cree LED bulbs were in ceiling fixtures over a breakfast bar. Some were hanging down while others were mounted flush. My step father has one outside that only works when the temp is about 40f. I think Cree fixed the problem with the bulbs. The new ones are vented so maybe it's an issue with heat damaging something in the base and because they are hanging the heat rises towards the base, don't know.
I took two apart, one that worked and one that would just flicker. The globe is glass with something that feels like a rubber coating on it. The globe was glued to the base with silicone caulk. Was very easy to remove. Once off the LEDs are visible. They are tiny yellow squares in the pictures. There's a white clip that easily removes and then the LED assembly just slides off. I swapped LED assemblies between the two and that's what's bad. One of the LEDs (if you look closely at the LED assembly that's not on the base you can see it just below it) came right off as soon as I touched it while the others were stuck on and didn't come off. Maybe that was the problem and the newer bulbs being vented help remove the heat.
/ Trouble with Home LED lights #50
All of the ones I have put in are open... several bulb up and the rest horizontal as they are in 1950's ceiling lights...
No can lights in Mom's house.
The only one that is bulb down is over the table where she reads the morning paper... it is a CREE and similar to the flood lamp style... on a lot and the fixture is large and well vented...
Interesting about the one that fell apart.
/ Trouble with Home LED lights #51
During January and February of this year, I replaced incandescent and CFL bulbs inside and outside with LEDs. The only ones I did not change were the appliance lights (in the refrigerators, microwave, and oven), and the two in the Liftmaster garage door opener. I tried them in the Liftmaster and they did not work at all. I got LEDs from Walmart, Home Depot, and Lowe's; 2700k and 5000k. Two are outside, 24/7 (never turned off); one is in a jelly jar type fixture, the other open. I have not found a single defective one when new, and I've not had a single one go bad so far. We have different sized bulbs and bases and four 3-way bulbs. There is a 4 bulb fixture in the master bath that I had trouble finding LEDs of the right size and with the small base; finally found Sylvania bulbs at Lowe's. When you flip the light switch on, it takes a split second for them to come on; all others are instantaneous.
But last Christmas, I bought three 70 bulb LED multi-colored web lights to put on 3 shrubs out front. This year, 2 of the sets work just fine, while only about a third of the other set works, and I have no idea why.
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
2002 Chevrolet Express 3500 Shuttle Bus (A64194)
2002 Chevrolet...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A67147)
2005 KENWORTH T800...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2006 INTERNATIONAL 7400 4X2 VACUUM EXCAVATION TRK (A63276)
2006 INTERNATIONAL...
