Trouble with Home LED lights
/ Trouble with Home LED lights #21
Many led bulbs, especially older ones, are clusters of led's.
Over time, as a few burn out, the bulb would put out noticeably less light.
/ Trouble with Home LED lights #22
On an up note;
I bought (14) 8' T12 LED tube lights rated 6000 lumens & 6000K and that used 48 watts and the difference was incredible!
My garage is 40x60 and is only heated when I use it and the LED's are at 100% when turned on and the added output and bright white light makes everything POP!
It actually improved my mood being bright and made it enjoyable to be out there.
Being able to see everything prompted me to start a week long cleanup project.
90cummins
Lets do a little cost analysis to see if Gary saved any money on his 31,000 hour period he used his LED bulbs.
I don't know what Gary paid for those bulbs 5 years ago, but I am going to suggest he paid about $25 each. LED bulbs cost a lot more back then.
So he got 31,000 hours out of them, that would be about 30 standard bulbs that he could have bought for about $0.50 each. So he is in the hole about $10.00 on the costs of the bulb by my way of thinking. Now only Gary can tell us how much trouble it would have been to change out those 30 standard 1000 hour bulbs and whether that would be worth anything to him, but so far he is $10.00 in the hole in buying the LED bulb.
Now lets figure out how much electricity Gary saved with the 12 watt usage 60 watt equivilant LED bulb.
First lets figure how much the 30 standard bulbs would have cost to run. Lets see, 60 watts is .06 Kilowatts X 31000 hours = 1860 KiloWatt Hours. Lets say Gary pays $0.10 per KiloWatt Hour. So Gary would have payed $186.00 to run the 60 watt incandescent bulbs that 31,000 hours.
Now lets figure the LED bulbs. Gary said they used 12 watts. Newer bulbs use a bit less, but that seems about right for bulbs of that era.
12 Watts is .012 Killowatts. X 31,000 hours = 372 KiloWatt Hours. X $0.10 per Kilowatt hour (guessing here as to what Gary pays, but I doubt he pays any less than this) = $37.20 for electricity for the LED bulb. Whoa now! that is a huge saving in electricity. $186.00 - $37.20 = $148.80 in electrical savings, and now subtract the $10.00 that the bulb cost over the incandescent bulbs yields an overall savings of $138.80
Multipy the $138.80 by how ever many of these bulbs Gary had, and we are talking some real money.. Note that if the cost of electricity is more than the 10 cents and the fact that a good Cree bulb is about $9 at Home Depot, and that the new bulbs are 10 watts consumption for 815 lumens of light and your savings will be even more. Anyway you figure it, LED bulbs can save a pot of money, if they are used much.
Gary please correct me if anything doesn't look right in the figures or assumptions.
I really don't know what the cost per KW is here (never looked at the bill, wife pays them) but that sounds about right. The reason I put 19 of them in was to save energy cost. Granted the other 17 don't run nearly as much as the ones I had to replace. Kitchen lights run next on the longest time but I doubt that they run more than 6 hours per day. These two are over our computer table so the come on first thing in the morning till last thing at night. I think I got my monies worth from them and you are correct that they cost around $25 each when I bought them.
Mine were cluster of about 8 LEDs but none of them quit working, they just got dim.
/ Trouble with Home LED lights #25
So far, I am very pleased by the Cree brand, we shall see how well they hold up long term.
Not well. In Vermont they are cheap (state law) so a little over a year ago I bought 20 60w Cree bulbs. I bet about 6 of the dozen or so I installed now have failed. I stopped returning them and now just have a drawer with the bad ones. The latest ones I got have gone through a design change. They now have vent holes in them. Not sure if I like that because now I can't use them outside because bugs will get inside the bulbs. But maybe they will last longer. If I had to guess I would say the problem is poor soldering as a number of them would start to work again if you tried to screw them in a little tighter but only for a few minutes. I'm going to take one apart to see how it's made and why they fail.
/ Trouble with Home LED lights #26
50% failure is a disaster...
I did notice the newer CREE bulbs are different in physical appearance and cost less than the original ones I bought...
Often wonder when I see a good product that has undergone a design change if it is to cheapen or improve upon the original...
/ Trouble with Home LED lights #27
How long is a piece of string? When talking about how long an LED lamp will last, that certainly seems to be the state of the question.
Manufacturers of LED lamps, which many regard as the next generation of lighting, destined to eventually replace today痴 incandescent and compact fluorescent lighting sources, make wild claims as to product life.
Typical incandescent bulbs last 1,000 to 2,000 hours. But in speaking about LED replacements, lamp life is routinely quoted as 25,000 to 50,000 hours. Long lamp life, and the reduced power used to create the same amount of light, is what makes this technology so promising.
But what does a 25,000-hour life mean? As it turns out, no one is quite sure yet. The definitions surrounding LED lamps, a nascent technology, are still being made up as we go along.
One thing we do know: It means something different than when people think about the life of a regular light bulb.
When it痴 said that a standard light bulb will last 1,000 hours, that is the mean time to failure: half the bulbs will fail by that point. And because lamp manufacturing has become so routine, most of the rest will fail within 100 hours or so of that point.
But LED lamps don稚 澱urn out. Rather, like old generals, they just fade away.
When a manufacturer says that an LED lamp will last 25,000 or 50,000 hours, what the company actually means is that at that point, the light emanating from that product will be at 70 percent the level it was when new.
Why 70 percent? Turns out, it痴 fairly arbitrary. Lighting industry engineers believe that at that point, most people can sense that the brightness isn稚 what it was when the product was new. So they decided to make that the standard.
Of course, brightness is subject to the old frog in the boiling water syndrome. I知 sure that most people won稚 even notice the lower level then, if they致e lived with the same bulb for its entire life. (How many owners of rear projection DLP TVs only realize that a TV痴 image has dimmed once they replace the bulb?)
If nothing else in the lamp fails, like its electronics, the product will continue to work until it becomes really dim. But some engineers are proposing a way to get around even that.
Their idea is that once the LEDs start to emit less light, increase the power to each one to increase its brightness. Unfortunately, that will also diminish the life of the lamp.
Good idea, or bad? 典he utilities really don稚 like this idea, Fred Welsh, a Department of Energy consultant, told me on Thursday at a lighting conference sponsored by his federal agency.
Not only would contractors need to use thicker cables, but the utilities would need to create more power, partially negating the appeal of LED lighting in the first place.
But still, it痴 in its early days, and no one yet knows how this will be settled, or how the consumer will be educated to think about 澱ulb life in a different way than they have for the past 130 years. If consumers are going to switch to this new lighting technology, it痴 an issue that needs to be settled.
And if it isn稚? 典his is a potential black eye for the industry, Mr. Welsh said.
The LED aren't what normally dies. There has to be a converter that steps down the voltage and then turns it into a steady DC voltage. All of that has to be tucked into the base of the bulb. Any heat that is generated needs to be radiated away. I'm finding the Cree 60w bulbs I bought last year are failing due to, what I can only guess, poor solder joints. The LEDs are much dimmer but some of them will emit the correct amount of light again if I screw the bulb in a little tighter. I've cleaned up the base of the bulb to see if that's where the problem is but it didn't make a difference. I'll take one apart to figure out what's failing. If the bulbs weren't discounted due to state law I doubt I would buy them.
/ Trouble with Home LED lights #28
Our home, which is 13yr old, has 41 recessed lights in ceilings that take the 65w flood light. Several years back I switched out about 1/2 of them - all in lower level- with CFL's. The wife hated them for the slow warm up when you turn them on. Now I'm going back and changing out the whole 41 of them with LED's. I started with Westinghouse brand @ 750 lumens @ $7.50 ea. from Menards. I find that the light from those are harsh or too bright white.
I just ordered from the net, another dozen @$5.50 ea @ 650 lumens Great Value brand hoping they will tone it down some. Both bulbs are rated @ 9w
If this don't do the trick, I'll have to start looking into dimmers.
In some places like the stair well, the bright bulbs are great. But having 10 of them on in the kitchen is just way too bright, almost like eating on a stage.
/ Trouble with Home LED lights #29
If you don't like the daylight color temperature, get the so called "warm white" which is more yellow in appearance. Cree sells both in the BR30 size. big difference in them. I have some of both.
/ Trouble with Home LED lights #30
In my master bath, I have a 6 globe fixture above the vanity. The original bulbs were incandesent. They emitted a tremendous amount of heat. I switched them first to cfl and hated them. Now have led, great light and virtually no heat. Still like the cfl on the nightstands, slow warmup gives the eyes time to get used to the light after waking up.
The ones I bought at Lowes were the "warm white 2700K" which I find to be more yellow than white. If you like the yellow color then get the 2700K bulbs. I prefer the daylight style in the 5000K range. I have since swapped out the Lowes lights with some from Walmart. I got one 100W equivalent in a regular light bulb (360degree radiant) and one 65 watt flood light style. Both are super bright with the 100 watt being a bit too bright. I may swap it to the kitchen later where lots of light is beneficial.
I plan to return the Lowes lights as I have no need for yellowish/orange light.
/ Trouble with Home LED lights #32
I have been considering changing my CFL's to LED but not looking to buy a bunch of expensive bulbs just to have them go dim in a short time.
I like the appeal of no warm up with LED's.
I currently have three 46w (300w incandescent equivalent) CFL bulbs in my unheated garage. Has anyone found LED's that would have an equivalent output?
/ Trouble with Home LED lights #33
Here are one They are not going to go dim soon, 30,000 hours of useage is a lot.
/ Trouble with Home LED lights #34
The only place I have noticed any discussion is LED lights around the vanity mirror do not do a good job of keeping the mirror fog free...
/ Trouble with Home LED lights #36
a couple years ago, i bought 4 LED, 60 watt bulbs at Home Depot, Lowes, and Walmart: within 6 months, 3 of the cree from HD had quit: HD did replace them, after a lecture about they really didn't "have to", etc etc: but i won't buy any more cree bulbs: have not had any other failures: WalMart had some that were subsidized by the local electric co: 88cents each: so i have a bucket load of those now: and am not going to worry about a warranty at that price: on black friday, Lowes had some for 99cents: all of them beat the heck out of the light our of the CFL bulbs.
/ Trouble with Home LED lights #37
The 750w LED's that I've installed are 3000k or down around the warm scale. Way too harsh for some areas. The 650w I've ordered are a little better at 2700k. So I hope this does the trick. If not, I'll have to learn to live with them one way or another or mix with CFL's instead of all LED's. I'll have too much $$ invested in this to change again.
/ Trouble with Home LED lights #38
Would like to know more about he CREE failures.
I live in a mild climate... no heat much of the year and never A/C
Wonder if the failures are heat related or type of fixture.
The whole house change I did was at Mom's place... all 1950's ceiling light fixtures with a few table lamps thrown in...
Not a single bad one and her electric bill dropped dramatically.
The family room had four 100W bulbs in the single ceiling fixture and now has 4 CREE 60w equivalent making for under 40W total... 400W to 40W is dramatic and she likes the light and hated the CFL we tried!
/ Trouble with Home LED lights #39
UPDATE
The 65w @ 2700k did the trick. Much more pleasant light in kitchen. If I were to have used the 65w @ 3000k lights - total of 10- we would have needed sunglasses when preparing meals.
I would advise anyone who has intentions of switching to LED's, just buy a couple of each and see how you like the illumination before you jump in like me and purchase a bunch only to find they're not right for the application. The 65w 2700k LED's are very close to the 65w incandescent in light output.
Fortunately I can mix the 65w 3000k bulbs in with the CFL's in the lower level - every other one - 20 lights - and make them work. You don't notice the slow warm up of the CFL's that way.
Thanks k0ua for the info on the different k output of LED's. I never paid any attention to that before. I will now.
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
2006 Hypac C530AH Pneumatic Wheel Compactor (A64553)
2006 Hypac C530AH...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A64553)
2007 JLG 600HJ...
2015 Ford E-350 Shuttle Bus (A64556)
2015 Ford E-350...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
135 (A64278)
135 (A64278)
