/ Harbor Freight Tools that don't suck #5,141
I've given up on their brass air connectors. Maybe the industrial sized ones work but the auto sized suck. For me, I switched to whatever Lowe's sells and have never had a bad one.
/ Harbor Freight Tools that don't suck #5,142
There is no size label on the air connector.
/ Harbor Freight Tools that don't suck #5,143
Maybe I should start a new thread, "HF tools that blow"
/ Harbor Freight Tools that don't suck #5,144
There are two kinds of air quick connectors. One is the"industrial" and it has the larger hole. The "auto" quick connect is the one most of us use nd has the smaller diameter hole. The two won't interchange.
/ Harbor Freight Tools that don't suck #5,145
H.F is ok but to buy something for lifting overhead even jack stands I would have to re weld it before I used it for peace of mind.Other things like sockets are ok to buy.
/ Harbor Freight Tools that don't suck #5,146
Uh - I think HF calls the more expensive series with 3/8" bore '1/4 x 3/8 Automotive', while the steel or brass 1/4" (or less) bore style is 'Industrial'. Both series have 1/4" pipe thread. Here's a link, the pictures there show the difference in bore diameter:
Search results for: 'coupler and plug kit'
/ Harbor Freight Tools that don't suck #5,147
Well I was poking around the website and seen few things that caused me to remember what I have purchased from HF in years past considering I have not actually bought anything new from them in almost 10 years now. My mailman probably still hates me for having to lug not just one but two of their horrible 5" multipurpose vices up and down the several flights of stairs to my old in city apartment way back then to deliver and then return them both. :laughing: Really I feel bad that was lot of BS!
So then I saw the 20pc plastic bins
20 Piece Poly Bins and Rails
I have these bins must have got 3 sets. I think they once sold for maybe for $8.99 (or maybe less) And I made a portable table top rack to mount the bins (and that's worked out quite well over the years)
So they store a huge grade 5 SAE nut and bolt and steel lock washer set 1" thru 3-1/2" inch lengths and 1/4 thru 5/8" diameters that I also believe originally came from HF. They had a Metric kit at the time too. Has been a valuable asset to me over the years being miles away from a hardware or automotive store and long before the days of TSC. Of course it has been added and renewed to since then
I didn't find anything like it on the site though, does anybody remember something like that?
Another vendor at my summer flea mkt gave me free one of these steel wall mount panels. Might need to fill it up! :D
Amazon.com: Akro-Mils 30136 Louvered Steel Panel for Mounting AkroBins, 36-Inch W by 19-Inch H, Grey: Home Improvement
/ Harbor Freight Tools that don't suck #5,149
DFB--My mailman was none too happy when I bought their large, cast steel anvil a number of years ago. worse, it arrived in the Spring so he had to lug it through the New England muck to the house. I think it was 70 lbs.
/ Harbor Freight Tools that don't suck #5,150
Yesterday I opened a HF 8x10 tarp, one of several I bought on sale 3-4 years ago.
I spread it over a firewood rack that I made 7' 4" wide to fit the labeled, finished size of the tarps. There was about a 6 inch gap. Then I got a tape measure, pulled the tarp tight and measured it. 6' 10" wide. So I measured another one from the same purchase. It was 7' 4" as it should be.
Bruce
/ Harbor Freight Tools that don't suck #5,151
You must have gotten a metric one. :laughing:
/ Harbor Freight Tools that don't suck #5,152
Speaking of tarps, something to keep an eye out is that they haven't been cut by a boxcutter. No fault of the product, but a while back when they had a sale on tarps I got a bunch of the pickup bed cover size and put them in the file cabinet in the shop. Grabbed a new one to help someone move a dining table in the rain, got there and found a bunch of slits where they opened the case and nicked the top tarp. Didn't notice it at the store, when it was unfolded there were like six parts that had cuts. HF is one store where it's really necessary to carefully inspect stuff before it goes in the cart.
/ Harbor Freight Tools that don't suck #5,153
First week report for the 3 in 1 framing nailer from HF.. I am not a professional builder, carpenter, any of that "er" stuff and if you are, why are you trolling this thread lol
First it is incredibly cheap (pricewise) bought it for 119 and it goes on sale for 99 in 2 days so I will be going back for that credit
The good:
compared to those I picked up at the local HD it seems to be in the same weight class not much lighter like most cheaper products usually are
Instructions are easy and are on the nail rail of the gun so you don't have to keep going back to printed manual depending on what nails you are using
It misfired only twice, and exactly as described if it gets too low on nails.. Both times while shooting nails upwards and with only 3 nails left in the rail
Used it with both 21 deg and 34 degree 2" , 3-1/4", and 3-1/2" nails.. The 21 deg nails were Dewalt brand bought at HD the 34 degree were bought at HF. It fired both easily
Framed and built most of a one sided barn this past weekend. Will put up pics and a build thread shortly
Extremely efficient on air.. was set at 68 lbs to set 3"+ nails that is 2 lbs lighter than recommended in the manual
The bad
Cannot plunge fire the nail gun.. It has to press and then pull trigger to fire.. Not really a bad thing but I thought it should be able to plunge fire
The grip is a little small (diameter) in my opinion but I cannot tell you if others are larger. Maybe they are all that small? Maybe I have big hands?
Unrelated bad:
Although the nails at HF are much cheaper this time they actually come that way because they suck.. I bought the 34 degree ringed nails and the plastic glue on the ends never melted they pulled fairly easy whereas the dewalt nails that plastic glue seemed to melt when driven in and was much, much harder to remove the nail..
So far a great purchase, time will tell as I have a house to build.. If it survives that then it is a great great purchase
Ok thought I would give an update on performance.. 9000+ nails and still working great.. Oil it every day of use and I think it is a winner. It would probably be faster changing nail types if I had 3 different guns but I have become a pro at changing it out for different nails angles. Taking merely seconds to do. It has suffered its very first super "Aw ****" jam.. Due to my limited experience with other nailers I cannot judge if they all can do this.. But I left the tension off of the nails due to trying to fill it max :) it bent one of the nail heads sideways and crammed it half down the piston tunnel.. This required about an hour of fidgeting but I got it all taken apart, cleared and it has worked flawlessly again since. I dont blame the product for this but it was sure a hassle to clear that one.
Also a reinforcement do not buy HF nails at all costs :) they are softer and again the glue is there to give you a pretty color it does nothing in the wood or to hold the nail. Alternatively, it has been slamming DEWALT 3.24" framing nails non stop most every weekend day.
Granted its all been by one of two users, myself and my son. We may not work at the same speed as others. But for a part timer, I give this tool two thumbs up
/ Harbor Freight Tools that don't suck #5,154
Look a 5 star review! :shocked:
Plumb Bob With 15 Ft. Line
I watched that 2nd video... 5 Things at Harbor Freight Worth Buying! The 60 pc tap and die set looks pretty decent in the online photos and includes both SAE and metric for the price of just one of my old Craftsman sets. I have seen the 45pc titanium coated tap die set with the larger sizes in couple of repair shops. (one at the motorcycle shop I frequent)
I don't know what to say on that electric impact wrench. I have a Cal Hawk branded one with the exact same specs its never impressed me much. I originally bought it years ago probably because the price was right? :confused3:
I tried to loosen the compensator sprocket nut (165ft lbs is factory spec) on my Harley to replace the alternator with it not a chance.
It has been in the tool box drawer for like forever so I just took it out chucked up a 1/2x 13 bolt in the Yost steel vise then a couple of flat washers, a lock washer and then ran down the nut and let it hammer for 15 seconds.
Then I took my tiny 12v Milwaukee 3/8 drive cordless impact rated at 100ft lbs and in about 5 secs. it loosened and spun the nut off. I tried the scenario twice with the same results. :confused2:
Not very scientific hey! :rolleyes:
Impact tools we discuss them often on TBN (I searched this thread)
The cordless impact wrench that HF offers claims a higher torque value a whopping 330 FT LBS :eek: or about 100 ft lbs more than the corded model. Not bad! Does cost more though and sadly a little outdated being Ni Cad, but looks interesting and much more mobile than the corded tool. A similar sized tool kit (single battery)from a brand name like Milwaukee would cost more than double the price and it is just about the same cost as a bare tool Ryobi or Milwaukee 1/2 drive compact impact wrench which are only rated at about 200ftlbs. In the you tube vid it looks like it does all right for itself.
https://www.youtube.com/watch?v=HOppsRCePUY
I really like cordless impact wrenches and drivers I have quite a few different ones! :D
/ Harbor Freight Tools that don't suck #5,155
Followup on the little Ryobi impact driver that claims 1600 inch-pounds.
Today I replaced a tire on the little watering trailer pictured above, and torqued the lugs with the Ryobi until the socket wouldn't move. Then I used a beam torque wrench to finish tightening the lugs. It took just over 50 ft/lbs to tighten the lugs beyond what the Ryobi could do. The Ryobi is very handy but this is a huge variance from claimed specs.
Doesn't (claimed) 1600 inch-pounds translate to 133 ft lbs? What am I missing here?
Did you find a satisfactory answer to your question?
I know both Workshop Addict performed a torque test video and Real Tool Reviews has done several videos testing torque ratings of different cordless impacts.
Bolt size and thread pitch are the main factors in duplicating factory ratings it seems
/ Harbor Freight Tools that don't suck #5,156
:D Yep. For farm and vehicle use I went and bought HF's Earthquake 1/2" air wrench - claimed 700 ft lbs, and 3/8 x 1/4 air couplers so it could breathe. A couple of points on my backhoe etc specify over 150 ft lbs so I decided to just get this instead of straining with a breaker bar any more. I'm getting old and impatient. :)
The little Ryobi impact tool remains useful for carpentry. Here's a photo running in 10 inch lag bolts (into drilled holes), replacing the rotted out foundation plates under a 100 year old water tank tower. This is earthquake country. Bolting the 6x6 corner columns to the plates, and the plates to the concrete foundation, is needed to prevent the structure from leaping off its foundation when the Big One comes.
And I continue to use the little Ryobi for ordinary nuts & bolts, and to reach the first 50 ft lbs quickly then finish with a beam torque wrench when remounting tires etc. Note this Ryobi is the little 1/4" hex drive 'impact driver' intended for deck screws etc, not their 1/2" 'impact wrench' with a lot more torque. (Looking up those links I see the impact wrench kit with battery and charger is only $10 more than the bare tool. Recommended).
/ Harbor Freight Tools that don't suck #5,157
Ok, point taken. :thumbsup:
But I started my discussion of this belt/disc sander with high hopes, I inquired here about others' experiences before buying this. The replies were favorable so I relied on this 'don't suck' thread and went ahead and bought one.
But those favorable replies must have described the earier 41 lb version, not the 29 lb version with same product number that I received. It seemed reasonable to write my followup here in the same thread as my initial inquiry.
Overall, I agree, they sell enough sucky stuff to deserve a thread dedicated to that. :D
,,,,,,,,,,,,,,,,,,,,,,,,,,http://www.tractorbynet.com/forums/parts-repairs/114375-hf-tools-suck.html?highlight=tools+that+suck
/ Harbor Freight Tools that don't suck #5,158
Quote Originally Posted by California View Post
If it has a square drive, those were square-inch-pounds. Divide 1600 by 144.
:laughing:
Bruce
/ Harbor Freight Tools that don't suck #5,159
/ Harbor Freight Tools that don't suck #5,160
It gets even stranger. :eek:
I just corrected my post two posts up, #5156, to clarify I'm discussing Ryobi's little 1/4" hex drive impact driver intended for deck screws, not their 1/2" mechanic's impact wrench.
Got some math for that? :p
1999 Fontaine 48ft. T/A Flatbed Trailer (A61568)
1999 Fontaine...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2018 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A59906)
2018 FREIGHTLINER...
2013 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2013 BIG TEX 20...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
