/ Harbor Freight Tools that don't suck #4,881
Question: Has the HF welding table always been capable of folding flat for storage? Didn't think the ones they've carried heretofore are that collapsible.
Got a promo email this evening with a super coupon for a "New" welding table that folds flat. The promo art looks like what I recall seeing in the stores, so I'm wondering if the folding feature is what's new. $59.99, good through 10-16-15. I'm probably going to pick one up for occasional small projects. The table they've carried for years gets pretty good reviews for light use.
/ Harbor Freight Tools that don't suck #4,882
Well, I've only had mine since the beginning of the summer, and I haven't seen the ad yet, but mine also folds flat.
I love it, and I even use it as a stand for my HF miter saw, because it is so solid and sturdy.
IIRC, I think I paid $54.99 with coupons.
/ Harbor Freight Tools that don't suck #4,883
I think that's the one that usually on sale for $79 something.
/ Harbor Freight Tools that don't suck #4,884
Just spoke with the manager of the HF nearest me and he says only the table folds flat, not the legs. So there's not been change in design.
/ Harbor Freight Tools that don't suck #4,885
Looks like the legs fold flat to me ... I'm putting one together as I type this. Will post pics shortly :)
/ Harbor Freight Tools that don't suck #4,886
I have a neighbor with an HF generator run by a Honda clone engine. Zero problems in moderate use over three years.
It's easy to disparage HF but Honda did a good job designing these engines and the Chinese seem to do a decent job of cloning them.
In many cases I wonder if both engines don't come from the same factory, but with different labels.
I know with many power tools that is the case.
Same goes for lawn mowers and snow blowers.
/ Harbor Freight Tools that don't suck #4,887
Thanks, PhysAssist and Hutchman. That would be a nice improvement for my occasional usage. I'm betting the store manager just looked at the display model that's been on the floor for a long time. The earlier ones used through-bolts at the cross gussets, so removing them every time to fold the legs would be a hassle. The artwork in the new ad still shows through bolts, though.
/ Harbor Freight Tools that don't suck #4,888
At this price ... it definately does not suck. Even the regular $79.99 price is OK ... with 20% super coupon you can get real close to this super coupon which runs out at the end of the month:
The legs do fold flat. Here is a picture after I got it together:
And they are expandable! (collect them like special McDonalds cups!):
The manual (specifically the parts list of what you should have and how many of each) does suck. The parts didn't match the item count. The pictures and assembly text is OK but you end up with extra parts. I ended up with four large washers extra and two small bolts. The big washers looked like the same size/diameter as the plastic handle to tighten the table angle so I used one between the plastic and the raised copper looking washer that engages the table tilt bracket ... so then I was left with two extra large washers and two small bolts.
You are given two types of nuts that are the same size. I used the lock nuts on the leg assembly and the table tilt because you want these tight but not so tight the tilt bracket can't move or the legs to fold. I used the 4 non-lock nuts on the bracket that holds the table to the stand as that you can torque tight.
... I'm off to go buy another one at this price before all you guys go buy them all up! ;)
/ Harbor Freight Tools that don't suck #4,889
Hey Hutch, I have been eyeing them for a long time and pulled the trigger on one today along with a rolling stand for my HF tile saw. I noticed a couple of minor issues on the display unit at the store and made some slight mods to mine during assembly this afternoon. We lost power so I was working in daylight only. Did finally fire up the generator so I could turn the overhead shop lights on!
I found exactly the same thing as you. Parts list wrong. Same extra parts, etc. as you. I used additional washers I already had so I put washers under head and tail side. I also made a couple of bushings to fit inside the tube so the tube wouldn't collapse when attaching the swivel plates. Used locktite on the four nuts connecting the table to the legs. For some reason those were not nylock nuts. Legs do fold!!! Pretty dang sturdy for $59! I also noticed too that they are expandable so I may get another one and tie them together. It is supporting my cutoff saw at the moment.
/ Harbor Freight Tools that don't suck #4,892
I posted some pics of it in action tonight http://www.tractorbynet.com/forums/...ions-please-post-post4261938.html#post4261938
I like it a lot!
/ Harbor Freight Tools that don't suck #4,893
First week report for the 3 in 1 framing nailer from HF.. I am not a professional builder, carpenter, any of that "er" stuff and if you are, why are you trolling this thread lol
First it is incredibly cheap (pricewise) bought it for 119 and it goes on sale for 99 in 2 days so I will be going back for that credit
The good:
compared to those I picked up at the local HD it seems to be in the same weight class not much lighter like most cheaper products usually are
Instructions are easy and are on the nail rail of the gun so you don't have to keep going back to printed manual depending on what nails you are using
It misfired only twice, and exactly as described if it gets too low on nails.. Both times while shooting nails upwards and with only 3 nails left in the rail
Used it with both 21 deg and 34 degree 2" , 3-1/4", and 3-1/2" nails.. The 21 deg nails were Dewalt brand bought at HD the 34 degree were bought at HF. It fired both easily
Framed and built most of a one sided barn this past weekend. Will put up pics and a build thread shortly
Extremely efficient on air.. was set at 68 lbs to set 3"+ nails that is 2 lbs lighter than recommended in the manual
The bad
Cannot plunge fire the nail gun.. It has to press and then pull trigger to fire.. Not really a bad thing but I thought it should be able to plunge fire
The grip is a little small (diameter) in my opinion but I cannot tell you if others are larger. Maybe they are all that small? Maybe I have big hands?
Unrelated bad:
Although the nails at HF are much cheaper this time they actually come that way because they suck.. I bought the 34 degree ringed nails and the plastic glue on the ends never melted they pulled fairly easy whereas the dewalt nails that plastic glue seemed to melt when driven in and was much, much harder to remove the nail..
So far a great purchase, time will tell as I have a house to build.. If it survives that then it is a great great purchase
/ Harbor Freight Tools that don't suck #4,895
First week report for the 3 in 1 framing nailer from HF.. ...
Thanks for the great report. I want one!
Does anyone know if the 21 degree (only) full-head nailer is noticeably lighter? They list 9 lbs for it vs 12 lbs for this 3-in-1, but the shipping weights are nearly the same and I couldn't feel any difference in the store.
/ Harbor Freight Tools that don't suck #4,897
I sure hope so :D
Now Tomseller, you miss out on explaining to your wife that the "Clearance" rack means "On Sale" not stay clear of.
(Before you are sent to the car):thumbsup:
/ Harbor Freight Tools that don't suck #4,899
My wife used to think something was wrong with anything that was on sale and would buy what was full price. So, yes, she would "stay clear". It took a long time for her to come around to paying attention to prices.
/ Harbor Freight Tools that don't suck #4,900
You could put my wife--or most women--in a store with no price tags and when they checked out would somehow have chosen the most expensive items in each department. In just in their DNA.
2016 PETERBILT 579 (A60736)
2016 PETERBILT 579...
NEW HOLLAND LB75B BACKHOE (A62129)
NEW HOLLAND LB75B...
2008 INTERNATIONAL DURASTAR 4400 CAB AND CHASSIS (INOPERABLE) (A60736)
2008 INTERNATIONAL...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
1995 HEIL ALUMINUM TANKER TRAILER (A60736)
1995 HEIL ALUMINUM...
