New polaris Side X Side- General
/ New polaris Side X Side- General #21
You state that it's the young guys wanting speed buying cvt UTV's but in reality it's the power companies, construction companies, gas line, town municipal departments......they are buying these for work not for high speed playtime. I rarely ever see an RTV but the few times I do it's principle use it to haul a few to feed animals on a farm or for general transportation around property.
The companies and municipalities you stated buy CVT's for the same reason most everyone else does..........lack of options. Nearly every UTV out there is equipped with a CVT transmission. Name the brands where you can buy anything else? I'm not up on all the latest out there, but I can only think of Honda and Kubota and now the Yamaha YXZ 1000 (which is a pure sport machine).
Would you buy a tractor that used a rubber belt as the primary power source in it's drive system? I'm far from a scientist or engineer, but even a tiny brain like mine can easily find the flaws and weaknesses in this system as opposed to real steel gears or hydraulic pumps providing the power to the wheels.
Polaris, as well as Can Am and Arctic Cat began as snowmobile manufacturers. They saw an expanding market in ATV and Utility Vehicles and found a way to make money year round by using existing technology in their new vehicles. Belt drive systems tend to overheat a lot less in the winter months with cold air flowing over their casings then they do in the heat of the summer. Polaris (and others) have had to put cooling fans for the CVT in some of their high performance models to keep them from heat related failures.
Polaris is also in the process of trying to develop a new drive system to replace their CVTs, due mainly to reliability issues. If the CVT was the be all end all, they would leave well enough alone and just call it a day.
/ New polaris Side X Side- General #22
Yeah, like I said before, in 10 years we'll look back and laugh at the current systems.
If what you own now is serving your needs you bought the right one, regardless of color or brand. In my case my needs changed dramatically and now I rarely use the CVT UTV.
/ New polaris Side X Side- General #23
Post the links to the Claims of polaris developing a new drive system. The snowmobile system is flawless and dependable as can be, like it or hate it, its not going away.
/ New polaris Side X Side- General #24
If you are a Polaris supporter, that should sadden you. They will get left behind if they marry themselves to CVT thru the next few years. I don't see them doing that. They will develop a successor.
A snowmobile's loads on a CVT system are sooooooo much different than an ATV or UTV.
I dont ever see them doing it, but it sure would be cool if they would throw a 5 or 6 speed manual transmission in the General, or any other side by side. Or even a traditional style automatic transmission.
/ New polaris Side X Side- General #26
Yea, my snowmobile has 135 HP and my 750 V-twin ATV has 50 HP.
I have well over 6000 miles on my ATV and the CVT clutch's have never needed anything.
/ New polaris Side X Side- General #27
Bobcat has hydraulic for the 3600 but the 3400 is CVT. Looks remarkably like the Gravely units.
/ New polaris Side X Side- General #28
What is the story on the Gravely? I remember something about them being front half of one and back half of another Polaris model.
I do remember they had the Prostar 570 gas or Kohler diesel.
/ New polaris Side X Side- General #29
I didn't have much success with my 2014 Ranger Diesel belt drive system for a work vehicle and I certainly never abused it IMO. I live in a warm climate, hilly terrain up to 30 degree slopes and never see snow, temperature averages of 30 degrees C are common up to 40 at times. 36 forecast today.
Anyway when using the Ranger diesel as just a people or material, equipment mover travelling at sensible speeds always in low range it worked reasonably well but with some clunky transmission slippage going downhill, that they, (Dealer/Polaris) said was normal, but without any explanation for the clunk??.
Any time I tried to use it for slow travelling type of work such as hours of spot spraying, pulling out long runs of fencing wire etc the belt/clutch system would heat up and make it impossible to shift the transmission without shutting down the engine and giving it a rest for 20 mins or so. Rear axle was popping out of the diff as well. My efforts to remedy this proved hopeless with my local dealer and Polaris AU. Immediately after I bought it new, they were not interested in helping me with it, just kept saying it is normal and a limitation of the machine.
The belt still looked like new and never replaced, worked fine while cool and the ranger was a very enjoyable vehicle otherwise and I liked driving it, but the crudeness of this system didn't make it suitable for my application as I believe that they require a decent amount of cooler air flow to work better. The other issues without a good explanation just made me worry.
So the term "work vehicle" is a bit loose as it depends on what type of work plus in what climate and conditions? So yes no doubt the CVT belt is successful for many, but not others.
I just became too frustrated with the Ranger Diesels belt system, transmission slippage, axle popping out etc., so for my purpose I had to take the fall of about $6K on the Ranger and traded it for a Kubota RTV-x1120D, hoping that the HST should cope better.
I have had the RTV only for a couple of months now and still early days but so far it has been generally superior as a work vehicle for my situation and a pleasure to not have to fight with the Rangers transmission and no other glitches. Heaps of low down hauling power with the RTV's HST and seems to run all day moving around at low speed with no issues.
Not driving on the open road, so high speed is not at all important to me personally although I find it to be quite adequate just the same.
To my surprise, Kubota head office called me this week as a courtesy to ask if all was well, and if I was happy with my RTV, which is good PR. Never got one call from the other crowd even though they knew I was having problems being very disappointing.
Anyway seems like I have my solution for now but yeah it will be interesting to see what they will come up with as a good all round transmission for these vehicles instead of what seems to be just a bit hit and miss from the ATV/quad bike system.
Sorry if I got a bit off topic.
/ New polaris Side X Side- General #30
They all have their pluses and minuses.
For a pure work UTV I would likely go with the hydrostat type transmission. Great for slow speed work, but not so great if you want to do any higher speed trail riding.
CVT- not as good for hard slow speed work, but much better if you want to use the machine for higher speed trail type riding.
/ New polaris Side X Side- General #31
Then you have Honda's DCT (dual clutch transmission) that works spectacular in both work and trail.
/ New polaris Side X Side- General #32
I do mostly trail riding, I've been looking at the new pioneer 1000.
Nice machine and Honda is known for their reliability. I like to be able to fix my own machine long term and higher mileage.
My concern with DCT transmission is the complexity. I doubt I could fix it myself and would need to go to the dealer for an issue.
The CVT transmissions are higher maintenance, but I can fix any issue myself and they are relatively easy to tune. (different springs and weights you can change the stall and shift out to what ever you want for your riding style)
My ATV has CVT , I bought a spare set of low mileage used primary and secondary clutch at Ebay for $250.
I could have a CVT clutch issue, throw in another clutch and be out riding again in an hour.
Repair the broken clutch and have a spare.
/ New polaris Side X Side- General #33
How old is your ATV? I have a 2004 Honda Rubicon that has been to **** and back with an even more complex transmission than the DCT and have spent $0 dollars on its tranny. I can't even count the cost of oil changes because it uses the same oil as the engine. Not saying people don't have problems with the Honda trannies but there is no question it's been bullet proof for me.
The cash spent on my CVT snowmobile are in the $1,000's. Mostly clutch kits and belts. Even though a belt wasn't broke but just slightly worn, I'd need to replace it just to keep optimum performance, but that's ok for a snowmobile, not for a SxS.
It's time for these other manufactures to start expanding (giving more options) with their transmissions other than just the prehistoric CVT.
/ New polaris Side X Side- General #34
My ATV is a 2005 Kawasaki Brute Force 750.
I bought it used around 3 years ago with 1500 miles.
I'm currently at around 6100+ miles. Clutch's have never needed anything yet. I replaced the belt once (around $80)
I can take a shim out of the secondary clutch to tighten up the original belt and rerun it again for thousands of more miles.
/ New polaris Side X Side- General #35
The CVT transmissions are higher maintenance, but I can fix any issue myself and they are relatively easy to tune. (different springs and weights you can change the stall and shift out to what ever you want for your riding style)<snip
I was beginning to think that I was the only out-of-the-box thinker around here! I just bought a Honda Pioneer 500. What swayed me over the Polaris was the shaft drive, fuel injection, and solid state ignition. The "1000" is an awesome machine, but much larger than I can use in my trails and bridges.
I'll pick it up tomorrow from the dealer. They're installing a 3,000# Warn winch on it for me, as well as a few other comfort goodies. I'll post and update on reliability in a year or two.
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
