Adding led lights...relay or not
/ Adding led lights...relay or not #21
I had to go to the fuse box with the front lights as they drew nearly 25 amps. For the rear lights I tapped into the existing wiring since they only drew 3 amps.
25 is a lot, but I bet those lights work really well.
Well....I rummage through a drawer label Truck...and found two relays from a longgggg time ago that I used on some aux lights on a 1979 Ford. So the die is set.
Headlight switch works off key ------> LED switches ------->Fused, relays next to battery --------> LED lights.
/ Adding led lights...relay or not #23
I went with a relay and an aux fuse panel when I installed my LEDs. Love the ability to have the lights on with out engine running for short needs and the key off shutting down the lights. I mounted two switches on the dash, one for the two lights facing forward and the other for the rears. The aux fuse panel allows for easy expansion should I add additional electrical devices.
/ Adding led lights...relay or not #24
Well....
I too am in need of light to "get the tractor to the barn".
I used a Planters Peanut jar (34.5 ounces), ductape and a flashlight to do a "mock up".
The concept
First result
Components
DCL040 20V MAX* Lithium Ion LED Work Light, 110 lumens.
I've got 3 of the 18 watt LED lights that put out 1200 lumens each, but I've yet to mount them on my M4700. I have not tested how long my flashlight will last but it seems a good interim solution since I have two of them and they run for hours off my DeWalt batteries.
I'm presently working on emptying another peanut jar.
/ Adding led lights...relay or not #25
They do. If I have to mow at night my neighbor (300 yards away) ends up closing the blinds so they can still watch TV. I kind of feel bad about that. But on the other hand there is no guessing where you left off. Here is a video walk-around.
I agree that is nice but I am always fearful that a barn cat will turn the dang things on and run down the battery. Has happened several times with the hazards on my old tractor.
Well....
I like how the light is multi-purpose and you can just bring it with you when you close up the barn.
/ Adding led lights...relay or not #26
oh sorry I may not have explained it well... unless your cats are good with keys no issue. With key off, the switches are not powered... with key on, whether engine running or not, there is power to them. One mistake I made was to locate them such that they get easily bumped by my knee. But there is not a lot of real estate on the BX25D dash to mount switches so I guess I didn't have much choice. A pain working in cramped space but I am glad I wired to the ignition switch.
/ Adding led lights...relay or not #27
Gotcha
No, our barn cats don't quite have the key thing down yet.
/ Adding led lights...relay or not #28
The majority of toggle switches will handle 10 amps at 12 volts DC.
A few major brand names will go 15 amps.
That is for the normal size vs the mini styles.
With most LED systems I would not hesitate to switch direct DC without using any relays.
I even switched dual 3" halogen spots with a standard toggle.
I'm back!
Let me add (qualify), I was a licensed aircraft electronic technician and have wired many aircraft as well as designed major modifications.
I have totally re wired passenger aircraft, and completely updated private planes to modern standards.
I held FAA and Cdn DOT certificates.
LED's are a great thing.
Easy on charging systems, great output, fantastic longevity and save weight etc etc.
The current draws are so low that you can use just about any size wire with the only drawback being physical strength of that wire size.
With just about any LED installation you could go 22 g and still be OK. but for the demands of the rugged environment a tractor lives in I prefer to stay with 16g mainly for the mechanical characteristics (or min 18g)'
/ Adding led lights...relay or not #29
I'm back!
22 gauge for just about any installation?
110V 12V
22 5A 5A
20 7.5A 8A
18 10A 10A
16 13A 20A
14 17A 40A
12 23A 60A
10 33A 100A
8 46A 150A
/ Adding led lights...relay or not #30
My L4330 has two 25 watt bulbs in front that are blocked by the RR fishplates weights I put on the front weight bar. I plan to replace them with 2 18 wat LED light bars Amazon.com: Signstek 2*18W CREE LED Flood Light Headlight Work Light Lamp off Road High Power ATV Jeep 4x4 Tractor off Road Light Fog Driving Bar Rree Truck SUV Car IP67 Waterproof Dustproof Shockproof (Black): Automotive.
I don't plan to use relays, just disconnect the OEM lights, tie them directly to the LED light bars. Unless I find that Kubota used rediculously small wiring for the headlights that is. Just in case I bought a couple of these when I bought the LED lights, so I'm prepared either way: Amazon.com: Absolute USA 2 In-line ATC Fuse Holder, 2 Relay RLS125 12 VCD Automotive Relay SPDT 30/40A and 2 SRS105 12 VDC 5-Pin Relay Socket: Car Electronics
Good luck!
Good luck!
Well one of my relays was bad....so I bought the deal you posted. Actually pretty good price considering what all is included.
/ Adding led lights...relay or not #32
JC, you helped me out a couple months ago, glad I could at least slightly return the favor!!!
[beer] (or however you do it.....:(
Hey...it's what this forum is all about. Kind of a go to spot in researching stuff.
/ Adding led lights...relay or not #34
Amp draw on 12v LEDs is very small. IMO no relay is needed. I had 6 50w LED flood lights running on a 24v system on my boat wired on one switch with no relay.
I actually don't think so either, except for the circuit I'm pulling from. It takes little effort to add them, so I'm going to.
Nice bow fishing setup. Many years ago, I was wanting a setup like that. To dang old now.
/ Adding led lights...relay or not #36
I'm surprised by many of the comments about LED current draw. Maybe I'm interpreting what people are saying incorrectly, and if so ignore what I'm about to say.
Watts = Volts X Amps (for DC circuits)
This is true regardless of what type of device you are using. A 55 watt LED draws the same amps as a 55 watt halogen bulb. Size switches and wire gauge accordingly. A 55 watt LED is more efficient and will put out much more light than a 55 watt halogen bulb. Conversely, because the LED is more efficient, it will produce much less heat than a 55 watt halogen bulb.
A 70 watt LED light bar draws 5.8 amps (70 watts/12 volts). A 5.8 amp circuit should use 14 gauge wire up to 10' to 15' wire length. If the wire run is longer you should use 12 gauge wire. Two 70 watt light bars and you should use at least 12 gauge wire up to about 15' of wire. These recommendations vary slightly depending on the source, but you can see that just because it's an LED does not make current draw and wire size insignificant.
Get this wrong and you could get lucky and have no problems or you could melt a wire, short it and blow a fuse. Although unlikely, the worst case scenario of undersized wiring is a fire. Please don't assume just because it's an LED fixture that it doesn't draw much current.
/ Adding led lights...relay or not #37
To add to my previous post, 6 50w LED flood lights draw 12.5 Amps on a 24 volt system. In a 12 volt system, these lights would draw 25 Amps! That's a lot of current. Better plan for it.
/ Adding led lights...relay or not #38
Watts / Volts = Amps
72 / 12 = 6
36 / 12 = 3
So with all of the lights you are looking at you will only be at 12 amps. The switch will handle it just fine. Now the trick will be finding a circuit on the vehicle that will handle the extra draw.
I like to take the draw back to the fuse box where you might be able to tap into an empty lug on the switched side of the box. Mind you, I'm not tapping into a fused circuit, I'm going to the main bus bar. The new line needs an in-line fuse.
I used these switches on my tractor light install. I had to go to the fuse box with the front lights as they drew nearly 25 amps. For the rear lights I tapped into the existing wiring since they only drew 3 amps.
Wow! That's a lot of forward facing light on that ROPS! 25 amps on 12volt LEDS will give you ~20,000 actual lumens. Or about 10x brighter than your average car head lights. Does it ever blind you if you turn around with the front lights on?
/ Adding led lights...relay or not #39
I just installed 4x18 watt LEDs today. The tractor had a 10 amp "work light" fuse with wire terminating at the rear of the tractor. I wired 2 x 20 amp rated toggles each running 2x18 watt LEDs (2 front 2 rear). Each switch will only ever see 3 amps (36 watts for 2 lights divided by 12 volts). I don't see any possible way to fry the 20 amp rated switches or hurt anything upstream of the 10 amp fuse with 3 amps per switch and 6 amps total going through the fuse. If there is a short causing a current spike the fuse should blow before the switches. So I did not use a relay.
However, this thread got me thinking... I'm don't know much about this stuff, is there any benefit from adding a relay in my situation (as described above)? If so, I can't think what that benefit would be so help me out!
/ Adding led lights...relay or not #40
This is a good point. DC systems have significant voltage drop as length of run increases. There are charts available to help calculate. I use a book on marine DC wiring.
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
2003 Ford F-350 4x4 Crew Cab Flatbed Truck (A66736)
2003 Ford F-350...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
