Pouring concrete under water
/ Pouring concrete under water #45
I think the OP said he dug the hole and then got 3" of rain, which filled the hole.
/ Pouring concrete under water #46
I had a similar problem one time, came up with the idea to use a shop vac to suck the water out, worked quite well, cleaned out the bottom too, making the holes back to their true depth. It ended up too slow for the number of holes I was doing so the second half I just poured the concrete in. It seemed to work and push the water out. I have no idea of the long term strength of either they were piles under a concrete ramp/walk up to our front door. Nothing shifted before we moved anyway. I have used to shop vac technique a few times now to clean out the debris at the bottom of the hole to get a few extra inches of depth when putting in posts (we have a fairly deep frost line here approx 5-6' to be safe.)
/ Pouring concrete under water #47
Concrete under water is not a problem, but yes excessive water in the mix will result in a degree of weakening of the strength of the concrete. Adding additional Portland cement into the mix will alleviate that. about 20% increase of cement is fine to get 5000 lb mix, despite water in the hole. Rebar will corrode and the rust will, over time, destroy the column of concrete. Addding pozzolan (fly ash) to the mix will slow that process, but will not stop it. I would not put rebar in the column for this reason, but I would consider adding glass fibre to the mix. I would also use crushed rock and not pebbles..
/ Pouring concrete under water #48
For crying out loud, it's a fence post with a duck box on it.
/ Pouring concrete under water #51
Anyhow, the usefulness to the OP and his duck house might be done, but its still fun to talk about stuff just to learn how its done. :)
UPDATE
Duck house successfully installed. Appears to be good and steady. This is a heavy Duckhouse. House probably weighs 25 lbs and post is 3" heavy duty galvanized pipe 9ft long. Hopefully duck will talke up residence this winter. Thanks to all who offered suggestions.
/ Pouring concrete under water #53
UPDATE
So did you just dump in the mixed concrete in to push out the water or what? Inquiring minds want to know:)
Yes that's what I did.
/ Pouring concrete under water #57
All this and no PHOTOS???
/ Pouring concrete under water #59
Yup, late to this thread, but reading through it was worthwhile just to see the ideas. :thumbsup: Have never had to pour underwater, but I'm a bit smarter now if I do.
Looking forward to a pic, with or without a happy wood duck.
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
1987 Chevrolet Pickup Truck, VIN # 1GCEV14H1HF371433 (A65563)
1987 Chevrolet...
1/4" Quick Attach Blank Plate (A66408)
1/4" Quick Attach...
14' Cultimulcher (A66408)
14' Cultimulcher...
