Pouring concrete under water
   / Pouring concrete under water #42
   / Pouring concrete under water #43
Hey, it wasn't misspelled. :laughing:
I corrected my quote, too. ;)
   / Pouring concrete under water #45
I think the OP said he dug the hole and then got 3" of rain, which filled the hole.
   / Pouring concrete under water #46
I had a similar problem one time, came up with the idea to use a shop vac to suck the water out, worked quite well, cleaned out the bottom too, making the holes back to their true depth. It ended up too slow for the number of holes I was doing so the second half I just poured the concrete in. It seemed to work and push the water out. I have no idea of the long term strength of either they were piles under a concrete ramp/walk up to our front door. Nothing shifted before we moved anyway. I have used to shop vac technique a few times now to clean out the debris at the bottom of the hole to get a few extra inches of depth when putting in posts (we have a fairly deep frost line here approx 5-6' to be safe.)
   / Pouring concrete under water #47
Concrete under water is not a problem, but yes excessive water in the mix will result in a degree of weakening of the strength of the concrete. Adding additional Portland cement into the mix will alleviate that. about 20% increase of cement is fine to get 5000 lb mix, despite water in the hole. Rebar will corrode and the rust will, over time, destroy the column of concrete. Addding pozzolan (fly ash) to the mix will slow that process, but will not stop it. I would not put rebar in the column for this reason, but I would consider adding glass fibre to the mix. I would also use crushed rock and not pebbles..
   / Pouring concrete under water #48
For crying out loud, it's a fence post with a duck box on it.
Skidloader Bucket W/Hydraulic Attachment (A50774)
Skidloader Bucket...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
UNUSED JCT QUICK ATTACH 84" GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
Wolverine 72" Skid Steer Bucket (A50515)
Wolverine 72" Skid...
Homemade Head Cart (A50514)
Homemade Head Cart...
