Grapple bucket for SCUT?
/ Grapple bucket for SCUT? #1
Fiziksgeek
Oxford, CT
Massey Ferguson GC1720
Hey all. I currently have a Massey Ferguson GC2400 and I'm interested in adding a grapple thumb to my bucket. I don't need it a lot, so I have trouble justifying a full grapple, I also have a pin on bucket. Adding a "thumb" to my bucket seems like it would be sufficient for moving small amounts of brush, an occasional log, etc.
I've done some searching, but the smallest bolt on grapples I have seen are ~150lbs and up. I'd like something under preferably under 80lbs. Anyone know of a company out there manufacturing small bolt on grapples?
I guess the lack of replies means there are many (or perhaps aren't any_ options out there. About the smallest I have seen is from Precision Manufacturing, which weights in at 125 lbs, which is still a bit heavier than I would like.
/ Grapple bucket for SCUT? #3
I just put one of these thumbs on my Kubota B2920. I bought the 20" and it bolted right up easily and works great. I believe the shipping on the thumb was like 63lbs. Shop Online
/ Grapple bucket for SCUT? #4
A thumb would definitely be better than nothing, but a Wicked Grapple would be the cat's meow!
I sold one of our 50" Wicked Grapples for a Massey DL100 pin on loader yesterday.
It weighs 255 without the lower intermediate slats installed and 274 with them.
Travis
/ Grapple bucket for SCUT? #5
Travis
<snip>
An important consideration for us small tractor owners is how much does an entire package (attachment method, equipment) weigh compared to what we have.
Your pin on Wicked probably weighs about the same as his bucket. I think that's about what the bucket weighs on my B7610.
/edit -
And to the OP -
Do you have pallet forks?
With a $149 pair of clamp on pallet forks and a chain or two I was able to get sort of a "poor man's grapple" which greatly assisted in clearing 1/4 acre of brush and bamboo.
Thanks for the responses. I'd love a full grapple, but I don't have a quick attach bucket..and Massey doesn't offer one, at least not yet. There are aftermarket solutions, but they are more cost, and push the weight out several inches. Considering my infrequent use, I'm looking for a low cost option, so The Thumb looks like a great option!
/ Grapple bucket for SCUT? #7
I wouldn't hesitate for a minute. I've used a full grapple for ten years and couldn't live without it. A bucket grapple is not as efficient but is 100x better than a standard bucket for handling brush and similar debris. I haven't looked recently but I'm pretty sure there are easily installed kits for the BX. You'll need to either add a set of rear remotes or a diverter valve to control it.
/ Grapple bucket for SCUT? #8
I have pallet forks and a real grapple. The pallet forks are a huge improvement over the factory bucket, but the grapple is still vastly superior for moving brush. A set of pallet forks with a thumb would be a good compromise, but still not nearly as good as a real grapple.
/ Grapple bucket for SCUT? #9
Since the OP has a pin on bucket, I'd vote for the add on thumb/grapple. That lets him keep his bucket for hauling loose material. And BAP gave him a great source.
If he were QA I might vote for an open grapple to swap back and forth with the bucket.
I built a Grapple onto a Bobcat low-pro bucket. I have the best of both worlds.
/ Grapple bucket for SCUT? #10
I did this to a Kubota BX 2200 scut with great results. Electric diverter valve from KBOH and the thumb from greens machine. Worked very well.
/ Grapple bucket for SCUT? #11
Trying a picture.
/ Grapple bucket for SCUT? #13
I have a pin-on bucket on my L3010 and put a bucket grapple and tooth bar on it. I find it very functional and use it all the time. The thumb types and the API I have don't weigh much. You loose a little lift weight but gain a whole lot in added capability. I work on woods roads and like having the bucket and grapple on all the time. Dirt, rocks, gravel, stumps, brush, or whatever, makes no difference - I can move it w/o changing anything.
gg
/ Grapple bucket for SCUT? #15
Another vote for Green's Machine Thumb;do reinforce the top of your bucket and a tooth -bar makes it more versatile.
/ Grapple bucket for SCUT? #16
/ Grapple bucket for SCUT? #17
Can you curl the loader at the same time you close the grapple?
He cannot because he switched the hoses for curl/roll to the grapple. However, that is a very clever compromise especially for cleaning up debris or moving logs etc. Yes he loses the ability to come down on a load from the top but he has $600-1000 bucks in his bank account that the rest of us don't.
/ Grapple bucket for SCUT? #18
I would hate to give up the ability to curl it the same time. I curl and close the grapple all the time. He has more than that in his bank account that the rest of don't because he saved the price of a real grapple.
/ Grapple bucket for SCUT? #19
I used it to move large piles of bush to a burn pile, and lift logs for loading on a trailer and cutting with a chainsaw. It was a little hard on the trailer as I couldn't roll the bucket to avoid dropping the log from a foot, but no big issues. Would buy another in a heartbeat. Weight around a hundred pounds.
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
John Deere 6000-Series Tractor Loader Frames (A65640)
John Deere...
