Welding table top?
/ Welding table top? #1
Piper2022
Poland, ME
New Holland 1920
I am about to build a welding table and would like some opinions. I plan on building some steel furniture such as table frames so 4�8 is the size I am planning on. I am thinking 2肺4 3/16 members under as a frame to keep it straight and (6) 2肺2 tubing as legs. Does that sound reasonable? I want it to be stiff enough that I can use it for projects other than welding.
So my real question is what to use as a top. I know there are a bunch of threads over the years with people discussing different top thickness. Some say 3/16 to 1/4" and some say 1/2" to 3/4". I was thinking 3/8 would be more than enough for what I am doing with it. My only concern is how flat are the sheets of 3/8 and 1/2" plate at most steel supply shops? If I use 3/8 the frame should be able to straighten it out a little. But I feel like if I go too thick and the sheet is not flat I am going to be stuck with it forever.
I have never had to purchase a full sheet of plate this thick before so I am unsure the over tolerance. Any input would be great.
/ Welding table top? #2
The way I did mine was based on a welder friend's advice, which took into account the limited space I have.
He suggested building steel saw horses, which I did, and just setting a steel plate on top, which I also did. That way, if I needed the space, I could simply take the plate off with the forks and just leave it on the floor and move the sawhorses off the side, or even outside.
I ended up going pretty heavy on the saw horses, wanting them to be capable of supporting significant weight ... I used some 3/8" x 2" or 3" angle as I was buying standard 20' lengths and had a use for that size on another project.
For the cross member connecting a pair of legs together, I used a couple of pieces of 3" x 2" x 1/4" wall rectangular tube I had here from another project that got aborted. I think they were 5' long - because I had a 10' long piece to use, and so they could be set in the long direction under a 4' x 8' piece of plate. 1/4" steel for bracing and foot pads.
I can drag them around by hand, but they aren't anything I'll be picking up and carrying.
For the top I got a 4' x 8' piece of 1/4" plate ... mainly because I had a need for that thickness on another project, the price was right, and picking up a 4' x 8' plate long-ways with the tractor, 1/4" was probably all it was going to be able to do, with the load sticking out 8' from forks.
After cutting off the steel for the other project, I now have a table that is around 4' x 5'.
I positioned the saw horses for the best support and then used shims to get the table as level as possible.
Cool, I like your idea of being able to tear it down and use the space for something else if needed. I would build it that way but my plan now is to build a big shelf under it and store my mig and tig on. As well as most of my other non combustible welding supplies and tools. I think I am going to go for 3/8 plate mainly because its about as think I feel I can attempt to straighten if it needs it.
I was going to try and find some rugged casters and put my table on casters. However the garage floor is not that flat so pending the stiffness of the table the location of the floor might rack the table around some. I don't want to have to shim it every time i want to move it.
/ Welding table top? #4
When I built my 4'x8' table I considered 5/8" or 3/4". Just couldn't justify the price. Cheaped out using 3/8"for the top thinking if I ever needed that thickness for another project I could use it and upgrade the thickness for the table.
That was 3 years ago and I'm happy with 3/8".
And you are correct in the fact that it is really easy to achieve a flat surface using that thickness. A couple of welded nuts and you can push or pull to get it pretty near perfect. (based on lax Big Barn tolerances)
Terry
/ Welding table top? #5
The only reason INHO that you need to go thicker than 3/8's is if you want to be able to get things straight by tacking it to the table and hitting it with a sledge. i worked in a stair shop and our tables were 4 x 16 x 1/2. It was wonderful to be able to hit things with a sledge and not worry. If I were to build a welding table I would live to go 1/2" thick but with money the way it is it will be 3/8's. Ed
I was quoted $225 for 3/8" and $295 for 1/2" in 4x8', sound reasonable to you guys?
/ Welding table top? #7
Yes. I paid $200 Cdn for 4x8 x.375 for mine 3 years ago.
Terry
/ Welding table top? #8
Steel plate is selling at the lowest prices I've seen since the 90's. Just bought some 1/4" plate for .28 cents a pound. Having built numerous different versions of welding tables over the years, I'd encourage you to go with as thick of plate as you can afford. If your table is going to be mobile, that is, if you are going to put casters on it to move it around, then 1/2" or less makes sense. This would most likely be stretcher leveled plate which is usually fairly flat. If it is not going to be a mobile table, go for the 3/4" plate-you will not regret it one bit. Six to ten inch channel iron on edge will go a long way for taking any curvature out of the surface.
/ Welding table top? #9
Look around some more. .35 to .40 cents a pound would be reasonable right now for a single sheet.
/ Welding table top? #10
Yes ... although I haven't priced lately.
I paid $180 for my 4 x 8 sheet of 1/4" last fall.
/ Welding table top? #11
Prices prolly vary region to region, also. Earlier this summer I was paying $1 a pound. :(
Terry
/ Welding table top? #13
For that price I WOULD HAVE 1/2 IN!!!! It is worth it. Ed
I agree. $70 over the lifespan of that table is nothing. My table is 4x10 and 1/2" thick. I am totally happy with it. Never felt I needed thicker but am not sure I would have been happy with thinner. I am pretty rough on it at times.
/ Welding table top? #14
I have a 5 x 10 welding table framed in 11ga 2" sq tube. I used a 5 x 10 piece of 1/8" tread plate (smooth side up) for my table top and it's been plenty for me. I hammer on it with a 3# sledge all the time without any problems. The tread plate was never perfectly flat but it's flat enough for me.
/ Welding table top? #15
I guess it all depends on your intended uses. I tack weld stuff to my table top to keep it square, set heavy things on there using my skid steer, etc. and need the thickness. I use my table almost daily and I can't see myself ever wearing it out or damaging it. The weight of the thicker plate is a great benefit as well because my table is rock solid. I have a heavy duty vise mounted on the edge and I can put things in there and beat the snot out of them or use big pipe wrenches with cheaters and the table does not move.
Years ago I worked in a shop that had a table top made out of 1/8" material and it was bowed down around all the cross members and looked like the side of a car that had been through a demolition derby. Then again if you are just doing light duty stuff on a hobby type basis and are not setting anything on it that you can't lift up there by hand then thinner might be ok.
When I built my table it took me a couple days. My time and the work involved is far to valuable to have to do it again over saving $1-200 on materials. I think when I built mine I paid nearly $400 for the top plate but that was when steel prices were much higher. If you can get a thicker top for $270 don't skimp.
/ Welding table top? #16
I use mine every day also. I have jigs welded to it to keep my hog traps square as I build them but don't tack my work to it. It's been 3 years now and it's holding up well. I cross-braced the top at 24" on center though, so it's got a lot of support underneath it.
/ Welding table top? #17
With the dropping steel prices go as thick as your muscles and wallet can afford. At 4x8 I expect your muscles may be the limiting factor.
Don't dismiss the logistics of moving it around. Half inch at that size is about 653 pounds.
When I went for a table top last year I got a 4x2 piece 5/8 thick and that's fairly heavy for me, about 200 lbs.
As far as prices that hunk cost me $0.65/lb last year, now it's down to $0.45/lb. So far I've just set it on an upright 55 gallon drum and use it as a worksurface.
/ Welding table top? #18
Hi,I've got a 5x10' table and have used the same 3/8ths top for ten years now.I used 2" tubing with 2x3" square stock for support,1' from the edge and one across the center.It's worked out great.
I welded a 2x10" box under it far enough in for all my ground clamps.Out of the way but easy to get to.I was afraid to put my welders under it,dust,moisture,mice and mud dobbers,etc.I'll blow a plasma cutter hole through it every now and then.I've never noticed it flex or bow.I've set a Miller Dynasty 350 and a big block chevy on it at the same time.
/ Welding table top? #19
You're too far away for this deal, but this is what my top was made of. I really like it.
1/2" steel plate
/ Welding table top? #20
1/2" steel plate
Thanks for the tip. Gotta go to Des Moines tomorrow. Might be getting me a welding table top. Thanks Tiller!!!
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
2015 PETERB/ILT 320 6X4 T/A GARBAGE TRUCK (A66091)
2015 PETERB/ILT...
CAT 613B Transmission (A68134)
CAT 613B...
2014 Ford Focus Hatchback (A66738)
2014 Ford Focus...
2019 Deere 35G (A64911)
2019 Deere 35G...
2012 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2012 CHEVROLET...
