Lynch Pins
/ Lynch Pins #21
Your application requires a rod to go through the hole and be fastened on both ends so it does not fall out.
I expect a 20D nail bent at the bottom would do.
You could take a suitable size bolt and drop it through the hole and put a nut on the bottom.
My M4700 uses a clevis pin with hitch pin clip at the bottom.
It;s not brain surgery.
/ Lynch Pins #23
Bolt & cotter pin. Drill hole in bolt or use nylon locknut.
Opps, already mentioned.
/ Lynch Pins
Once I lose, or break :), the pins I have I think I will either use the pin on the left in my first post or a straight pin and a hairpin type clip. The original pin can not be sourced locally except at the dealer for much more than I al willing to pay. Thanks guys!
/ Lynch Pins #25
I replaced both of mine with a straight pin/hairpin clip (wire anti-losing strap crimped on).
This was as a precaution... the originals just didn't look robust enough to handle the stresses of rotary tilling or the water-filled roller.
/ Lynch Pins #26
I'd use these, at the correct size for your application. They are what came on my Kioti from the factory.
Amazon.com: 1 X Lynch Pin 3/16": Industrial & Scientific
PS. Any chance of you shooting us a pic of the actual application- where the pin needs to go- I'm thinking there might be a different pin that better suits your application, if it's where I think it is.
Thanks.
Those won't work. The bail is bent and formed to go around the body of the turnbuckle if his is like the "John Deere" thumbnail.
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
PALLET W/ FAN, CHAIN SAWS & MISC PARTS (A64278)
PALLET W/ FAN...
2022 EZ-GO ELITE...
2018 Kia Rio Sedan (A64557)
2018 Kia Rio Sedan...
2022 EZ-GO ELITE...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
