My NX6010
/ My NX6010 #961
I suspect in this instance you are correct. I am just saying an academic center (especially in July) is often a very frightening place.
If I needed a lumbar epidural steroid injection or my gallbladder out, an academic institution would be the last place you would find me!
But we digress...
Agree. I live within ten miles of a half dozen very famous hospitals but if I need my appendix out I'm heading for the local community hospital.
/ My NX6010 #962
I guess it depends what I was being treated for. Had an ACL reconstruction done this year. Went to the guy who does the most in my city and does lots of college and pro athletes. I'm walking and climbing stairs. Ain't running yet but glad I ain't on crutches either.
/ My NX6010 #963
We should start a new thread and consulting service: 'Medical advice from know-it-all tractor guys.'
:confused3: :laughing:
/ My NX6010 #964
Wouldn't be the first time I've checked TBN for info on non-tractor questions! :laughing:
/ My NX6010
FWIW, I had my ACL replaced with a dead guy bit graphed into my own bits and a couple of wood screws back when I was 18 by Pat Smith. Pat does did high level amateurs and pro players and so forth and is the most laid-back medical pro I've ever met (his story of his own knee getting replaced is hilarious). Back when I had my ACL replaced it was a really evasive and I have two 6" long scars. Roll forward 30 years and I still know and talk to Pat from time to time and the knee is super except for the now torn upper meniscus. The only real downside to my ACL reconstruction is that the knee cap is forever-more tender and for the first decade I couldn't knee down. Now I can knee down but only with a pad. All in all, a good outcome and best practices has changed so the procedure is less evasive since my ACL. My ACL carried me through the Army, hours of jogging, piles of mountain biking and more.
/ My NX6010 #966
I don' know about less invasive. Mine involved taking a graft from my patella and then drilling holes thru the femur and tibia to attach it. I'm sure techniques have improved in 20 years but It still sucked. On a positive note, I spent yesterday and all of today walking around the woods on my land, scouting, hunting, and cutting trails. knees hurt but they worked.
/ My NX6010
Back to tractor talk. In the middle of packing and moving a house 200 miles and making it to a November 12th closing on time, I checked Craig's List and found an old McKee Sno-Lander 720 for sale. McKee, an old Canadian company, was the first company to offer the modern twin auger tractor snow blower. The McKee 720 Snolander is a CAT2, twin-auger, seven-foot-wide, 30ish" high snow blower with a hydraulic shoot and I agreed to purchase it for $900. The price is cheap because McKee got bought out of business and parts are not available. Even so, $900 seems like the lowend of the price range when I checked pricing on TractorHouse.
I had the guy I'm purchasing the blower from power it up with his 40hp Ford tractor so I could see everything work as well as to check that the augers where straight and bearings good. The only specific part to McKee are the augers and 90 degree oil-bath gearbox and so I figured I can fab anything that breaks if it turns out that I really like the blower.
/ My NX6010 #968
What?! You break something?! Never!
/ My NX6010 #969
Looks like a good deal, Eric. :thumbsup: Do you plan to modify it to use with your quickhitch, or just remove the QH as necessary?
/ My NX6010 #970
$900 for a functioning snowblower is a great deal. If you can fix the Kioti then the snowblower should be easy.
/ My NX6010
I don't think I'll have time to fiddle with making it quick hitch compatible before it gets too cold, and so my plan for now is to drop my quick hitch and mount the blower as is.
/ My NX6010
I'm happy that it has hydraulic shoot rotation, but wondering why it doesn't have a hydro on the deflector like the blower in the photo below.
/ My NX6010 #973
If the gearbox goes out, it looks a lot like the one on our Loftness. That has a straight through shaft for the impeller and a 90 degree shaft for the cross auger. They are still in business, so it may still be available.
Aaron Z
/ My NX6010 #974
Pretty simple project to add if you have enough remotes.
I thought you were moving snow on your lake land. The deflector would be necessary in the suburbs but not so much in rural areas.
/ My NX6010 #975
He doesn't have the remotes, not unless he unhooks either hydro top or side link. However, I do agree that it doesn't seem much of a project. Eric has fixed much bigger things before.
/ My NX6010 #976
He doesn't need the side link while snowblowing so that is the remote I'd use.
/ My NX6010 #977
If I'm remembering correctly, Eric installed three sets of remotes, didn't he? (Eric, we'll sort this out for you amongst ourselves, no worries! :laughing:)
/ My NX6010 #978
Yeah, and if you don't have enough remotes we'll design a simple manual Y valve for you so you can switch from one implement to the other. We got this!
/ My NX6010 #979
That's what we do best here, solve other peoples problems while spending their money:thumbsup:
/ My NX6010 #980
You can make all the remotes you want with these stackable electric/hydraulic valves. You use your OEM SCV for control.
you can stack 3 of these in a stack, making 4 sets of remotes including the pass thru when no valve is selected electrically all fed and controlled from one of your stock OEM remotes. So if he had room on the back he could have 12 remote sets with the 3 stock remotes as the feeds. There now.. that ought to satisfy the most remote hungry guy on the planet.:laughing:
CONSTRUCTION 4 ATTACHMENTS-XTREMEDUTY 48" FORKS (A62130)
CONSTRUCTION 4...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
UNUSED 44" HYD MINI ROCK GRAPPLE BUCKET (A62130)
UNUSED 44" HYD...
Caterpillar 289D (A62180)
Caterpillar 289D...
