Tractor and Slopes
/ Tractor and Slopes #1
Billrog
Armstrong, British Columbia
Kioti 2610, 580 SuperM Case Backhoe
Since joining I've seen a few comments on slopes so today I decide to check a few of the slopes I drive on nearly a daily bases. There is one I have to have something in the front bucket to keep the front wheels on the ground but it's been raining so I never checked it out to see the max. slope the tractor will climb.A couple are my driveway and a few of trails that I use there are approx. 5 miles of trails 70% are just slight grade to med. so this is only a small sample.
Took this pic. so you could see it's actually a trail.
The trails in this area I cleaned up to use from horse logging around 1945.
When working on these hill sides there's a good chance you won't get a second chance if your careless & you should get to know your tractor very well before tackling steep slopes. In some of the open areas I'm able to log without trails.
/ Tractor and Slopes #2
Wow, those are some serious slopes! Be careful. That looks like a perfect place for a Ventrac or Steiner.
/ Tractor and Slopes #3
A digital level! I was expecting a protractor and a plumb bob.
/ Tractor and Slopes #4
That's a interesting thing to do. Lets you see where you fit in. I like your % angle meter. I just have a clinometer on my compass. Works like a plump bob against an angle gauge. It is only 4" long so not to accurate maybe the way I just hold it up and sight along the slope. I never thought of just putting it down on the floor boards...DUH.
You have some steep ground there.
gg
/ Tractor and Slopes #5
When it comes to slopes I can relate to degrees better than percent of grade.
Here is a chart that helps visualize the slope.
Here is my wife's Toolcat with the 7' brush hog on the front, on a 50% side slope.
Note the body lean compared to the tops of the tires.
/ Tractor and Slopes #6
If you have a smart phone, there is an app,,
/ Tractor and Slopes #7
I don't understand the display of 25 degrees? The red pointer is on 15 degrees and that looks right.
/ Tractor and Slopes #8
I don't understand the display of 25 degrees? The red pointer is on 15 degrees and that looks right. <img src="http://www.tractorbynet.com/forums/files/owning-operating/445755-tractor-slopes-degrees-jpg"/>
It's hard to tell from the crumby picture, but the display number is percent, the red pointer is referencing degrees.
/ Tractor and Slopes #9
Here is better pic.
/ Tractor and Slopes #10
Ok. :thumbsup:
/ Tractor and Slopes #11
I mounted a lev-o-gage on my dash so I could check anytime while running on slope.
/ Tractor and Slopes #12
does the lev-o-gage tell you anything while going up or down slope?
/ Tractor and Slopes #14
I get the measuring but how do we know what is safe and the max amount we can go?
/ Tractor and Slopes #15
I don't know about others but I have sensors in my butt that determine how far I will go.
When the wheels on the high side start coming off the ground I know it's to steep.
/ Tractor and Slopes #17
when the wheels on the low side lift up i know its too steep also:))
/ Tractor and Slopes #19
How accurate is that? Amazing at how many things phone apps can replace. Not that I would build a house with one, but I might hang a picture with one.
/ Tractor and Slopes #20
I do too and mine are set real low. I keep my loader dang near on the ground when I do have to go up a steep hill.
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2015 Ford Transit 350 4x4 Sewer Viewer Van (A61573)
2015 Ford Transit...
Challenger 65-85C Tractor Service Manual (A63117)
Challenger 65-85C...
1076 (A64280)
1076 (A64280)
