Stihl MS-261CM or Husky 550XP?
   / Stihl MS-261CM or Husky 550XP? #21
Do you have to change sprockets to go from a 16 to 20" bar on a 550xp?
   / Stihl MS-261CM or Husky 550XP? #22
IF you also change the chain pitch, then yes... IF you don't, then NO...
I wanted 3/8's chain, so I changed out the stock sprocket, to a sprocket for 3/8's chain ...
That's the same thing you would have to do with any brand of chainsaw...
SR
Sawyer,
Luke might be asking about the size sprocket, not the pitch. Way back in my logging days when we ran 266XP's, I believe we changed to a different size sprocket so you'd still have torque when running a longer bar. I'm not sure if that's still possible.
I have a 550XP with both a 16" bar and a 20" bar. I stay with the same sprocket and don't get as aggressive when using the 20" bar. The 16" bar is well suited for the available engine torque and a 55cc saw. An 18" might be just fine too. I bought the 20" for the occasional stump flushing and don't use it often.
   / Stihl MS-261CM or Husky 550XP? #24
On my 550xp, I went from a 20" bar, .325" chain to a 16" bar, 3/8's" chain, both with 7 pin sprockets. I HATE .325" chain, so for me, I see going to 3/8's as a HUGE improvement and I like the way my saw saw works MUCH better now.
SR
   / Stihl MS-261CM or Husky 550XP? #25
IMO 3/8LP is best on a saw this size or smaller.
   / Stihl MS-261CM or Husky 550XP? #26
If you haven't tried 3/8's on a 550xp, don't knock it! This saw runs full 3/8's with ease!!
I sawed out and cleaned up some logs with it today, and it just screamed right through them!
SR
   / Stihl MS-261CM or Husky 550XP? #27
Big fan of my MS261. Can't fault it at all.
   / Stihl MS-261CM or Husky 550XP? #28
SR
I don't have a 550XP and I'm not knocking 3/8. 3/8 would be my second choice. Lo Pro is faster on a smaller saw.
   / Stihl MS-261CM or Husky 550XP? #29
SR
Nice looking saw!
   / Stihl MS-261CM or Husky 550XP? #30
What saws should I look at in the 60cc range?
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
Mini John Deere Truck (A55853)
Mini John Deere...
2014 Grove TMS700E 60 Ton Hydraulic Truck Crane (A60460)
2014 Grove TMS700E...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
