Hay Flat
/ Hay Flat #1
derekuk101
KY
M5-111, M8540, M4900, Ford 3600
We are building a metal hay flat with 10 inch channel as the sills and 3 inch channel as runners every 24 inches. The top will be treated 2x8s. Question is can you still bolt this set up to the running gear or should we use a chain or cable one on opposite corners? If we bolt it I'll use a grade 8 on opposite corners. Wagon is 20 feet.
/ Hay Flat #2
What do toy mean chain or cable? ? Only thing I have ever heard of is bolting. Just make sure you have heavy enough running gear.
Have you tought about making it a trailer? ?
/ Hay Flat #3
Not sure what you mean as well? My neighbor cut and baled a field for me a few days ago. He round baled some and square bales some for me. He came by today to pick up his round bales with a homemade wagon. Not having a loader, he used a 3pt bale spear. I stood by the home built wagon while he ran back and forth. After it was all said and done, we stopped to chat.
His wagon, which he had not built was to high. He had to park it in a swale to load it. Just one of those situations where you home build something but would do it differently the next time I guess. He also said that this wagon was not wide enough for his baler that makes 5 1/2 foot wide rolls. I suggested adjustable cross members where you could pull a pin and slide out your crossmembers to accomadate two wide bales.
Nothing like a experiance and a good imagination to home build a better rig.
/ Hay Flat
The running gear is rated at 8 tons. I just want to make sure it has enough to flex if it needs too.
/ Hay Flat #5
Our wagons are bolted on all 4 corners with grade 5 bolts. Thats stronger than the wood and I doubt it will be a problem.
Aaron Z
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
PATRIOT 5100 ELECTRIC CAKE FEEDER (A64277)
PATRIOT 5100...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
DMI Rear Bumper (A65640)
DMI Rear Bumper...
