B2782 Snow Blower modifying
/ B2782 Snow Blower modifying #1
bumperm
Gardnerville, NV
Kubota B3350 cab & BX24
Ultra High Molecular Weight Polyethylene (or UHMW PE for short) is the strongest long chain polymer plastic available. It is also blessed with a coefficient of friction that rivals Teflon. Thus it is particularly suitable for high wear and abrasion applications where slippery is good too! Snow blowers come to mine, snow does not stick well to UHMW, so clogs, even with slushy snow, are rare. Throw distance can increase by 25%, maybe more :thumbsup:.
UHMW is a thermoplastic, so can be bent and shaped with heat, a heat gun works well, as does a propane torch if you are careful. The plastic will turn from opaque white to clear as it is heated. It must be held in place as as it is cooled. UHMW can be easily cut or machined with common woodworking tools, saws etc.
Lining the chute was the first project (and was written up in another post previously - though I think the photo links no longer work):
Last week I lined the impeller housing (hasn't been tested in the white stuff yet).
The UHMW used is 1/8" thick, 64" long by 6 - 7/8" wide. The acute angle bend (bottom in picture below or left side blower from cab), is about 35 degrees and is fully heat formed and fitted by first doing the larger bend outside the blower, then the side angles are bent and clamped in place after sliding the straight end of the UHMW into the housing in direction of impeller rotation. Then removed again. Since the liner has to be removable and insertable for fitting and replacement, (top in photo) cannot be heat formed. Instead a "V" chisel used in wood carving was used to carve a groove in the plastic on the inner surface to allow the side "ears" to be bent into position. Note the plastic isn't pulled tightly into position against the housing, but with snow pressure I'm sure it will conform - in any case not an issue.
Only the acute angle end at the "beginning" of the impeller housing is fixed in place with two 10-32 SS machine screws into drilled and threaded holes in chute (bottom of next picture). The exit end of liner (top in photo) is slotted for a single 10-32 SS screw, fender washer, and locknut - adjusted just snug. This is to allow for the thermal coefficient of expansion differential between the plastic and steel. (I put the UHMW in the freezer, measured length, then soaked it in my hot tub. The 64" length grew by 1/2", so that's how long the slot is.
Looking down the chute:
Should mention that I removed a small amount of material from the impeller blades to provide clearance for the liner. The blades were not all exactly the same length, so I used layout dye (Dy-Kem) and a divider to scribe a line off the face of the blower housing onto each blade - then had at it with angle and die grinders to get all the blades the same and a good snug fit to the liner with little friction - (a right angle air die grinder with 3M rol-loc sanding disks provided a smooth final surface to the blade ends). Dy-Kem was also useful for the grinding process as it made it easier to see where material was being removed when the dye was repeatedly brushed on the high spots.
Now where is the snow . . .
bumper
/ B2782 Snow Blower modifying #2
Wow, that's a nice clean job. I didn't think you guys got snow in the high desert.
/ B2782 Snow Blower modifying #3
Very nice work! I've been thinking about doing the same thing but I am running out of time this year. We get heavy , wet snow in this area and the UHMW PE lining would be the hot set up. Please update your thread as throughout the winter.
/ B2782 Snow Blower modifying #4
I like your idea. Very nice work!
Thanks for the compliments.
I live up against the eastern flank of the Sierra near the south end of Lake Tahoe. We get some lake effect snow and since we're in the shadow of the mountains, what we get is often slow to melt. I've seen 2 to 3 feet, not much by eastern standards I know, but still worth blowing. We've had two bleak years and some are thinking we may get hammered this year - - I hope, well, within reason anyway. If we don't, I may have to load up the tractor and head east to help you guys just so I can play in the snow some. This sitting on the tractor in the garage making engine noises is not getting it.
/ B2782 Snow Blower modifying #6
Wow. Very nice. After 8 years of gravel wear and tear on my impeller housing that may be a good material to reline it with some day. P.s. we got pretty good snow during the last big el nino in 97-98 so the buzz may not be too far off.
/ B2782 Snow Blower modifying #7
Nice looking job ----------Did you use the 1/8 " thickness in all locations?
Thanks,
Thanks,
Yes. But there's a caveat . . . when you look at the deflector, you'll notice that the plastic goes on each side of the chute and so it will not fit unless there is 1/4" slop between the deflector and the chute where the deflector sides overlap the chute. This is not a high wear area, so thinner sheet will be fine if 1/8" won't fit. BTW, those radiused slots are easiest to cut with a sabre saw after drilling the end holes - - I tried to get fancy and do it with an end mill cutter, not so good unless going to the trouble of setting it up on an index table to do in the mill (too much set up hassle)!
On this size blower, as posted in the copy, the circumference of the impeller housing requires about 64" length. I was not able to find a partial sheet for sale that had the required dimension (partial sheets offered for sale seem to max at 48"), so bought a full 96" X 48" sheet from "Plastics International" for $109 plus $40 shipping. Note that they were at first going to ship me the sheet *flat* and charge me $120 shipping!!! I said no way, it's thin, roll it up please! They said they would try and they called me back with the $40 price and it came nicely rolled up. If you want to get it flat again for cutting etc. just lay it in the sun.
I would have preferred to cut off the strip I needed on my table saw, but it would take a large table or 3 people to do that safely without having the sheet yanked. I marked a line and cut it with a saber saw, good enough.
Smaller sheets are available on Amazon etc.
/ B2782 Snow Blower modifying #9
Aaron,
I've been using UHMW tape (acrylic adhesive, not rubber) on aircraft for years, so I naturally went that route first, only using it on the deflector for the test. It got torn up when the blower picked up a bit of gravel. I think I was using 6 or 7 mil, so maybe the thicker stuff would work. It naturally resists impact and abrasion (a 1" thick piece will stop a .45 round), mine was just too thin. I don't think tape would last on the impeller housing.
I've been using 3/4" thick pieces for the skids for two seasons, I'm sure they are a little thinner, but not so's to look at. The UHMW skids prevent any damage to pavers and concrete etc.
bumper
/ B2782 Snow Blower modifying #11
Aaron,
bumper
That was my worry. Will keep looking.
Aaron Z
Aaron,
I don't think there's a known, existent material that is more suited for the job. There is a decision to be made, at least in terms of blower efficiency, and that is to line the impeller housing as I did, put paddle liners on the impeller blades, or both.
There's one enterprising individual selling "kits" which have pieces of rubber belting to seal the gap between blades and housing - this to improve efficiency and gain some distance. What I've done accomplishes that. I was faced with a varying gap, more than 3/8" at the lead in, to just under 1/8" before the exit. The rubber belting idea would flex to fill the changing gap, improving fan blow, but actually add a small amount of friction in the process. Thinner UHMW could function in a similar manner. I did consider using slotted UHMW paddle liners that would move to maintain contact with the housing wall face (and I may still do that - there would be zip for wear between the two surfaces and the moving paddle liners would help prevent any foreign object from getting between the paddle and housing/liner. It should also slightly increase efficiency over what I have already done. Doing the paddle liners and chute only, no impeller housing liner, should be almost as good as what I've done, it just would not prevent housing wear and would perhaps incur a little more friction moving the bulk of snow around the housing.
bumper
/ B2782 Snow Blower modifying #13
I have a snowblower that has impeller clearances that vary from 3/8" to 3/4"
I wonder how well the plastic from a plastic barrel would hold up. I have one that could be cut up without any drama. Might try it after I get it mounted to the L3830.
Aaron Z
Aaron,
See this page for info on the various polyethylene weights and properties: POLYETHYLENE UHMW HDPE LDPE
The strongest grade of PE is UHMW. The cost for a sheet adequate for the job is maybe $25 (with free shipping):
Amazon.com: UHMW (Ultra High Molecular Weight Polyethylene) Sheet, Opaque White, Standard Tolerance, ASTM D4020, D6712, D4976: Industrial & Scientific
Your barrel is most likely LDPE, the least dense and strong PE (by a large margin, up to 10 times depending on the specific quality). Since most of the effort in a project like this is labor, it hardly makes sense to skimp on the material used. UHMW is sold as virgin and recycled, I would only consider using virgin even though the cost is a little more. Do the job once (grin).
/ B2782 Snow Blower modifying #15
My uderstanding of UHMW is that it expands with heat like vinyl siding. If you fix it down when its cold outside it may buckle when sitting in a hot garage in the summer time.
In my first post I addressed the issue. The 64" length of UHMW I used was first placed in a freezer to cool, then measured and marked before putting in my hot tub. Then measured again and found to have "grown" by just under 1/2".
One end of the housing liner strip (blade "entry" end) is fixed in place with two machine screws. The exit end (where the snow heads to the chute) is NOT fixed in place in the lateral direction. There is a + 1/2" slot for the machine screw and fender washer to provide a sliding fit at this point to allow for the differential coefficient of expansion between liner and metal housing.
In use, the centrifugal forces imposed on snow will push against the liner to closely "mold" it to the steel housing. This will automatically adjust the slip fit end of the liner as needed to compensate for temperature variations. This sort, or similar, accommodation for expansion is an absolute requirement for my design to work, no question.
/ B2782 Snow Blower modifying #17
Aaron,
Looks like I will need a 8"x88" piece (I have a 7' Loftness snowblower with a "Truck Loading" chute). I contacted a seller on Ebay to see what they want for a 8"x100" piece. That would give me a little left over to try on the spout.
I have some heavy (3/8") rubber mudflaps that I will put on the ends of the impeller blades to tighten it up further.
Aaron Z
Aaron,
I posted source and price for a full sheet from the supplier I used. If it turns out to be not much more than the strip you need, I'd go the full sheet as you will find all manner of uses for the plastic (besides replacement liners for life :c).
I'd also use it for the ends of the impeller blades too - - would have to slot them as described earlier, but less friction than the rubber wipes.
The "spout" or chute and deflector was the first thing I did - if you ever have issues with clogging, this one change all but eliminates it. And, importantly, if a clog does happen in the slushy stuff, it is far easier to clear than before as it has no tendency to cling to the plastic as it does to steel. I'm sure you will find that it provides an overall amazing improvement.
I have no idea why the manufacturers haven't incorporated UHMW lining in their designs.
/ B2782 Snow Blower modifying #20
I could have sworn I read the whole post but I definitely missed the heating/freezing part. Sounds well designed and the pictures look good.
LEVIATHAN INC SAND CHIEF TRAILER (A67714)
LEVIATHAN INC SAND...
2017 Autocar Xpeditor T/A EZ-Pack 40yd. Front Loader Garbage Truck (A66736)
2017 Autocar...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
CAT C1.1 LITER WITH GEN END (CONDITION UNKNOWN) (A67714)
CAT C1.1 LITER...
2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
