Which tractor is top of the "B" series line... B3200 or B3030
/ Which tractor is top of the "B" series line... B3200 or B3030 #41
image.jpgThe b3030 is the premier of all the Kubota B series tractors even better than the new B3350s considering the new tier 4 DPF emissions systems that make buying and maintaining a lot more.
I have 2 B3030s, a B2710, a B2320 and a grand L the B3030 is tops in all aspects of using, maintaining and comfort to drive!
I own 43 acres of pasture / hay ground and 7 acres of lawns to mowe.
Can't beat the B3030s!
I would buy a low hours used B3030 over all the others.
/ Which tractor is top of the "B" series line... B3200 or B3030 #42
That's a lot of orange! Gotta get you in touch with some of the other Kubota collectors here. Welcome to TBN.
/ Which tractor is top of the "B" series line... B3200 or B3030 #43
I'm sure glad I bought my B3030 when I did.
/ Which tractor is top of the "B" series line... B3200 or B3030 #44
My thoughts only, no disrespect to others... I found new crated b3300su this past winter. I put money down, went to pick it dealership jacked up price 4800 more than agreed. So that left me only decision almost new, drive a truck for a living so know about Def (you don't want it, costly problems). I found a b3200 kubota fel/bh/be and woods double roller pulverizer/ woods scrape blade w box scrape plates double pivoting and 58 reverse land pride tiller, got a really good deal. Point is what are using it for and how picky are you. Me, I won't own a 3 cylinder been there had one and tested several. I can tell you it is a very noticeable difference also 3 cylinder has to be operated at higher rpm than the 4 cylinder to perform even the lightest of jobs. I liked the 3030 but could not find one, b3300su was first choice had no intentions for mid pto but since I have it with belly mower, I like it. Now I'm trying to find blower assembly for my rck60-27ba, shaft driven from deck with pulley to pto converter. I watched a video on u tube while searching for vac system by 2jeffs1 but not sure of brand??????
/ Which tractor is top of the "B" series line... B3200 or B3030 #45
It depends on the displacement and size, among many other things. Some of the large 3-cylinders will of course make more power than a smaller displacement 4-cylinder at lower RPM.
The main advantage of a 3-cylinder is that it is inherently balanced and a lot smoother than a 4-cylinder, which is inherently unbalanced. Once the engine starts to get larger, with more reciprocating mass, that is an important consideration. All else equal, a 4-cylinder would need the extra complications of a harmonic balancer to match a 3-cylinder for smoothness.
/ Which tractor is top of the "B" series line... B3200 or B3030 #46
You are correct, it was in reference to an older b7500. Rpm reference was bx series. Both are good tractors but was looking for a balance between hp and rpm in a b series. Only really one slight dislike with b3200 is front tire size but engine does seem smoother than the b7500. Had both tractors together, that how I came to that opinion.
/ Which tractor is top of the "B" series line... B3200 or B3030 #47
Isnt the new 3350 the a candidate with 33 horse and large tires?4 cylindar too
That being said last years model 3300 su is 33 horse 25 on pto and large tires 4 cylindar too
Ok ok i just bought one:)
Regardless im getting my local sign shop to detail mine shes gonna say super bee on mine thought it would be cool
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
