MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,982
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
Tires do grow. The Tire and Rim Association specifies maximum grown dimensions for each size. Growing is due to use, not due to being filled. When they come out of vulcanizing, they have a "green" tire size. As the tire flexes, especially in the first hours, the cords and rubber find an equilibrium which, due to air pressure, results in a larger tire than when delivered. On the large combine and tractor tires with which I am most familiar, growth is significant. I am not sure what it would be on a small tractor like yours - you mentioned as much as 3/4 inch and that would be normal for a 30.5 x 32 combine tire. We've experienced more than that. Tires should be supported off the ground when filled. That is how we factory fill and through experience, I found that if they tried short cutting the operation, letting air out to just a few psi before pumping in fluid, a high percentage had fluid streaks down the tires, unacceptable for a dealer to find when the machines were delivered.
