Do liquid fill tire expand?
/ Do liquid fill tire expand? #21
Tires do grow. The Tire and Rim Association specifies maximum grown dimensions for each size. Growing is due to use, not due to being filled. When they come out of vulcanizing, they have a "green" tire size. As the tire flexes, especially in the first hours, the cords and rubber find an equilibrium which, due to air pressure, results in a larger tire than when delivered. On the large combine and tractor tires with which I am most familiar, growth is significant. I am not sure what it would be on a small tractor like yours - you mentioned as much as 3/4 inch and that would be normal for a 30.5 x 32 combine tire. We've experienced more than that. Tires should be supported off the ground when filled. That is how we factory fill and through experience, I found that if they tried short cutting the operation, letting air out to just a few psi before pumping in fluid, a high percentage had fluid streaks down the tires, unacceptable for a dealer to find when the machines were delivered.
No pics yet but I did take some measurements. The Tires are 16.9-24 6PR R4 TI. Based on what I've read the tire sectional width is 16.9". Measured center of the left tire to center of the right tire the tire tread width is just shy of 59" (according to the owners manual this corresponds to the wheels being mounted in the 4th position out of 8. Just where you'd expect the factory to mount them). When I measured the sectional width just now, the left rear tire is 18.25" and the right is 18.75". If those are accurate then that is my problem and the tires did expand. To measure them I took two pieces of 24x24" plywood and stood them on edge on each side of the tires, then took 2 large framing squares to make sure that I was measuring two parallel surfaces and measured between them.
The owners manual indicates that if the tires are mounted in the 5th position, the rear tire tread dimension opens up to 63" (6th position will open it up to 67"). I'll take the pictures today but I think the solution to my problem is going to be to remount the wheels in a wider position. I'll try increasing the tire pressure just to see if that takes up any slack (max is 26 psi) but I don't expect that to help.
I probably would never have noticed except for the 485A backhoe's unique attachment.
/ Do liquid fill tire expand? #24
I expect the added air to help
Ran the air up to 26 psi (max per owners manual). No help. I took pictures and will get them up when I figure out how to post pix to this site. If anyone wants a better idea of what I'm trying to do, here is a link to a video of how to detach and hook up a 485A backhoe https://www.muttonpower.com/t-how-to-install-and-remove-a-john-deere-485a-backhoe.aspx Note the amount of room that he has to install and remove the pins. To be clear, the 485A frame is in 2 parts. One part is attached to the tractor frame and is designed to stay there (doesn't interfere with the 3 pt hitch or attachments) The second part is the backhoe itself on a ladder frame. You remove your top link (it gets in the way) Attach a guide bar onto your lift arms and back into the backhoe until the guide bar engages a notch in the frame. Lift the backhoe with the 3 pt hitch to its highest point then lower the 3 pt hitch and the backhoe frame engages the frame attached to the tractor. Ideally the holes that the pins go through at the attachment point of the backhoe frame and the frame attached to the tractor line up and you slide the pins in from the outside (always takes some lifting and dropping to get the holes lined up, I'll guarantee that they didn't do the video in one take and that they edited the heck out of it). Unfortunately, since adding the ballast to the tires there is not enough room between the tires and the frame to install the pins.
Just for the heck of it, while I was out just now, I was able to get everything lined up and insert the pins from inside. The pins are not tapered so that they can only go in one way. Other than John Deere saying that the pins go in from the outside, is there any reason anyone can see that they shouldn't go in from the inside?
/ Do liquid fill tire expand? #26
It looks like he had about half a foot of clearance from the tires. Your saying they expanded that much? or was this on a different tractor?
/ Do liquid fill tire expand? #27
Looks like to me inside would be fine.
/ Do liquid fill tire expand? #28
Tractor in that video had the rears set to the widest position.
This is the right side
This is the left side
This is the left side with the pin inserted from the inside
This is a closeup of the right side with the pin inserted from inside
/ Do liquid fill tire expand? #30
Should be fine, just watch if you get in some mud because those lynch pins have a habit of disappearing, other wise I'd say rock on.
Might make sure you have some spares in your toolbox.
I know that the pins fit from the outside before ballast and that the tires are an 1 1/2" to 1 3/4" wider now. I hadn't realized that the video (same tractor as mine) was set so wide. For stability's sake it wouldn't hurt to widen the stance but I'm certainly not equipped to remount the wheels myself (especially with 550 to 600 extra lbs of ballast each). Is my best bet to get it back to the dealer?
/ Do liquid fill tire expand? #32
Well if you don't trailer it much, then go wide! (wont fit between the fenders anymore unless you have a deckover.)
Do you have a concrete pad or apron / driveway to work on?
Do you have a couple of friends?
A bottle jack or strong floor jack?
If so, it ain't that hard. Having a hard surface area to work on and using your noggin it isn't physically hard at all.
You could if you like do it with your hoe on and use your hoe and stabilizers instead of a jack - but, just be careful and be sure to use some blocking or a jackstand under the axles just to give you a margin of error if a hydro line decides to blow whilst you are in a bad place to get smushed.
/ Do liquid fill tire expand? #33
For stability's sake it wouldn't hurt to widen the stance but I'm certainly not equipped to remount the wheels myself (especially with 550 to 600 extra lbs of ballast each).-------------------
An engine hoist or shop crane would make it doable. :thumbsup:
/ Do liquid fill tire expand? #34
This makes no sense. It is impossible that the tires grew to that degree. Did you watch the guy fill them?
/ Do liquid fill tire expand? #35
tis what i use to mount / remount tires.
it does help to have second person. to hold tire some when putting bolts back on. and to simply stabilize tire as it gets moved.
it can take a couple tries letting tire down re-adjusting straps and lifting tire back up to get all the bolts to align up for you.
if you are not willing to do it yourself. see about them just bringing a unit to you and work at your place. it should be a fairly quick job without to much hassle.
most agriculture / industrial tire shops that come out to deal with tires should already have some sort of crane / boom on there truck to deal with stuff.
/ Do liquid fill tire expand? #36
I agree. Though I wouldn’t be surprised to see a small difference in width, it’s simply not possible for them to increase 1.5” - 1.75” in width. I might have missed it, were they removed from the tractor when filled? I wouldn’t think so, just grasping for straws.
They were filled in my presence, on the tractor while jacked up. He estimated for me, before hand, that a 16.9-24 would take between 55 and 60 gallons to fill 3/4 way. I was told that Rim Guard weighs approx 11 lbs/gallon. I think the final figure was that I paid for a total of 112 gallons. My research on line indicates that 55-60 was a good estimate. Maybe my measuring this morning was off, I'll recheck. What isn't in dispute is that there is not enough clearance between tires and frame to insert the pins per the manual. I rechecked the 485A manual and there is no recommended mounting position for the wheels. It certainly won't hurt to remount the wheels in the 5th or 6th position as the added stability is always welcome even if Sussex County Delaware is as flat as a pancake. My old 18 ft trailer is too small for the tractor with the grapple and a Woods BB 720X rotary mower so I was looking at longer deck over trailers anyway.
Having said all that, I hooked up the backhoe after lunch (pins inserted from the inside position) dug a couple of stumps with no problem. Back to the house and no problem removing the backhoe. I should leave well enough alone but my OCD wants a new machine to operate the way the manual says it should.
/ Do liquid fill tire expand? #38
I see zero issues with putting the pins in from the inside. Saves you a whole lot of work
/ Do liquid fill tire expand? #39
Also, take a quick measurement from another tractor at the dealer?
/ Do liquid fill tire expand? #40
Yep -putting the pins in from the inside should not hurt a thing - they are just as secure and that is all that really matters. As for the tire - makes no sense what so ever, I filled mine and there is no different in size , can't understand how they could "grow" that much? Are you positive he didn't move the rims in when he filled them? That is the only way I can possibly see this happening....
Glad it is all working good for you.
2014 Honda Accord Sedan (A61574)
2014 Honda Accord...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
1994 Chevrolet C70 Kodiak 18FT Box Truck (A61573)
1994 Chevrolet C70...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
