Subsoiler build
/ Subsoiler build
The shanks are removable, so I'm sure when he needs to, he can have any number he needs for the application. I think his JD 5520 is about 90hp, which should pull pretty good in his soil.
It will make her grunt when I hit those spots of red clay. The removable shanks are a plus
/ Subsoiler build #22
I'm betting the tool is a bit under built. More of a heavy duty cultivator than a subsoiler. Think of the power needed to pull even one tine through heavy ground.
Deep subsoilers are usually limited to a single tine for many reasons.
But the nice thing about being a pessimist, is that one is left open to be pleasantly surprised! ;-)
Nice looking fabrication!
I agree. The OP has built a nice field cultivator.
A proper subsoiler looks like these:
Sub Soiler
/ Subsoiler build
Sub Soiler
subキsoil?r
ˈsəbˌsoilər/
noun
a kind of plow with no moldboard, used to loosen the soil at some depth below the surface without turning it over.
These are field cultivators.
https://www.google.com/search?q=fie...nT1ZeOGCM:&usg=__FHknCRNhj1ZB8v_ec3cAvofZCrk=
And subsoilers come in all various shapes and sizes
https://www.google.com/search?q=fie...=yyfzVY_iINKryASNobqoCw#tbm=isch&q=sub+soiler
/ Subsoiler build #24
subキsoil?r
ˈsəbˌsoilər/
noun
BR,
I think your subsoiler is solid and will work well in your soil.:thumbsup: However, you can make it beefier lookin' by painting it RED.:D How much does it weigh?
hugs, Brandi
/ Subsoiler build
BR,
hugs, Brandi
Thanks Brandi ... I think red paint will add 25 lbs!!!! I've not weighed it ... cant be much more than 275-300 lbs.
/ Subsoiler build #26
If you paint it red, you'd have to put Yanmar stickers on it:eek:
/ Subsoiler build
For Brandi "Mahindra" ... or "Red Beast" ... Any I sell I'll just custom paint and add any sticker I have to ... BTW neighbor bought my root grapple
/ Subsoiler build #29
Uh.........Big RED Beast. You put a Mahindra decal on it and it will grow 100 pounds.:cool:
hugs, Brandi
/ Subsoiler build #30
/ Subsoiler build #31
/ Subsoiler build #32
Hooking up my subsoiler..
Sub soiling my pasture
018.JPGATTACH=CONFIG]440498[/ATTACH]
/ Subsoiler build #33
It is interesting what different areas of the country have for soil. I can find 6 inches of sandy loam across the street in the unclaimed property I mow. I have a small area of that sandy loam in my property. The rest washed away before I got it. I made a 3 shank subsoiler and my tractor will stop when I am in clay. Most of my little 9.3 acres is red clay with a hint of topsoil. Even a single shank will bog out the tractor. OK, my tractor might weigh 3,500 pounds and has short 11.2x24 tires which means it has limited pulling abilities. My uncles, who are farmers say that the taller tires give you more pulling ability.
Anyhow, whenever the farmer across the street or the neighbor down the road pull a plow or disk, they pull up rocks. The neighbor probably learned his lesson as that is a lot of work to clean up a pasture after turning up rocks. One of my hay farmers 30 miles away sold his Pasture King airator because it pulled up to many rocks. I do not see any rocks in the family farm fields up in eastern Indiana.
/ Subsoiler build #35
Looks great! I built myself one a few years ago. Made the shanks too long and had to cut them down some. 36" down would stop our 190XT.
/ Subsoiler build #36
Never seen a RED Yanmar, just yellow
Yanmar excavators.
hugs, Brandi
Yeah, most of them are yellow and black these days. Google image "yanmar tractor" you'll be shocked!
So how has the subsoiler been working for you blueriver? I'm thinking about building a adjustable single tine subsoiler for my poorly draining three acres. Is there anything you'd do differently next time around?
/ Subsoiler build
Actually I've been busy enough in the shop that I've not even hooked it up!!
Sold 3 root grapples, 2 hay grapples and a custom gate order ... Been burning rods!!
/ Subsoiler build #38
That's great! I'm glad you're busy and making money. The gate in your signature is incredibly cool! I want to show it to my wife, but I know I'de be buying one... Ha ha
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
1761 (A58375)
1761 (A58375)
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2018 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2018 Ford F-150...
2019 VOLVO VNL TANDEM AXLE SLEEPER (A59911)
2019 VOLVO VNL...
