What do I do next
/ What do I do next #1
PuJo
Member
Central Louisiana
2015 RX6620PS
Morning All.
I have recently brush cut about 15 acres that hasn't been cut in about 20 years.
There were many trees that were about 2-3 inches and larger in diameter. Now that the area is cut, I am left with thousands of small cut trees and branches.
Way too much to pick up by hand. What is the best way to clear this up?
Thanks,
PuJo
/ What do I do next #2
A grapple would be my choice. Are there stumps left above the ground? If you can drive over it with a tractor, I guess you could use a box blade or rake, as long as it won't get snagged on stumps. But it would be slow. Or just let it rot over time, perhaps spraying it regularly with herbicide to keep it clear until you can bush hog it and chop it up . Guess it depends on what you want to do with the area, how big a hurry you're in, and your budget.
Sent from my iPad using TractorByNet
/ What do I do next
No many stumps left. Most of them are either cut at or below ground level.
I have plenty time, just cleaning the property, no plans as of yet.
I do not have a grapple, so maybe just the box blade.
Thanks,
-PuJo
/ What do I do next #4
Is it in an area where you could have a controlled burn in the spring? Would get rid of the brush weeds and possibly the stumps as well as put nitrogen back in the soil.
/ What do I do next #5
Push them into piles with front end loader or back blade. When you get all you can in one pile, burn it and move to the next area.
/ What do I do next
I plan to burn them in the spring.
It's way off the beaten pass, but I will contact the local fire dept in advance.
I guess using the loader, and blade would do the trick, just going to take a while...
But that's half the fun isn't it??
I guess my overall goal is to get the area clean, and get the grass (not weeds) to grow.
Thanks,
-PuJo
/ What do I do next #7
Buy a Ratchet Rake for your bucket from the T-B-N store.
Ratchet Rake on your bucket is really effective at piling timber debris, prying out <3" stumps and light grading after brush has been removed. Much, much more effective than a 3-Pt. mounted Rear Blade or Landscape Rake.
I would favor burning piled brush.
VIDEO LINK: https://www.youtube.com/results?search_query=RATCHET+RAKE
/ What do I do next
Ratchet Rake is really effective at piling timber debris, prying out <3" stumps and light grading after brush has been removed. Much, much more effective than a Rear Blade or Landscape Rake.
Cool, I have a tooth bar with 4" teeth that was installed at the dealer. It only has one set of teeth but I think I can get it to work like the video.
Thanks!
-PuJo
/ What do I do next #9
No, you cannot.
Tooth Bar is not a substitute for a Ratchet Rake.
For $400 buy a Ratchet Rake. Fifteen acres contains a lot of debris. You will be glad you disgorged for the Ratchet Rake.
/ What do I do next
Ok, thanks for the insight.
I am saving to purchase a set of 12-14 foot disc at the moment. It will have to wait till I get the disc first.
Thanks,
-PuJo
/ What do I do next #11
Your toothbar will work fine for piling brush. You may loose a sapling under the bucket now and then and have to back up to retrieve it but they still get the job done. Once you get one or two trees collected in the bucket, they will tend to push the rest in front as long as you have the power and traction to push them. Just push them up into as big of a pile as you can then start another one.
Try to avoid trapping dirt in the pile. Go slow and watch for those stumps so that if you do accidently hang one, you are going slow enough that you wont damage your FEL.
Lay the bucket lip flat on the ground then tilt it up just slightly and it will slide over most stumps but be aware that if you tilt it too much, limbs and small trees are also going to slide under it.
By the way, I don't have a toothbar on my B26 and it does an adequate job of piling brush. My other tractor had one and it was much easier to gather up all the limbs with it.
/ What do I do next
I should have enough power. I purchased a 2015 RX6620PS a few months ago.
I will take it slow, and try to get everything into a pile without piling too much dirt. If we don't have a wet spring, I can get it done early before the first brush hogging is due.
/ What do I do next #13
No, you cannot.
Agree. Even a grapple is no substitute for a Ratchet Rake in collecting debris (the grapple is much better at moving piles however).
If I were in the OP's shoes, I would temporarily remove the toothbar (really only useful for digging) and install a ratchet rake. I'd use the ratchet rake to scrape while driving backwards with the bucket in a mild dump orientation and with the RR tines just barely on the ground.
If I had my druthers, I'd then convert my bucket to a bucket grapple and use that to move the piles around. A regular standalone grapple is better at that task but you can have a RR mounted on a bucket grapple and the convenience of a single FEL device would trump the full grapple in this case.
I'm not so sanguine about the ability of the RR to dig out the stumps of 3" saplings. It might work but really you want to get something (like grapple tines) underneath the stump to pull up. Pulling sideways or parallel to the ground, which is all the RR can do, will work for small bushes and small sapling stumps but will likely just slip off of 3" stumps.
If you have a large area of these smallish stumps and don't expect the field to turn into a golf course green or a pasture for horses in one year, you might just consider just repeated bush hogging at a low level setting. They will die and rot eventually but you'll need to mow more than a couple times a year to hurry that process along. Depending on how heavy duty your bush hog is and how soft the saplings and branches are, you could actually avoid collecting and burning anything and just bush hog over and over. I've seen that done and have done it myself in small areas. Bush hogs in the medium and heavy duty category can make chips/mulch out of just about anything smaller than 3". Mowing over the same area about three times from different angles will mulchify nearly all the debris and regular bush hogging after that will get the rest. It may delay regrowth of grass by a season but it will keep the area clean and will take a lot less time and hassle than raking and burning.
/ What do I do next #14
I've used both toothbar and ratchet rake for collecting debris. There is a big difference in efficiency. Trouble with the toothbar is that you need to keep the bucket in full dump position to keep debris from simply sliding under the toothbar tines and when that happens the bucket is raised and you lose most of your load. To keep the bucket in full dump, even in float, with the toothbar in contact with soil will almost always dig/rip sod. The ratchet rake is effective at milder angles and in float you can use the front edge to guide the bucket along the soil while the rear ratchet blades (set at 90 degrees from the front) are set an inch or so above the soil and will collect debris. I just found the RR much more effective for backwards raking.
/ What do I do next
Wow, I didn't realize there was that much of a benefit to using the ratchet rake....
I wish I could get on now, but my priority is the set of disc. I can wait a year or 2 for the debris to rot, and I will continue cutting about once every 6 weeks or so.
Thanks,
-PuJo
/ What do I do next #16
I'm a rachet rake convert too. Bought one about a week ago for a similar brush cleanup and it works great. In another lifetime, while just out of college, I worker for a landscaper in central Louisiana (Baton Rouge). Most of the time I ran a fairly large brush hog doing a number of commercial and development sites. I've chopped up more rabbits and rattlesnakes in a day down there than I even see in a lifetime in NJ. Not to mention the crawley critters and fire ant mounds. Brush and grass grows faster in three weeks than it does in half a season here in Jersey. Debris also rots faster so I might be tempted to follow Island Tractors advice and leave it in place for subsequent mowings.
/ What do I do next #17
I have moved a lot of brush with a boxblade. I have a hydraulic top link and can vary the position of the scarifiers. I drag the brush up close to the pile and then turn around and push it up into the pile.
/ What do I do next #18
I've cleared, down to the dirt, many acres with nothing but a regular FEL bucket. Grapple would great be great but pricey. Other gadgets like the ratchet rake would be fine too but again, more money. Box blade does not work well at all. Regular 3 pt rake works great for the small stuff and I recommend one because they are versatile. Tooth bar works fine but is fiddly. However, it serves other purposes for your money. But, the bottom line is that you don't need any of this stuff for one job for which you have plenty of time. When I cleared 4 acres of 5-8" pines and brush I found a sort of ravine to push it all into, burned it and then used the box blade and bucket to push dirt on top.
/ What do I do next #19
Please, when you are shopping Disc Harrows or writing about Tandem Disc Harrows, describe them by pan diameter, then adjustment mechanism, maybe frame dimensions, WIDTH LAST. You will make a better decision.
For your Kioti 22" to 24" pan diameters are appropriate.
LINK: http://www.tractorbynet.com/forums/attachments/308251-disc-harrow-selection-18-45-a.html?highlight=
You are not far from Monroe Tufline, one of the best Disc Harrow manufacturers, which has a diverse offering.
LINK: Agriculture | Tufline
/ What do I do next #20
I can attest to the success of several bushhoggings to mulch your debris and then leave it to rot (assuming you are not in a hurry). And I can confirm that 15 acres of debris, even if quite thin, will make for LARGE piles and BIG fires if you spend a LOT of time collecting and piling it via just about any method.
- Jay
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Caterpillar 12/14/120 Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
2016 John Deere 6155R (A64119)
2016 John Deere...
Caterpillar 322B/325B/325BL Excavator Service, Parts, and Operation Manuals (A63117)
Caterpillar...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
