Battery powered angle grinder to cut 3/4" logging cable
/ Battery powered angle grinder to cut 3/4" logging cable #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
A thread was posted regarding ways to cut logging cable. Here is a test using a 10 year old DeWalt 18volt angle grinder. It stands to reason that the technology has improved in 10 years but I have never used anything but my old DeWalts. My batteries are 4 years old and past their prime. My batteries were 2.4Ah when new, and the new batteries have more capacity. A 4.8Ah battery would (in general) run twice as long as a 2.4Ah.
There is a tangle of rigging buried underground here. I mow this field twice a year and in between, I forget that I planned to cut that cable out of the ground. The 27HP tractor that I have can't pull it out. Today is the day to cut it out.
It took 57 seconds to cut 3/4" logging cable, and it used 1/16" of a 4 1/2" harbor freight abrasive cutoff disc. I don't know how many cables I could cut with one battery, I suppose between 10 and 20. And if you made no mistakes, the 4 1/2" abrasive disc might be down to 3 3/4" or so after 10 cables.
As the cable cuts, you can sometimes choose the best way such that it springs open and doesn't grab the disc. The strands can be under a lot of tension. If it's not cooperating you have to go at it from a different angle.
439946d1441571744-battery-powered-angle-grinder-cut-0cable-field-jpg
439947d1441571744-battery-powered-angle-grinder-cut-1cablesize-jpg
439948d1441571744-battery-powered-angle-grinder-cut-2_060_hf_abrasive_blade-jpg
439949d1441571744-battery-powered-angle-grinder-cut-3position-jpg
439950d1441571744-battery-powered-angle-grinder-cut-4_cut_cable-jpg
/ Battery powered angle grinder to cut 3/4" logging cable #2
I have been told, and read, that mildly enterprising thieves are using just that to quickly cut thru hardened locks- the kind that used to be considered secure. Sounds like nothing is safe unless it is constantly under watch.
Dang you're right about that, but the mildly enterprising are already watching YouTube how to pick the lock, probably on YOUR wifi. Lucky most thieves are dumb.
/ Battery powered angle grinder to cut 3/4" logging cable #4
When I was turning wrenches fulltime I accumulated a bunch of 18v Dewalt stuff. Bought the angle grinder as an afterthought. With abrasive & cutoff wheels and the irreplaceable flap wheels, I used it as much as the rest of the bunch combined. Yours looks identical.
/ Battery powered angle grinder to cut 3/4" logging cable #5
I use combo locks, because I can change the combos if needed, and a 'bump key' isn't an issue. Angle grinders, not so much.
What would a diamond blade do with the cable? I would thing it would cut it too, yes?
/ Battery powered angle grinder to cut 3/4" logging cable #6
I don't think there is a padlock with an exposed shackle of any kind safe on this earth from a battery powered angle grinder with a harbor freight cutoff wheel in it.
/ Battery powered angle grinder to cut 3/4" logging cable #7
I could be wrong, but aren't diamond blades for your angle grinder made to cut masonry not steel?
/ Battery powered angle grinder to cut 3/4" logging cable #8
Probably diamond wheels are mostly for stone; but I'm just curious if they will cut metal like a shackle too.
/ Battery powered angle grinder to cut 3/4" logging cable #9
Diamond wheels will cut metal, but will not last very long cutting iron or steel.
The problem is that diamond is carbon crystal and carbon dissolves in hot iron or steel. This is how carbon steel is made, although a less expensive source of carbon is usually used. Essentially the iron chemically attacks your expensive diamond wheel...
/ Battery powered angle grinder to cut 3/4" logging cable #10
Curly Dave explained just what I once watched... a rushed contractor using a diamond blade to cut thru steel. It was noisy, and destroyed the blade pretty thoroughly, but got the job done. He could have changed to a cut-off wheel and done it in less time.
/ Battery powered angle grinder to cut 3/4" logging cable #11
One way to help lessen damage to the thin cutoff blades is to position the grinder so the material being cut will pull the grinder forward (throwing sparks at the user's hand) if it snags. Don't apply excessive pressure and let the disc do the work. With the material being cut is positioned to throw sparks to the side, or away from the operator, the tool's movement is greater when it catches.
/ Battery powered angle grinder to cut 3/4" logging cable #12
Interesting, thanks, Curly.
/ Battery powered angle grinder to cut 3/4" logging cable #13
I've got a lot of time using skinny wheels, they really eat through material but need a great deal of respect. Since the best ones are the 6" Metabo .0625", they are quite fragile and side loads or binding will grenade them. Also, you want to have a very firm grip on the grinder, if it gets away from you it can do severe structural damage to a hand and a heavy welding glove won't even slow it down. Look at each cut as if it were a chainsaw in wood; will it close up and bind or twist and bind? If so, change your approach and or block or clamp so it can't bind.
/ Battery powered angle grinder to cut 3/4" logging cable #14
Great, now i gota go buy another tool, thanks sodo. :)
/ Battery powered angle grinder to cut 3/4" logging cable #15
The thin ones cut skin so nicely. If we just cut the hands off the thieves, we could all sleep easier! Many people build a heavy cage around the lock, only accessible from the bottom and inaccessible to a grinder.
/ Battery powered angle grinder to cut 3/4" logging cable #17
If you don't have a cordless bandsaw, GET ONE. I just upgraded from my Bosch with the 2.5" throat to the Milwaukee 5". Use it for cutting everything. It works great on steel cable, just cut a bunch of steel strapping and rebar over the past few days, as well as a ton of 2x2x3/16 tube and angle for a project.
,,,, bandsaw,,,, It works great on steel cable,,,,
Really? Thats not something I would think of for cable. I would think cutting (logging) cable with a bandsaw would be like trying to cut a bundle of drill bits. I suppose some cables made of mild steel, but not sure where its used or where one might encounter mild steel cable.
Does sound like a useful tool though.
Rick have you been buying replacement batteries? What type, and are they equal to the original 2.4Ah? I'm nearing the end of my rope on batteries, all 4-5 years old and dropping like flies.
I see Dewalt offers 2.0A Li-Ion batteries for $116, that is not appealing.
/ Battery powered angle grinder to cut 3/4" logging cable #20
Nope, the cable holds together pretty well, unlike a "bundle of drill bits".
