Cub Cadet 3000 series slow reverse
   / Cub Cadet 3000 series slow reverse
While I have you cub guys here, has anyone ever had an issue with their cub 3000 series not turning as far in one direction as it does in the other? All the cub manual says is to bring it to the dealer
   / Cub Cadet 3000 series slow reverse #12
I haven't, but there may be an adjustment. You could call the dealer and ask or maybe check at onlycubcadets.com
Sent from the mountains
   / Cub Cadet 3000 series slow reverse #13
I don't know specifically, but in my situation I was turning tighter to the left. I knew it was something I needed to check, but before I got around to it the shaft on the power steering piston came off. Seems that it had had loosened on it's own and the result was more play in one direction over the other. After reassemble and a touch of locktite it was good as new.
The loose bolt in the differential lock which seized the rear end is a whole nuther story though.
Killbros 350 Gravity Wagon (A50775)
Killbros 350...
New 4x6 Chicken Coop (A50775)
New 4x6 Chicken...
McCormick W-4 Tractor (NOT RUNNING) (A50775)
McCormick W-4...
2005 Nissan Pathfinder SUV (A55758)
2005 Nissan...
2010 Dewalt Air Compressor (A55787)
2010 Dewalt Air...
