Subsoiler build
/ Subsoiler build #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
Just thought I'd share some pictures ... got a start on a subsoiler.
/ Subsoiler build #2
Looking good man! I'd run full seam welds on the front's and rears of the tine mount brackets. I would also make wider swathes, and get that super hot penetration into both weldments. Looking great though. Keep it up! Still totally jealous of your plas abilities!!!!
/ Subsoiler build
Oh yes great advise ... I always in situations like this give it a second run HOTTER and WIDER ... I'll keep pictures coming!!!
/ Subsoiler build #4
Smart man! I figured it might be a little too early to call that out. What's your soil like?
/ Subsoiler build
Sandy Loam then that hard red clay
/ Subsoiler build
A little more progress ... lacking braces on the top link and paint!!
NO ITS NOT A DIRT FLOOR ... had to suck up some oil!!!
/ Subsoiler build #7
You & your plas. table are really starting to piss me off:laughing:
Looks real nice:thumbsup:
/ Subsoiler build #8
/ Subsoiler build
ha ha .... better to be pissed off than pissed on!!!
/ Subsoiler build
Same here. That clay can be a bear when it's dry! Digging the posts for my barn in the summer was a human backs nightmare!
Looking really nice!
Thanks ... that dried out clay is tough.
/ Subsoiler build #11
You DO know that I'm just jealous, I'm just afraid that if I make that $tep up that I'll just be unable to do the programing (computer) side of it and it'll become an expensive mistake taking up room and pissing me off every time I walk around it while it's just in the way. This and a few other forums are the extent of my skills with a 'puter. He!! I feel like an "einstein" every time I am able to post a picture:laughing:
Why did you bolt the "shanks" on, and will you be able to put a small "tooth cover" like off a S. steer bucket on the tips?
Oh, and your root rake turned out amazing also!
/ Subsoiler build
Its a learning process for sure ... the bolts are "shear' pins ... I've been searching for replaceable tooth covers and have found an idea that I will incorporate into the build.... I love that root rake grapple ... Thanks!!
/ Subsoiler build
Threw some paint at it
/ Subsoiler build #15
That looks great. Let us know how it works!
I'm betting the tool is a bit under built. More of a heavy duty cultivator than a subsoiler. Think of the power needed to pull even one tine through heavy ground.
Deep subsoilers are usually limited to a single tine for many reasons.
But the nice thing about being a pessimist, is that one is left open to be pleasantly surprised! ;-)
Nice looking fabrication!
/ Subsoiler build
I'm betting not ... I used the a similar one last year that I borrowed from my neighbor... went over 34 acres with no problems and loved the results ... I got his and took measurements ... went with a larger beam than his.
Now I've not built this as a rock ripper ... subsoiler in pastures and hayfields.
/ Subsoiler build
I'm betting not ... I used a similar one last year that I borrowed from my neighbor... went over 34 acres with no problems and loved the results ... I got his and took measurements ... went with a larger beam than his.
/ Subsoiler build #18
Your soil must be a lot looser than mine. A 5 shank sub-soiler would take a 200 hp tractor in my black land clay.
Nice work.
/ Subsoiler build #19
The shanks are removable, so I'm sure when he needs to, he can have any number he needs for the application. I think his JD 5520 is about 90hp, which should pull pretty good in his soil.
/ Subsoiler build
Nice work.
You are so right ... that black clay you got is some solid soil. I'm sandy loam with red clay in places. You guys grow better crops than we do!!
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
Cat CB24B (A60462)
Cat CB24B (A60462)
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
