Fish Tailing
/ Fish Tailing #1
jp2code
Longview, TX [USA]
Kubota BX2200 and L4400DT
OK, what causes fish tailing?
It must have something to do with how the load is setup on the trailer.
I pulled the tractor to a field that needed mowing, and noticed the trailer started fish tailing if I got over a certain speed.
So, I maintained that speed. No big deal.
I finished mowing, loaded back up, and off I went.
Something was loaded differently, though. This time I wasn't able to get up nearly as fast as the first time.
So, is fish tailing caused by the load being too far forward, too far back, too much on the left or right?
It's got to be something.
/ Fish Tailing #3
George has it right. Never have I had this problem, but I have seen some scary sights on Interstate 81 with trailers fish tailing-one time, my fiancé insisting we get off the highway when the truck and trailer in front of us was swaying at least a foot back and forth while they going 65-evidently scared us more than them!
Will
/ Fish Tailing #4
Usually, fishtailing is caused by not enough tongue weight or the load on the trailer is too far back. Uneven tire pressures or a suspension problem can also cause the problem.
https://answers.yahoo.com/question/index?qid=20101222183809AA1g8ZT
Ayep.
See if you can find a scale that will let you roll across a couple of times to compare tow vehicle rear axle weights and trailer tongue weights.
You want around 10% of the trailer weight on the tongue.
Aaron Z
/ Fish Tailing
That's what I was thinking, but I wanted to verify. I try not to drive the tractor too far up, because it can put too much load on the truck's suspension. The trailer's axles are 3500 each, which is way more than what the truck can take.
I noticed when going down the road that the tractor was scooted over more towards the driver's side than the passenger's side, so I thought that might have had something to do with it.
The tires were checked this morning before heading out.
Freaky as **** when it starts, too. I've got a little play in my truck's steering and one brake already grabs before the other. I'm glad I wasn't going fast.
/ Fish Tailing #7
What type of truck you using?? A s10?? A ranger can even take a good 3,000 lb load. We have had ranger bumpers to the ground and no suspension problems
/ Fish Tailing
Remember when Toyota and Nissan used to make those little 1-ton trucks in the '80s? Think about those little U-Haul trucks or the Toyota Dolphin/Nissan Sunrader motorhomes.
From 1993 to 1995, Nissan made a 3/4-ton. GVRW rating on it is 5600-lbs, but just about all hitches state not to put more than 500-lbs of weight on them.
/ Fish Tailing #9
jp2code,
Looking at your picture, I, as a RETIRED truck driver, would suggest that you first tip the bucket down a bit to be level with the deck. Then move the tractor FORWARD so the bucket touches the front frame of the trailer. I can not tell from the picture how you have it secured to the trailer, but I would suggest using 2 attach points on the front axle and 2 points from the rear axle OR draw bar hitch. Check out how that setup handles. IF it improves you are going the right direction. You MAY have to raise the bucket a bit and set it ON TOP of the front trailer frame to get the right placement for a good ride.
Good luck.
Dave
/ Fish Tailing #10
Your L4400 w/loader is probably close to maxing out your 7K trailer, especially if the tires are loaded.
At 500# max tongue weight the hitch needs to be upgraded.
That Nissan pickup looks more like an S10 than a 3/4T truck.
I'd say neither the truck or trailer is capable hauling that load safely.
/ Fish Tailing #11
Are the tires on the truck 8 ply rated? My 1987 Toyota 1 Ton (was sold as a 1 ton with emblems on the fenders and tailgate) was rated for a 5,000 pound trailer. It was also rated to carry over a ton in the bed (5600 GVW). It had 8 ply rated tires that were supposed to be pumped up to 65 PSI in the rear when working.
I spun out my Toyota when I was carrying 20' 2x8s on my equipment trailer. When I got home I did the math and I was way overloaded. I had not checked the tire pressure on the trailer. I was not going over 30 mph at the time I spun. I was much more aware of over weight from then on.
/ Fish Tailing #12
Classic example of the tail wagging the dog on the video below. Like others have said, it's all about tongue weight. I like to see the rear bumper drop about 2-4 inches when the trailer is loaded (as compared to no trailer hooked up). You should have sufficient tongue weight on it then. If you have some good scales, you can put them under the tongue jack on the trailer (after it's loaded down) and jack it down so it's sitting on the scales to see about how much tongue weight you will have.
https://www.youtube.com/watch?v=MMkq7PSQhI4
/ Fish Tailing #13
That is not a safe trailering operation. The truck is too light. This tail will wag the dog and you'll be in a world of hurt. And legally liable since the GVWR is exceeded. JMO.
/ Fish Tailing #14
Also a semi retired truck driver. I wouldn't feel safe hauling a load with that set up. The rear tractor tires need to be moved forward, over the axles, if that means resting the bucket on the front trailer frame, so be it. You always want as much load contact with the trailer deck as you can get. Can't tell how the tractor is anchored, but load rated chains are necessary, and tire pressure equal and adequate. That pickup may be rated to do the job, don't know for sure, but it is way too light, if you are going to do much trailering, a bigger tow rig is needed. You don't want to risk tractor trailer wreck or injury to others using the same road. If that trailer starts fish tailing, and your attention is momentarily elsewhere, bad thing can happen.
/ Fish Tailing #15
I was 16 years old when my Dad bought a service station and we hauled our own garbage and such to the dump on a little two wheeled trailer. I towed that trailer with a clamp on bumper hitch (which I assume many of you are too young to have ever seen) on the back bumper of my ten year old 1946 Chevy 2 door sedan with nearly 100k miles on it. One day when I went to hook it up, the load was heavy enough behind the axle that I had to pull the tongue down instead of lifting it up to hook up, and I didn't know any difference. I got up to 50 mph and that thing started fishtailing and I only barely avoided crashing. But it was a lesson I never forgot.
When I hauled my little Kubotas and my brother's Kawasaki Mule and other things on a 16' trailer, I actually used a yard stick and measured the height of the rear bumper on the truck. If the load wasn't heavy enough in the front to lower the back bumper of a 3/4 ton Ford more than an inch (preferably 2"), the load was re-arranged or moved forward.
But NEVER after that experience when I was 16 have I had a trailer fishtail.
/ Fish Tailing #16
Tail wagging the dog. Bumps, depressions, speed and corners make it worse. That trailer is a bit short from tongue--> axles to drive on--backing on would get more weight forward with no implement on the back, or setting the bucket in front of the bar. You said you were mowing--did you have a bush hog acting as an eight foot lever off the back?
Looks like the springs on the Nissan are already about flattened though. You want to get enough tongue weight that conditions won't create a lift on your truck's rear axle. The tongue weight should keep your vehicles rear axle pinned to the pavement. You probably know not to hit the vehicle brakes if a heavy load is fishtailing and your trailer has no brakes, but I'll mention it in case readers aren't aware--the trailer will keep going and you'll be jackknifed if not detached or rolled. Trailer brakes will help settle down an active trailer, but getting the weight distribution right is the only way to prevent it. Accelerating will pull the tongue back down if the situation was caused by a turn or road condition, but won't help if speed precipitated the event. I'd be hesitant to tow that set-up much of a distance or at any significant speed.
/ Fish Tailing #17
I have several clamp on hitches... think the last time I used one was on a 1975 Ford Granada towing a 1200 lb fishing boat and trailer...
Only one time did I have a white knuckle ride and it was due to sacks of concrete shifting on a pallet when I went up a steep driveway...
/ Fish Tailing #18
Try moving the tractor as far forward as possible. If that won't give you enough tongue weight try backing it on.
As others stated you need 10% tongue weight minimum.
Chris
/ Fish Tailing #19
An L4400 and a 5 foot shredder should be on a 20 foot trailer, at least an 18 footer IMHO. My L3901 and a 5 foot shredder takes up 19 feet of my 20 foot trailer.
The truck is way too light. To be safe you need a 3/4 ton. Upgrade to a 3/4 ton truck and 20 foot trailer. Put the majority of the weight being hauled on the trailer axles (not forgetting about proper amount of tongue weight) and you should be fine at highway speeds. Truck rear tires should be heavy duty 8 ply sidewall to prevent sway as well. With your present setup you are either going to exceed the tongue weight the truck should have or have too much equipment hanging out over the rear. Either condition could cause fish tailing.
/ Fish Tailing #20
It's a compromise- more weight on the trailer is a smoother ride, more on the truck is a rougher ride, but smoother. 10% is the ideal- it gives an acceptable ride yet still puts enough weight on the truck for stability.
Will
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A64553)
2013 Hitachi...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2019 VOLVO VNL760 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2019 VOLVO VNL760...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
