Repairing sidewall rips?
   / Repairing sidewall rips? #11
What I know will work is polyurathane caulking as I have done it !
A brand that I know is FLEXTRA which is close to the caulk they glue windshields on cars.
Clean the inner with a non greasy solvent glob the caulk and press a generous patch to cover the hole. Let dry/cure and you'll be surprised.
Windshield caulk in a tube is in the $10.00 range.
Well I had to practice what I preach.
Nice long rip, cords showing and I can`t find a replacement.
I used some nylon fabric that was about one eighth thick and generously smeared it with the Flextra caulking.
Re inserted the tube and inflated to about 25psi and sat it in sunlight to let the Caulking cure.
Today I moved crushed stone by the bucket full and no signs of the buck-she repair failing.
   / Repairing sidewall rips? #12
It's called windshield urethane. You can get it at most auto body repair places in the big gun tube. Remember it when you just gotta absolutely gotta keep something waterproof and glued together. The other go to stuff I use is 3M 5200. It's white and they seal holes in fiberglass boats with it. Same principal and Lowes usually has it but it's pricey. Consider both like a welding and waterproofing combined. You have to cut it to remove. The trouble with both is that what you don't use once the tube is opened WILL dry up no matter what you do after a couple weeks. Too bad they can't cure that issue but besides that they both are fantastic and not all that expensive. Both are great for gluing impossible things like stainless steel to plate glass and such.
   / Repairing sidewall rips? #14
'nother use of urethane caulk.
Borrowed buddy's B21 as he has backhoe.
His seat had 3 tears in it and I got a wet butt, no fun.
Cut some patches and glued them in place with urethane caulk. (Flextra).
Sure is better than duct tape.
   / Repairing sidewall rips? #15
You can delay curing of open 5200 caulk tube by covering tip with plastic bag or Saran Wrap and storing in a freezer, but only for a month or so.
   / Repairing sidewall rips? #16
I'd replace the tire. It's a tractor... It'll need good rubber. You'll only make more work for yourself. I wouldn't put my name on something questionable.
Regards,
Chris
   / Repairing sidewall rips? #17
I was at my local tire dealer the other day and saw he had a heat blanket wrapped around a tractor tire. Turns out he was vulcanizing a relatively new tire that got cut on the sidewall. Certainly would never try this on a road vehicle, but it's something to consider if you are off road.
   / Repairing sidewall rips? #18
Regards,
Chris
With anything of such low speed why not? There is no such thing as a low speed blow out rollover unless you are doing something incredibly stupid. I can see it if you are some bigwheel farmer who has the massive operation going that just can't wait for some breakdown but not so with the majority of us. As long as you can live with the possibility of an inopportune break down fixing something like this can give someone with a spot of bad luck much of the useful service life he deserves (and paid for). Over the years I found that many of these types of fixes work out far better than hoped and I go through about 1 set of toothpaste sized JB Weld tubes / year in the process. For most of us our labor is free as well so the prospect of it failing down the road doesn't cost anything in labor either. It's all about your tolerance for risk / reward.
   / Repairing sidewall rips? #19
Love to do that but cannot find a replacement locally, hence the 'jerry rig'.
For now it works and allows me to do the right thing. Just buying me some time.
   / Repairing sidewall rips? #20
I totally understand what you're saying. Trust me, I've had to get by with rigging things up many of times. I know you can't always just throw money at something when it breaks. I know a guy that had a fully loaded FEL that tipped over from having low pressure in a front tire, while landscaping on a 2-3 percent grade. Should he have aired it up beforehand? yes! Could he have been more careful? you bet. Sometimes we make mistakes, and the results are very bad!
Regards,
Chris
500BBL WHEELED...
19008 (A56859)
19008 (A56859)
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
